I want to transfer files to my /run/media/johnlamuel/Data/ directory cause it has more storage but when i try to transfer files a pop up saying "Could not write to /run/media/johnlamuel/Data/ screenshot_1.png."
I already tried doing chmod and mounting and unmounting but it still doesn't work
╭─johnlamuel@johnlamuel in ~
╰─λ inxi -Fza
Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=62aa587f-5047-4514-8fd1-0d539d5c469e rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Aspire A314-35 v: V1.09 serial: <filter>
Mobo: JSL model: Rosemary_JL v: V1.09 serial: <filter> UEFI: INSYDE v: 1.09
date: 06/22/2021
ID-1: BAT1 charge: 41.6 Wh (100.0%) condition: 41.6/41.6 Wh (100.0%)
volts: 12.6 min: 11.2 model: LGC AP19B8K type: Li-ion serial: <filter>
status: Full
Info: Quad Core model: Intel Pentium Silver N6000 bits: 64 type: MCP
arch: Tremont family: 6 model-id: 9C (156) stepping: 0 microcode: 1D cache:
L2: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8908
Speed: 3126 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 3126 2: 1900
3: 1895 4: 2284
Device-1: Intel JasperLake [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4e71 class-ID: 0300
Device-2: Quanta VGA WebCam type: USB driver: N/A bus-ID: 1-4:2
chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (JSL) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:4dc8
Device-2: Intel USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:11 chip-ID: 8086:0808
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lite-On driver: ath10k_pci v: kernel port: 3000 bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-8:3 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 1.03 TiB used: 75.95 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM128GD3JX016N
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41020C20 temp: 53.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 2J scheme: GPT
ID-1: / raw-size: 118.99 GiB size: 118.99 GiB (100.00%)
used: 34.39 GiB (28.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 118.99 GiB size: 118.99 GiB (100.00%)
ID-4: /var/log raw-size: 118.99 GiB size: 118.99 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.99 GiB size: 118.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.6 GiB used: 596 MiB (7.7%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 260 Uptime: 3h 24m wakeups: 1 Memory: 7.6 GiB
used: 3.3 GiB (43.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1762 lib: 505 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
╰─λ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1
ntfs Data 6446759B46756F24 890G 4% /run/media/johnlamuel/Data
zram0
[SWAP]
nvme0n1
├─nvme0n1p1
│ vfat FAT32 NO_LABEL
│ F1EE-BF8B 255.4M 0% /boot/efi
└─nvme0n1p2
btrfs 62aa587f-5047-4514-8fd1-0d539d5c469e 83.7G 29% /var/tmp
/var/cache
/var/log
/srv
/home
/root
