I just connected my bluetooth headphones a few days go to my laptop. I'm dual booting with WIndows, by the way. While using HSP/HFP, I can use my mic properly, but the audio quality is low. When I switch to A2DP, the quality is fixed, but I can't use my mic at all. The option for using the headphone's mic disappears. How do I fix this?
The output of inxi -Faz
is:
System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=980a943b-afb8-4dbf-aacc-a09f6462a31f
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK serial: <filter> Chassis:
type: 10 v: Lenovo ideapad 320-15ISK serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter> UEFI: LENOVO v: 4WCN47WW
date: 06/30/2020
Battery: ID-1: BAT0 charge: 18.1 Wh (100.0%) condition: 18.1/30.6 Wh (59.1%) volts: 8.5 min: 7.6
model: CPT-COS L16C2PB2 type: Li-poly serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15999
Speed: 2000 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 2000 2: 2000 3: 2000 4: 2000
Graphics: Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1921 class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4 chip-ID: 5986:210f
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 0cf3:e500
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
Drives: Local Storage: total: 1.82 TiB used: 13.92 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
serial: <filter> rev: LDM2 scheme: GPT
Partition: ID-1: / raw-size: 61.93 GiB size: 61.93 GiB (100.00%) used: 13.81 GiB (22.3%) fs: btrfs
dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 103.6 MiB (40.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 61.93 GiB size: 61.93 GiB (100.00%) used: 13.81 GiB (22.3%) fs: btrfs
ID-4: /var/log raw-size: 61.93 GiB size: 61.93 GiB (100.00%) used: 13.81 GiB (22.3%) fs: btrfs
ID-5: /var/tmp raw-size: 61.93 GiB size: 61.93 GiB (100.00%) used: 13.81 GiB (22.3%) fs: btrfs
ID-1: swap-1 type: zram size: 3.62 GiB used: 1.17 GiB (32.2%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 43.5 C mobo: N/A
Info: Processes: 229 Uptime: 3h 5m wakeups: 1 Memory: 3.62 GiB used: 3.04 GiB (84.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1327 lib: 323
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
