garuda-inxi:
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: PCSpecialist product: Atlas Elite v: N/A
Mobo: ASUSTeK model: PRIME B660-PLUS D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2212
date: 12/13/2022
Info: model: 13th Gen Intel Core i5-13600KF bits: 64 type: MST AMCP
microcode: 0x10E
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 3839 high: 5100 min/max: 800/3841:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 5100 2: 3500 3: 3500
4: 3500 5: 5100 6: 3500 7: 5100 8: 3500 9: 3500 10: 3500 11: 5100
12: 3500 13: 3897 14: 3500 15: 3500 16: 3500 17: 3500 18: 3500 19: 3500
20: 3500 bogomips: 139776
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2488 class-ID: 0300
Screen-1: 0 s-res: 3440x1440 s-dpi: 106 s-size: 824x342mm (32.44x13.46")
s-diag: 892mm (35.12")
Monitor-1: DP-2 res: 3440x1440 hz: 100 dpi: 107
size: 820x346mm (32.28x13.62") diag: 890mm (35.04") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1-10.1:7 v: kernel alternate: snd_sof_pci_intel_tgl
chip-ID: 046d:0aba bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:7ad0
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Logitech PRO X Wireless Gaming Headset type: USB
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-11:6 chip-ID: 8087:0029 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 945.83 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: swap-1 type: zram size: 15.43 GiB used: 1.76 GiB (11.4%)
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 46 C
Processes: 353 Uptime: 10m wakeups: 0 Memory: 15.44 GiB used: 5.19 GiB
(33.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1194 libs: 295
Garuda (2.6.8-1):
System install date: 2023-07-04
Last full system update: 2023-07-04 ā»
I'm stuck at grub rescue with the error efi_wrap_1 not found after a system update failed and rollback to snapshot.
I found Grub fails after update - #3 by librewish which looks like it might be the solution, but it fails:
mkdir: cannot create directory ā/mntā: File exists
mount: /mnt: special device /dev/sdxy does not exist. -> sda sda1 sda2 exist, but not sdxy
Anyone point me in the right direction? Have I identified this ttps://forum.garudalinux.org/t/grub-fails-after-update/78/3 is the solution correctly?
