I can not go into even get GRUB at all. GRUB Does NOT even show after selecting to boot. If I choose it to boot manually also it restarts and I end up at MSI BIOS page. It is shown in my MSI BIOS as Garuda like usual No change. It is the primary bootloader. The think happened after some major update around 27 August 2022.
I run dual boot with Win 10 on same disk. But the thing is I have not even started Windows 10 AT ALL for atleast 30 days. I didn't update BIOS also before the problem or anything that can remotely affect it. Turned off my pc as regular and now even GRUB gone. So it definitely has to do with some Grub update or some update or gaurda-update.
I can boot into live USB drive and try all the GRUB boot repairs from GUI of Boot repairs but nothing seems to repair the GRUB. also detecting the EFI bootloader at initial GRUB Page from USB does detect it but choosing it again causes restart it into BIOS.
Older garuda-inxi(can not boot now obviously)
Please help my entire system is broken!!!!!!!
Thank you to everyone for reading and helping!!
Kernel: 5.18.11-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.1.0 parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
root=UUID=10b3e5d1-0274-4dc2-aaa2-ae6daa1710d0 rw rootflags=subvol=@
loglevel=3 amdgpu.dc=0
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH (MS-7A38) v: 4.0
serial: <filter> UEFI: American Megatrends v: M.C0
Info: model: AMD Ryzen 5 1600 socket: AM4 bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3343 high: 3400 min/max: N/A base/boost: 3400/3700
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 2721 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
bogomips: 81626
vendor: Sapphire driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2 bus-ID: 29:00.0
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S22E360
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.46 5.18.11-hardened1-1-hardened)
v: 4.6 Mesa 22.1.3 direct render: Yes
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 29:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.18.11-hardened1-1-hardened running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-9:2 chip-ID: 0a12:0001 class-ID: e001
address: <filter>
Local Storage: total: 1.36 TiB used: 56.25 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR010
temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 316d 2h cycles: 3,357
read-units: 46,447,210 [23.7 TB] written-units: 40,472,303 [20.7 TB]
model: WD10EZEX-00MFCA0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A01 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 322d 21h cycles: 3406
ID-1: / raw-size: 375.53 GiB size: 375.53 GiB (100.00%)
used: 56.22 GiB (15.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 25.5 MiB (26.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 375.53 GiB size: 375.53 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 375.53 GiB size: 375.53 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 375.53 GiB size: 375.53 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1682
Processes: 331 Uptime: 1m wakeups: 0 Memory: 15.58 GiB
used: 2.08 GiB (13.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1721
lib: 430 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-05-25
Last full system update: 2022-07-18
Windows dual boot: Yes
Failed units: dev-binderfs.mount anbox-container-manager.service
