Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi
) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Hello, Garuda newbie here. I want to know how do i make the OS not look that much purple and neon cause it’s making my eyes suffer. I want to have a clean and simple asthetic similar to Linux Mint for example. It’s just too much neon for me.
Welcome to the forum!
Plz note:
About what you asked:
This is plain Plasma feature, nothing special here, you can change any of or multiple of the following from System Settings :
FGD
Split this topic
3 May 2024 00:34
3
is this dragonizer? i don’t have the dragonizer one, i have Bird Of Prey
Bird Of Prey is the major release, dragonized is a spin of this.
Can i change the colors so it doesnt look that much neon or will i have to switch to dragonizer?
Again, please post your garuda-inxi as @FGD
already requested from you.
Kernel: 6.8.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=36512526-2da5-4732-abc7-d7b818904189 rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: MSI model: AM1I (MS-7865) v: 2.0
UEFI: American Megatrends v: 10.0 date: 02/21/2014
Info: model: AMD Athlon 5150 APU with Radeon R3 bits: 64 type: MCP
arch: Jaguar level: v2 built: 2013-14 process: GF 28nm family: 0x16 (22)
model-id: 0 stepping: 1 microcode: 0x700010F
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1141 high: 1591 min/max: 800/1600 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 799 2: 1376
3: 1591 4: 800 bogomips: 12776
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: eVga.com. driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2024-09-xx)
arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-2018 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: lanes: 8 ports: active: HDMI-A-1
empty: DVI-D-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:1287 class-ID: 0300
temp: 22.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa dri: nouveau
gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell SP2208WFP serial: <filter>
built: 2007 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 473x296mm (18.62x11.65") diag: 552mm (21.7") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM 17.0.6)
Device-1: AMD FCH Azalia vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
API: ALSA v: k6.8.8-zen1-1-zen status: kernel-api with: aoss
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtw_8822bu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3
chip-ID: 2357:012d class-ID: 0000 serial: <filter>
IF: wlp0s19f2u2 state: up mac: <filter>
Local Storage: total: 454.35 GiB used: 7.72 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: 0101 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 7.22 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
used: 7.72 GiB (1.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 8.8 C mobo: N/A gpu: nouveau temp: 21.0 C
Memory: total: 8 GiB available: 7.7 GiB used: 963.2 MiB (12.2%)
Processes: 229 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.07 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1348 libs: 465 tools: paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.34
System install date: 2024-05-02
Last full system update: 2024-05-03 ↻
engineergaming:
Desktop: Cinnamon
That explains a lot…
That’s why it’s important to post the garuda-inxi
Please edit your last post and put terminal output in a code block.
I need to install a different desktop manager?
nepti
3 May 2024 19:17
15
I don’t understand what you want, you just have to use a different global theme - @FGD
explained it.
Until now we didn’t know you were using Garuda Cinnamon.
The example from @FGD
shows the settings on Garuda KDE Dr460nized but the procedure is the same.
On Garuda Cinnamon, open the system settings and change the global theme or the colors or what ever.
Seems you did not search before posting.
So 412 Precondition Failed
Requests which fail basic precondition checks. For example you are not running Garuda Linux, did not search for a solution first , or you did not provide the information required to render assistance.
system
Closed
9 May 2024 17:01
18
