Having audio jack issue
If it works only sometimes, it might be a connection or hardware fault even. An unsecured connection could explain why it would be trying to play from both. I would try different stereo pin headphones for troubleshooting purposes as well.
I would search more for your model in regards to in-built audio on Linux (you might be more lucky with this as I seemed to hit a dead end).
yes please search for my model
lenovo ideapad slim 5 ( intel 12th gen 12450h + 16gb ram , UHD graphics)
There is a BIOS update from October for that model. Worth a shot to see if that helps any.
it updated recently
Hi
i have updated my bios
but nothing changed.
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8ab62b3f-bd15-4415-aedf-a4c675252eea rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 83BF v: IdeaPad Slim 5 14IAH8
serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 5 14IAH8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
serial: <superuser required> UEFI: LENOVO v: LACN29WW date: 09/01/2023
ID-1: BAT1 charge: 57.1 Wh (99.8%) condition: 57.2/56.6 Wh (101.0%)
power: 3.5 W volts: 13.2 min: 11.5 model: LGES L22L3PA4 type: Unknown
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x430
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 606 high: 890 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 443 2: 761 3: 761 4: 400
5: 668 6: 890 7: 661 8: 622 9: 405 10: 861 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a3
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 04f2:b7b9
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1457 built: 2022 res: 1920x1200
hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 1920x1200
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 14.99 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a3 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:4853
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 11.24 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPMQD-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73110001 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 11.21 GiB (12.5%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 35.9 MiB (37.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%)
used: 11.21 GiB (12.5%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%)
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 326 Uptime: 2m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.35 GiB used: 3.94 GiB (25.7%) Init: systemd v: 254
pm: pacman pkgs: 1419 libs: 413 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-23
Last full system update: 2023-11-23
Failed units:            systemd-vconsole-setup.service
Pls help
as i am not able to work on this os properly.
Im 99% sure this is a configuration issue and can be solved by some tweaking ,as mentioned at old arch forums post —> referring to this one
yes
actually i reinstall it today
initially it was working fine
but when it got system update means after installing it is asking for update
i update it
then it all happen
Just revert back to an older snapshot (before the last update) , few days and maybe another update will fix this .
sry, i didn’t took the snapshot
yes it is configuration issue
pls help me as i am not able to operate this os properly
Please do not post here in the forum, like in chat forums like Telegram.
As long as no one has responded to your post, you can edit your post.
i am sorry
will follow the decorum
