I recently changed my chromebook os to Garuda KDE Dr460nized gaming edition, but when I open an application or a tab it lags and when I use the laptop when it is charging it gets very hot. i have the chromebook: chromebook 14a-na0170nd, does anyone know how to fix this?
Welcome to Garuda.
Please post the output of:
â•─linux@linux in ~
╰─λ garuda-inxi
Kernel: 5.19.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=944050d3-9deb-483c-8963-646a77cd97e4 rw rootflags=subvol=@
Type: Laptop System: Google product: Blooglet v: rev4
Mobo: HP model: Blooglet v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 33.1 Wh (79.6%) condition: 41.6/47.4 Wh (87.9%)
volts: 8.0 min: 7.7 model: 333-1D- GH02047 type: Li-ion serial: <filter>
status: discharging cycles: 30
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x20
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1449 high: 1804 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1095 2: 1804
bogomips: 4377
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0380
Device-2: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 30c9:0016 class-ID: 0e02
Monitor-1: eDP-1 model: LG Display 0x060f built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.19.2-zen1-2-zen running: yes
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Local Storage: total: 58.31 GiB used: 8.84 GiB (15.2%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Kingston model: TA2964
size: 58.31 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: MBR
ID-1: / raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.19 GiB (22.4%)
fs: btrfs dev: /dev/mmcblk0p2 maj-min: 179:2
ID-2: /boot/efi raw-size: 9.77 GiB size: 9.76 GiB (99.90%) used: 624 KiB
(0.0%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
ID-3: /home raw-size: 29.01 GiB size: 29.01 GiB (100.00%) used: 94.3 MiB
(0.3%) fs: btrfs dev: /dev/mmcblk0p4 maj-min: 179:4
ID-4: /usr raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 6.56 GiB
(67.2%) fs: btrfs dev: /dev/mmcblk0p3 maj-min: 179:3
ID-5: /var/log raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.19 GiB
(22.4%) fs: btrfs dev: /dev/mmcblk0p2 maj-min: 179:2
ID-6: /var/tmp raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.19 GiB
ID-1: swap-1 type: zram size: 3.7 GiB used: 644.9 MiB (17.0%)
System Temperatures: cpu: 75.0 C mobo: N/A
Processes: 223 Uptime: 13h 8m wakeups: 11779 Memory: 3.7 GiB used: 2.29 GiB
(62.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1174 lib: 304 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-09-03
Last full system update: 2022-09-04 ↻
First of all, reboot, as indicated by this symbol
The problem in my opinion is due to the week performance of the machine
This is even below our suggested requirenents.
Ideally, you should consider a lighter edition.
Maybe you could try checking in the Garuda Assistant if the performance tweaks are on and remove them, moving to a more “conservative” configuration…
But this is the Minimum requirements
- 30 GB storage space
- 4 GB RAM
- Video card with OpenGL 3.3 or better
- 64-bit system
And i have this
| Product name | HP Chromebook 14a-na0142nd |
| Microprocessor | Intel® Celeron® N4020 (1.1 GHz base frequency, up to 2.8 GHz burst frequency, 4 MB L2 cache, 2 cores) |
| Chipset | Intel® Integrated SoC |
| Memory, standard | 4 GB LPDDR4-2400 SDRAM (onboard) |
| Video graphics | Intel® UHD Graphics 600 |
| Hard drive | 64 GB eMMC |
I have met the minimum requirements
Yes, sure, otherwise the installer would stop you.
There is no formula to determine hw requirenents and you can only define minimum indications.
And this depends on a combination of factors.
Consider that a part of RAM is taken by the GPU, and see that you're already using a lot of that. Probably with not many applications in use.
The CPU is probably working a lot due to that, and a more performing one would have helped. So the CPU temperature goes high.
Even more if you are using performance tweaks. Probably not.
Anyway a configuration aimed to power saving would relief the CPU workload.
How do I turn on power saving and why does the laptop lag when I open an application.
Open Garuda Assistant and check the options (I can't help more at the moment).
The reason for the lag (in my opinion) is the explanation above.
do you know other operating systems that I can put on it and use without lag?
There are so many. Probably too many. It depends on your preferences.
Prepare a USB Key with Ventoy, so you'll simply copy there all the ISO files.
Start from some light Garuda editions, check on the web sites. I don't know, if you are not accostumed with tiling window managers, go e.g. for the xfce, cinnamon or lxqt editions.
Try them all on the USB. When you decide which one you prefer, install it, and check the performance.
Outside Garuda, maybe Linux Mint or MX Linux. But there are dozens...
Open htop and check if your CPU% is running high at idle.
Do anyone know how to make a boot able USB, because I tried to make on but it doesn't work. i want the os Garuda LXQT-Kwin.
Use ventoy then just add your iso
Can i get a .exe file, because i want to make a bootable usb on a windows pc.
yes ventoy works on windows (woogle is your friend)
i dont know why, but my pc doesn't detect the usb. can i use rufus too.
yes you can but if ventoy is not seeing the usb then you will need to format it
yes, but i cant the pc doesn't detect the usb.
i didn't know how to use that. I installed USB Disk Storage Format Tool 6.1, but it says the storage cannot be detected
