I think you need to google now and read up on how to format a drive
Why did you seperate /usr?
I would recommend qtile if you would like to stay with Garuda Linux distro.. on my laptop on start up 600mb used and less then 1% core usage...
And I must say it's a beautifully done.. shout out to whomever did it...
idk, my brother says i must to do that.
This might be worth a shot, or Sway which is also very well done.
It cannot be overstated how limited this processor is. Around 2012 the average person was carrying a smartphone with a more powerful processor than this.
But I'm going to change OS now which garuda OS can you recommend to me. I would prefer a garuda OS.
Garuda Sway, Garuda i3wm, Garuda Qtile ...
check them.
and I have another question my brother has Garuda KDE Dr460nized, but the headphone jack does not work. How can he fix that?
Ask your brother to ask the question in another thread
can connect Garuda Wayfire to the internet because I just tried that but I can't find anywhere to connect to the internet.
Garuda Wayfire is a bad choice for this hardware.
Please, if you have a new issue you need to open a new topic. In your new topic, follow the template with a new garuda-inxi
, carefully explain the problem, and elaborate on troubleshooting efforts you have made so far.
This topic is not about establishing a network connection on Garuda Wayfire, and it is definitely not about troubleshooting your brother's headphone jack. One issue per topic, please.
agree, it is a super “low power” cpu … with erm no power to calculate stuff ^^
If I recall correctly seperating /usr is not relevant for home PCs for something like 20 years. /usr seperation will give you no benefit and may make booting harder. You have also seperated /home, if you eant to reinstall while preserving files /home seperation is sensible.
