Hello Garuda users.
HDMI works on various other Linux installs using kernels 5.19. I verified this issue is not because of Zen.
╭─mickleby@mickleby in ~ took 7ms
╰─λ mhwd-kernel -li
Currently running: 6.2.10-zen1-1-zen (linux-zen)
The following kernels are installed in your system:
local/linux-lts 6.1.23-1
local/linux-zen 6.2.10.zen1-1
╭─mickleby@mickleby in ~ took 51ms
╰─λ
╭─mickleby@mickleby in ~ took 9ms
╰─λ pactl list short sinks
64 bluez_output.54_15_89_07_49_A4.1 PipeWire s16le 2ch 48000Hz RUNNING
444 alsa_output.platform-snd_aloop.0.3.analog-stereo PipeWire s32le 2ch 48000Hz SUSPENDED
446 alsa_output.pci-0000_00_1f.3.3.analog-stereo PipeWire s32le 2ch 48000Hz SUSPENDED
╭─mickleby@mickleby in ~ took 10ms
╭─mickleby@mickleby in ~ took 5ms
╰─λ pactl list cards | grep -A 2 Card
Card #63
Driver: module-bluez5-device.c
Card #434
Driver: alsa
Card #435
Driver: alsa
╰─λ
But HDMI is an output option for the internal sound card, #435, /devices/pci0000:00/0000:00:1f.3/sound/card1 as we can see from this (edited)
(edited)
Card #435
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA Intel PCH at 0x6001120000 irq 141"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3"
device.description = "Built-in Audio"
device.enum.api = "udev"
device.form_factor = "internal"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "3820109"
device.product.id = "0x51c8"
device.product.name = "Alder Lake PCH-P High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card1"
device.vendor.id = "0x8086"
device.vendor.name = "Intel Corporation"
media.class = "Audio/Device"
factory.id = "14"
client.id = "34"
object.id = "48"
object.serial = "435"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0x6001120000 irq 141"
alsa.driver_name = "snd_hda_intel"
device.string = "1"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + AnalogStereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + AnalogStereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + AnalogStereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
pro-audio: Pro Audio (sinks: 5, sources: 2, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
port.availability-group = "Legacy 1"
device.icon_name = "audio-input-microphone"
card.profile.port = "0"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo,output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, available)
Properties:
port.type = "mic"
port.availability-group = "Legacy 2"
card.profile.port = "1"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availabilitygroup: Legacy 3, not available)
Properties:
port.type = "line"
port.availability-group = "Legacy 3"
card.profile.port = "2"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, available)
Properties:
port.type = "line"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 5"
device.icon_name = "audio-headphones"
card.profile.port = "4"
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 6, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
device.icon_name = "video-display"
card.profile.port = "5"
device.product.name = "LG TV"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 7, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 7"
card.profile.port = "6"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 8, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 8"
card.profile.port = "7"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 9, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 9"
card.profile.port = "8"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
╭─mickleby@mickleby in ~ took 20ms
Being an Arch n00b I’m reluctant to build 5.19 kernel myself, but I think this is an obvious and simple “razor” to apply. I’ll see what I can do on this front.
I don’t yet see how to query Alan to learn if he found resolution. I believe it’s the same as this unresolved issue Alan reported:
╰─λ
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e3932b26-e146-46da-9d7d-65804c9d90ad rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: AZW product: SEi v: N/A serial: <superuser required>
Mobo: AZW model: SEi serial: <superuser required> UEFI: American
Megatrends LLC. v: ALDER109 date: 12/01/2022
Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room Keyboard
K830 serial: <filter> charge: 100% (should be ignored) rechargeable: yes
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x429
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1753 high: 2500 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 2500 3: 758 4: 695
5: 698 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 794 12: 2500
bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) TV
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 1836mm (72.3") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 2-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 9.43 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 type: SSD serial: <filter> rev: V3MA002 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 38.67 GiB size: 38.67 GiB (100.00%) used: 9.39 GiB (24.3%)
used: 35.3 MiB (36.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
used: 9.39 GiB (24.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
ID-5: /var/tmp raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.39 GiB used: 768 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A
Processes: 317 Uptime: 7m wakeups: 2 Memory: 15.39 GiB
used: 3.82 GiB (24.8%) Init: systemd v: 253 default: graphical
pkgs: 1420 libs: 351 tools: gnome-software,octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-04-09
Last full system update: 2023-04-10
– mickleby
//Edit: moved a paragraph for clarity
