Grub gone after power outage while coping files
had power outage, laptop never shut down. Rebooted
Used Garuda-USB, tried to repair grub, failed. Read a lot of forums post tried all. Somehow restored the previous snapshot, not sure what I am doing.
My guess is the Grub is corrupt or some how missing. Tried to use the repair tool but not sure which options to use.
When I reboot laptop, the only boot option in bios is for windows.
2 SSD in laptop, one was for windows (came with laptop) and 2nd added after to install garuda.
I had not done an update in a while and did an update hours before the power outage. There were some pacnew files I had not addressed.
100% certain I am not doing anything correctly. Really tired but really need to get system working by morning.
I am sure the answers is in one of these forums but can’t spend more time trying to understand. Have mercy on me.
I assume I just need information of which option to pick for grub repair / boot repair
Kernel: 6.6.72-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/.snapshots/304/snapshot/boot/vmlinuz-linux-lts
root=UUID=0eb11c94-d361-4490-9a56-8399da90c616 quiet loglevel=3 ibt=off
rootflags=defaults,noatime,compress=zstd,subvol=@/.snapshots/304/snapshot
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Convertible System: SAMSUNG product: 950QDB v: P11AKG serial: <filter>
Chassis: type: 31 serial: <filter>
Mobo: SAMSUNG model: NP950QDB-KB3US
v: SGLB153A0D-C01-G001-S0001+10.0.22000 serial: <filter>
part-nu: SCAI-A5A5-A5A5-TGL3-PAKG
uuid: b9878300-1439-11ec-8587-7a21e46c1a00 UEFI: American Megatrends LLC.
v: P11AKG.027.231017.MK date: 10/17/2023
ID-1: BAT1 charge: 37.0 Wh (60.1%) condition: 61.6/66.8 Wh (92.2%)
volts: 15.1 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: discharging cycles: 247
Info: model: 11th Gen Intel Core i7-1165G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xB8
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4700 base/boost: 2800/4700 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
bogomips: 44864
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Samsung Co
driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Generic 720p HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:6 chip-ID: 2b7e:0171
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: Samsung 0x4159 built: 2020 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 7.47 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu
name: Intel Iris Xe Graphics (TGL GT2) driver: N/A device-ID: 8086:9a49
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Samsung Co
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.72-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 2d:00.0
IF: wlp45s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:9 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 2.98 TiB used: 1.45 TiB (48.8%)
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: MZVLQ1T0HBLB-00B
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7AK1Q temp: 29.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 46.9 MiB (18.3%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:3
ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.45 TiB (79.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:1
ID-4: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 259:1
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 39.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Memory: total: 16 GiB note: est. available: 15.3 GiB used: 7.03 GiB (45.9%)
igpu: 64 MiB
Processes: 313 Power: uptime: 21m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2187 libs: 587 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
System install date:     2024-05-06
Last full system update: 2025-01-24
Windows dual boot:       Yes
Failed units:            snapper-cleanup.service systemd-remount-fs.service
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda           8:0    1 232.9G  0 disk
├─sda1        8:1    1 232.8G  0 part
└─sda2        8:2    1    32M  0 part
sdb           8:16   1     0B  0 disk
zram0       253:0    0  15.3G  0 disk [SWAP]
nvme0n1     259:0    0   1.8T  0 disk
└─nvme0n1p1 259:1    0   1.8T  0 part /run/snapper-tools-IpUWwb
/var/tmp
/var/log
/var/cache
/srv
/root
/home
nvme1n1     259:2    0 953.9G  0 disk
├─nvme1n1p1 259:3    0   260M  0 part /boot/efi
├─nvme1n1p2 259:4    0    16M  0 part
├─nvme1n1p3 259:5    0 468.8G  0 part
├─nvme1n1p4 259:6    0 469.6G  0 part
├─nvme1n1p5 259:7    0  14.2G  0 part
└─nvme1n1p6 259:8    0     1G  0 part
Try chrooting and reinstalling the GRUB. Like here:
Tried that a few hours ago not sure what to mount for `sudo mount /dev/sdxy /mnt
lsblk
loop0         7:0    0  16.8M  1 loop /run/miso/sfs/livefs
loop1         7:1    0 357.7M  1 loop /run/miso/sfs/mhwdfs
loop2         7:2    0   3.4G  1 loop /run/miso/sfs/desktopfs
loop3         7:3    0 725.8M  1 loop /run/miso/sfs/rootfs
│ └─ventoy  254:0    0   4.6G  1 dm   /run/miso/bootmnt
nvme1n1     259:0    0   1.8T  0 disk
└─nvme1n1p1 259:1    0   1.8T  0 part /run/media/garuda/0eb11c94-d361-4490-9a56-8399da90c616
nvme0n1     259:2    0 953.9G  0 disk
├─nvme0n1p1 259:3    0   260M  0 part
├─nvme0n1p2 259:4    0    16M  0 part
├─nvme0n1p3 259:5    0 468.8G  0 part
├─nvme0n1p4 259:6    0 469.6G  0 part
├─nvme0n1p5 259:7    0  14.2G  0 part
└─nvme0n1p6 259:8    0     1G  0 part
do I put nvme1n1p1?
like sudo mount /nvme1n1p1 /mnt
or
sudo mount dev/nvme1n1p1 /mnt
In /mnt/broken /dev/nvme0n1p1
In /boot/efi /dev/nvme1n1p1
I did
sudo mount nvme1n1p1 /mnt
sudo garuda-chroot /mnt/@
and I my prompt changed to
sh-5.2#
I guess I am in chroot
so my quesiton is how do I know if I am efi or legacy.
I had a windows laptop, I installed a 2nd ssd and installed Garuda on there. Again I know the answer is out there but I am exhausted.
TY for you help.
Don’t worry, you have an EFI system partition and your system is new enough for that.
But be careful, your system is /dev/nvme0n1p1 not /dev/nvme1n1p1. The latter is the EFI system partition.
I think you were telling me to do
sudo mount /dev/nvme0n1p1 /mnt/broken
sudo mount /dev/nvme1n1p1 /boot/efi
Please correct me if I am wrong.
Correct.
Just the second sudo is not needed because you’ll be in a chroot, where you’re root by default.
sh-5.2#
Ok I am i chroot and i mounted the /mnt/broken and /boot/efi
sh-5.2# lsblk
|-sda1        8:1    1 232.8G  0 part
| `-ventoy  254:0    0   4.6G  1 dm
`-sda2        8:2    1    32M  0 part
`-nvme1n1p1 259:1    0   1.8T  0 part /boot/efi
/boot/efi
|-nvme0n1p1 259:3    0   260M  0 part /mnt/broken
|-nvme0n1p2 259:4    0    16M  0 part
|-nvme0n1p3 259:5    0 468.8G  0 part
|-nvme0n1p4 259:6    0 469.6G  0 part
|-nvme0n1p5 259:7    0  14.2G  0 part
`-nvme0n1p6 259:8    0     1G  0 part
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=garuda --recheck
Installing for x86_64-efi platform.
grub-install: error: /boot/efi doesn't look like an EFI partition.
Sorry I am sure its obvious to you what I am doing wrong but this is my first time trying to repair/create grub and chrooting.
sh-5.2# ls /boot/efi
@                                    @_backup_20240808052434925         @home  @tmp
@_backup_2024-08-13T09:21:21.342Z_a  @_backup_2025-01-26T06:12:36.470Z  @log   broken
@_backup_2024-08-13T09:21:28.895Z    @_backup_20252601002557976         @root
@_backup_20240507230450020           @cache                             @srv```
This looks strange.
Are you sure there was not a typo when mounting/boot/efi?
this is the copy and paste of the command I wrote in chroot, I just went back and checked.
I tried the boot repair and other tools many times maybe I messed something up for good.
I don’t want to mess your system further, but what I would do is to reformat your EFI system partition (maybe it’s corrupt).
mkfs.fat -F32 -n EFI /dev/nvme1n1p1
You’ll probably have to use some Windows recovery tool afterwards to reinstall its bootloader as well.
I’m sorry but you have to decide.
Or maybe just wait for some other suggestions…
When I made the original post with the Garuda-inxi had somehow booted into a snapshot via the Garuda-USB
I restarted and to try other things and have been working with you in the normal garuda-usb
this is my current Garuda-inxi
sudo garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=garuda
root=miso:LABEL=GARUDA_DR460NIZEDGAMING_BIRDOFPR quiet
systemd.show_status=1 checksum=y driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
ID-1: BAT1 charge: 59.1 Wh (95.9%) condition: 61.6/66.8 Wh (92.2%)
volts: 17.3 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: charging cycles: 247
microcode: 0xAC
Speed (MHz): avg: 487 high: 1100 min/max: 400/4700 base/boost: 2800/4700
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 1100 5: 400 6: 400
7: 400 8: 400 bogomips: 44851
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Display: server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: eDP-1 model: Samsung 0x4159 built: 2020 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.94 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: MZVLQ1T0HBLB-00B
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7AK1Q temp: 37.9 C
SMART: yes health: PASSED on: 68d 4h cycles: 224
read-units: 14,704,294 [7.52 TB] written-units: 17,221,729 [8.81 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 163d 10h cycles: 223
read-units: 274,930,084 [140 TB] written-units: 59,720,456 [30.5 TB]
Src: /sys System Temperatures: cpu: 46.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.3 GiB used: 4.6 GiB (30.1%)
igpu: 64 MiB
Processes: 282 Power: uptime: 1h 4m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1846 libs: 539 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date:     2025-01-26
Last full system update: 2025-01-26 ↻
there is no information in the partition section.
Ok I don’t mind I never use windows.
I will give you a moment to read my last reply and then run your command to format my efi partition.
I think that’s a normal garuda-inxi from a live USB.
You just don’t see the partitions there.
Ok I ran the command
mkfs.fat 4.2 (2021-01-31)
mkfs.fat: /dev/nvme1n1p1 contains a mounted filesystem.
umount/boot/efi
Ok I still can’t format
I even typed exit to get out of chroot
when i am just in as my user I get this
╰─λ lsblk
└─nvme1n1p1 259:1    0   1.8T  0 part /mnt/@
/mnt
├─nvme0n1p1 259:3    0   260M  0 part /mnt/@/mnt/broken
│                                     /mnt/@/mnt/broken
│                                     /mnt/broken
