I've been fiddling with the audio for my bluetooth earphones in System Settings and I've noticed that the quality of incoming audio is horrible when I switch to headset mode (HSP/HFP, mSBC is better than CVSD but still horrible). Is there something I can install that will preserve the audio quality of High Fidelity Playback while also using the microphone?
This issue was described in this post as well, but it was locked before a resolution was presented: Bluetooth headphone mic error
garuda-inxi:
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0675be4a-0a5f-4a0b-96bf-87c54655178a rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y530-15ICH
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: 8JCN52WW date: 06/14/2019
ID-1: BAT0 charge: 45.4 Wh (100.0%) condition: 45.4/52.5 Wh (86.5%)
volts: 12.8 min: 11.2 model: SMP L17M3PG1 type: Li-poly serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2600 high: 2601 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2601 3: 2600
4: 2600 5: 2600 6: 2600 7: 2600 8: 2600 bogomips: 36799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:56a6 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.03 TiB used: 550.83 GiB (52.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 0109ADLA temp: 45.9 C scheme: GPT
model: WD10SPZX-24Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 27.16 GiB (22.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 1.92 GiB (25.2%)
System Temperatures: cpu: 55.0 C pch: 58.0 C mobo: N/A
Processes: 279 Uptime: 1d 6h 9m wakeups: 10144 Memory: 7.64 GiB
used: 4.51 GiB (59.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1379
libs: 421 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-07
Last full system update: 2023-01-13
Is partially upgraded: Yes
