How do I add Bing as default search for Firedragon?
I couldn't find a way to reply to your post, so I'm editing mine. I looked in the settings and Bing is not there. I reinstalled Firedragon to see if I could get it figured out but it says Firedragon profile cannot be loaded. It may be missing or inaccessible.
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=d674fff5-945a-44e3-8760-7c24b139ae74 rw rootflags=subvol=@
resume=UUID=069555e6-8d80-4d2a-9ea6-98a9bc6b5490 loglevel=3
Type: Desktop Mobo: ASRock model: B450M Pro4 serial:
BIOS: American Megatrends v: P5.10 date: 05/06/2021
Device-1: hidpp_battery_0 model: Logitech M570 serial: charge: 40%
rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3066 high: 3099 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3081 2: 3099
3: 3081 4: 3040 5: 3022 6: 3075 7: 3066 8: 3069 bogomips: 59202
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: PNY driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1b81
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4.3:4 chip-ID: 046d:0843 class-ID: 0102 serial:
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: PNY
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 717.99 GiB used: 37.33 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: HP model: SSD S700 500GB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: rev: 4A1 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37120G
type: SSD serial: rev: 71E0 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: rev: 1.00 scheme: MBR
ID-1: / raw-size: 94.7 GiB size: 94.7 GiB (100.00%) used: 22.46 GiB (23.7%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 94.7 GiB size: 94.7 GiB (100.00%)
used: 22.46 GiB (23.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 94.7 GiB size: 94.7 GiB (100.00%)
ID-4: /var/tmp raw-size: 94.7 GiB size: 94.7 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 57 C
Processes: 288 Uptime: 15m wakeups: 3 Memory: 15.54 GiB
used: 2.93 GiB (18.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1812 lib: 532 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-04-21
Last full system update: 2022-04-21 ↻
Windows dual boot:
Speed (MHz): avg: 3064 high: 3090 min/max: 1400/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3019 2: 3090
3: 3075 4: 3086 5: 3071 6: 3035 7: 3060 8: 3082 bogomips: 59199
s-diag: 610mm (24")
Local Storage: total: 717.99 GiB used: 41.27 GiB (5.7%)
ID-1: / raw-size: 94.7 GiB size: 94.7 GiB (100.00%) used: 26.4 GiB (27.9%)
used: 26.4 GiB (27.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.54 GiB used: 3.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 53 C
Processes: 299 Uptime: 44m wakeups: 6 Memory: 15.54 GiB
used: 2.87 GiB (18.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1814 lib: 532 Shell: fish v: 3.4.1
Garuda (2.6.1-3):
Windows dual boot:
I already looked in settings and didn't see it there, nor did I see an option to add a custom URL to create it. I searched the forum for how to add Bing search to Firedragon and there were no results specific to Bing, but it showed Google was already there. I then did a Google search for "Garuda Linux Firedragon change default search" but I still haven't found a way to do it. Now when I try to launch Firedragon it says "Your Firedragon profile cannot be loaded. It may be missing or inaccessible".
I got Firedragon to load after deleting the .config folder. I still don't see Bing as a search option in settings.
I fixed it by deleting the .config file, and there's still no option to add Bing in settings. I went to bing.com and right-clicked in the url bar and the search bar in the midde and neither one had a right-click drop-down option for "Add Bing".
SGS
April 21, 2022, 11:28pm
6
Find more or use restore button.
Read and edit your posts, please
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
system
Closed
April 23, 2022, 11:29pm
7
