surfr
31 October 2023 16:46
1
This is a continuation of Changing Default Kernel which is locked…
I want to run the linux-clear kernel and after tinkering a bunch I believe the best way to make it the default kernel is to add
GRUB_TOP_LEVEL="/boot/vmlinuz-linux-clear"
into /etc/default/grub. Adjust the kernel name to whichever you choose…
filo
31 October 2023 16:54
2
Thanks for sharing this, I was not aware of this (relatively new) possibility.
And I see a confirmation here from a person I fully trust
General system
Applications
The latest grub update introduces new options, to explicitly select an entry of the installation (among linux, linux-lts, linux-zen etc) being at the top level of the menu. In case you use submenus, the selected entry is the one in the front/main...
Reading time: 1 mins 🕑
Likes: 21 ❤
Ops, and in the Arch Wiki. My bad!
https://wiki.archlinux.org/title/GRUB#Setting_the_top-level_menu_entry
excellent.
thank you very much for this info.
EDIT: functionality report:
i had selected a specific kernel within Garuda’s boot options GUI, so i changed it back to the default ‘Garuda’, applied the changes there and then followed the instructions in Filo’s link so my etc/default/grub looks like this:
# GRUB boot loader configuration
GRUB_TOP_LEVEL="/boot/vmlinuz-linux-lts"
GRUB_DEFAULT="0"
GRUB_TIMEOUT=3
GRUB_DISTRIBUTOR="Garuda"
i then ran
sudo grub-mkconfig -o /boot/grub/grub.cfg
and
sudo update-grub
i then rebooted my system and it worked perfectly, the LTS is now selected as my default kernel.
thanks again to Surfr and Filo.
@petsam wrote such a guide for us as well back in November 2022:
The latest grub update introduces a new feature , to explicitly select an entry of the installation (among linux, linux-lts, linux-zen, etc.) being at the top level of the menu. In case you use submenus, the selected entry is the one in the front/main page, while it is also at the top in the Advanced menu entries page.
A user may wish to use an image that is not sorted as the "latest" version as the top-level entry. For example, in Arch Linux, if a user has the LTS and regular kernels installed…
At the time it was temporarily unlisted because we were shipping a frozen version of Grub (remember that whole Grub fiasco where so many systems could not boot?), and our version did not have the new feature. But I think no one ever remembered to relist it!
surfr
1 November 2023 02:17
5
Michael_joseph:
sudo update-grub
Is this necessary in this case? It works for me without… But probably doesn’t hurt either.
It is not necessary to do both like this:
These two commands do the same thing; running either one or the other is sufficient.
i didn’t know that, but now i do!
thanks lmao
system
Closed
3 November 2023 12:33
8
