Hello Garuda Team,
when i plugged earphone in audio jack , sound comes from both inbuilt speaker and earphone both. But in windows it is working fine.
why this issue is happening ?
Kindly help me.
root=UUID=6b6fa549-88e4-4b89-8c1f-4caffe56dbe3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 83BF v: IdeaPad Slim 5 14IAH8
serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 5 14IAH8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
serial: <superuser required> UEFI: LENOVO v: LACN25WW date: 05/25/2023
ID-1: BAT1 charge: 34.6 Wh (60.5%) condition: 57.2/56.6 Wh (101.0%)
power: 14.4 W volts: 11.5 min: 11.5 model: LGES L22L3PA4 type: Unknown
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x42C
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1824 high: 4218 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 649 2: 1515 3: 400 4: 400
5: 4130 6: 4218 7: 1742 8: 400 9: 2245 10: 2774 11: 400 12: 3024
bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a3
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 04f2:b7b9
Monitor-1: eDP-1 res: 1280x800 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 14.99 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a3 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 0bda:4853
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 8.58 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPMQD-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73110001 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 8.55 GiB (14.2%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 35.9 MiB (37.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 60 GiB size: 60 GiB (100.00%) used: 8.55 GiB (14.2%)
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 8.55 GiB (14.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 322 Uptime: 3m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.35 GiB used: 5.12 GiB (33.4%) Init: systemd v: 254
pm: pacman pkgs: 1392 libs: 409 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-1):
System install date: 2023-11-12
Last full system update: 2023-11-12
Not sure but this may have some advice:
[Solved]: WirePlumber doesn't auto-mute alsa / Applications & Desktop Environments / Arch Linux Forums
Quotes from there:
It looks like you chose the “pro” profile for your card. I’d suggest you try to set it to the normal “analog stereo duplex” with pavucontrol. The pro profile might disable things like autodetect, hardware volume control and so on and give direct access to all ports to audio software.
would be the first thing to check.
edit: scrap the amixer
thing, I’d keep that as last resort and look into wireplumber configuration instead (if the above is not the problem)
how to set it to normal profile
when i connect earphone , sound output come from both speaker and earphone.
pls help
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
ID-1: BAT1 charge: 39.9 Wh (69.8%) condition: 57.2/56.6 Wh (101.0%)
power: 9.2 W volts: 12.1 min: 11.5 model: LGES L22L3PA42 type: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
microcode: 0x430
Speed (MHz): avg: 611 high: 1109 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 663 2: 400 3: 400 4: 400
5: 808 6: 400 7: 400 8: 1109 9: 961 10: 400 11: 996 12: 400
bogomips: 59904
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 04f2:b7b9
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 7 state: up address: <filter> bt-v: 5.3
Local Storage: total: 476.94 GiB used: 45.48 GiB (9.5%)
fw-rev: 73110001 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 13.35 GiB (22.3%)
used: 13.35 GiB (22.3%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: zram size: 15.35 GiB used: 4 MiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 346 Uptime: 9h 3m wakeups: 4 Memory: total: 16 GiB note: est.
available: 15.35 GiB used: 9.61 GiB (62.6%) Init: systemd v: 254
pm: pacman pkgs: 1410 libs: 411 tools: octopi,pamac,paru Shell: fish
Garuda (2.6.19-2):
Last full system update: 2023-11-22 ↻
harshjeet:
2023-11-22 ↻
Please reboot the system ,
and you should be able to monitor sound output easily by selecting the device and desirable settings :
Not showing anything
@Straight
In windows it is working fine
I am sorry for creating multiple thread on same topic
But pls help
I am getting sound output from both speaker and the headphone jack
Kayo
22 November 2023 12:49
8
Click on the speaker icon on your top bar in plasma. It should bring up a GUI from @Straight ’s post:
Straight:
Click the hamburger icon next to the audio device you want sound from (red arrow in the picture points to it). Click then on “play all audio via this device”. There might be other options in there that could help as well (all depends on the device what it has for options).
There is no any option like this
I send u ss
Pls check
Kayo
22 November 2023 14:46
10
There is, from clicking on sound icon from plasma’s system tray.
If you are missing a system tray in Plasma, add one.
this is what it is showing in system tray
Kayo
22 November 2023 14:52
12
Good. Now follow prior suggestions related to that menu.
but nothing is showing as you instruct
i plugged the earphone but there is nothing showing the option like headphone
Kayo
22 November 2023 14:54
15
check for options for speaker then. there could be additional modes for the inbuilt audio
and this is option for microphone
i don’t know why it is not recognizing the headphone
Kayo
22 November 2023 14:57
18
There might be an issue with the hardware switch on that model of Laptop when it comes to Linux. I’ve tried looking into this earlier, but came up with nothing. Your search might be more fruitful though.
so what should i have to do now
in ubuntu sometimes it works sometimes it doesn’t
