I have been having two issues with my computer lately.
My first issue is that my web browser is putting me a day ahead despite my calendar saying otherwise. I've tried tinkering the settings but to no avail.
The next problem is that sometimes after a soft reboot, whenever I open something, the screen becomes black and gray with glitched icons appearing right aside it. I'm unsure if this is a graphics card issue or an issue with the OS and would like to know.
My specs
ial: <superuser required> UEFI: American Megatrends v: N.1.06
date: 04/09/2020
ID-1: BAT0 charge: 14.5 Wh (32.9%) condition: 44.1/62.3 Wh (70.7%)
volts: 14.0 min: 15.2 model: standard type: Li-ion serial: <filter>
status: Discharging
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3370 high: 3849 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 3467 2: 3220 3: 3401
4: 3403 5: 3401 6: 3400 7: 2601 8: 3284 9: 3541 10: 3849 11: 3044
12: 3494 13: 3201 14: 3719 15: 3530 16: 3370 bogomips: 73625
Device-1: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Tongfang Hongkong Limited driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e91
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:6
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3839x1080 s-dpi: 144 s-size: 678x191mm (26.7x7.5")
s-diag: 704mm (27.7")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: DP-4 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2070 Super/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Tongfang Hongkong Limited
Device-2: NVIDIA TU104 HD Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8
Sound Server-1: ALSA v: k5.15.10-hardened1-1-hardened running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: 3000
bus-ID: 3d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp61s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 3e:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp62s0 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 931.51 GiB used: 166.69 GiB (17.9%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 32.9 C scheme: GPT
ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
used: 166.69 GiB (17.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%)
System Temperatures: cpu: 52.0 C pch: 55.0 C mobo: N/A gpu: nvidia
temp: 49 C
Processes: 346 Uptime: 10m wakeups: 3 Memory: 15.54 GiB
used: 2.82 GiB (18.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1725 lib: 504 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
