Garuda noob here, coming from Ubuntu.
Fresh install just fine. Problem arises after attempting to auto install proprietary drivers for my GPU(s). It's a hybrid setup as detailed below. Would greatly appreciate any advice as to how this can be done. I must say this sticking point has derailed an otherwise great OS.
System: Kernel: 5.13.4-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=bc0b687e-5e39-45ac-bcfd-cb16cc7c756c rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=13966a07-dceb-435a-a097-312cfea0e209 loglevel=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Mini-pc System: Intel Client Systems product: NUC11PHi7 v: M26149-402 serial: <filter>
Chassis: Intel Corporation type: 35 v: 2.0 serial: <filter>
Mobo: Intel model: NUC11PHBi7 v: M26151-402 serial: <filter> UEFI: Intel
v: PHTGL579.0062.2021.0430.1451 date: 04/30/2021
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP arch: Tiger Lake family: 6
model-id: 8C (140) stepping: 1 microcode: 88 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44851
Speed: 846 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 846 2: 2285 3: 3678 4: 3619 5: 3599 6: 4163
7: 4244 8: 3008
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Intel driver: nouveau v: kernel
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: intel,modesetting,nouveau
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 dpi: 77 size: 632x360mm (24.9x14.2") diag: 727mm (28.6")
OpenGL: renderer: NV166 v: 4.3 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Intel driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-zen2-1-zen running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3 chip-ID: 8086:a0f0
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I225-LM driver: igc v: kernel port: 3000 bus-ID: 59:00.0 chip-ID: 8086:15f2
IF: enp89s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0026
Drives: Local Storage: total: 465.76 GiB used: 9.6 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
Partition: ID-1: / raw-size: 431.37 GiB size: 431.37 GiB (100.00%) used: 9.6 GiB (2.2%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 431.37 GiB size: 431.37 GiB (100.00%) used: 9.6 GiB (2.2%) fs: btrfs
ID-4: /var/log raw-size: 431.37 GiB size: 431.37 GiB (100.00%) used: 9.6 GiB (2.2%) fs: btrfs
ID-5: /var/tmp raw-size: 431.37 GiB size: 431.37 GiB (100.00%) used: 9.6 GiB (2.2%) fs: btrfs
ID-1: swap-1 type: partition size: 34.13 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Info: Processes: 271 Uptime: 24m wakeups: 0 Memory: 31.03 GiB used: 3.56 GiB (11.5%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1126 lib: 289 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
I really hope to get this sorted and fully experience Garuda! Thanks in advance.
