Hi. Whenever I try to get into a game on GGST my graphics card resets.
I’ll be honest, I’ve 0 idea how to start or who to tell.
Here’s the output of running dmesg grep amdgpu. It clearly shows a crash but I cant seem to find the dump it talks about.
[ 9.211369] [drm] amdgpu kernel modesetting enabled.
[ 9.211384] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 9.211500] amdgpu: ATPX version 1, functions 0x00000000
[ 9.214588] amdgpu: Virtual CRAT table created for CPU
[ 9.214594] amdgpu: Topology: Add CPU node
[ 9.214610] amdgpu: Overdrive is enabled, please disable it before reporting any bugs unrelated to overdrive.
[ 9.215278] amdgpu 0000:03:00.0: enabling device (0006 -> 0007)
[ 9.215312] amdgpu 0000:03:00.0: amdgpu: initializing kernel modesetting (IP DISCOVERY 0x1002:0x7550 0x1043:0x0613 0xC0).
[ 9.215322] amdgpu 0000:03:00.0: amdgpu: register mmio base: 0xF6D00000
[ 9.215323] amdgpu 0000:03:00.0: amdgpu: register mmio size: 524288
[ 9.222249] amdgpu 0000:03:00.0: amdgpu: detected ip block number 0 <common_v1_0_0> (soc24_common)
[ 9.222251] amdgpu 0000:03:00.0: amdgpu: detected ip block number 1 <gmc_v12_0_0> (gmc_v12_0)
[ 9.222252] amdgpu 0000:03:00.0: amdgpu: detected ip block number 2 <ih_v7_0_0> (ih_v7_0)
[ 9.222253] amdgpu 0000:03:00.0: amdgpu: detected ip block number 3 <psp_v14_0_0> (psp)
[ 9.222254] amdgpu 0000:03:00.0: amdgpu: detected ip block number 4 <smu_v14_0_0> (smu)
[ 9.222254] amdgpu 0000:03:00.0: amdgpu: detected ip block number 5 <dce_v1_0_0> (dm)
[ 9.222255] amdgpu 0000:03:00.0: amdgpu: detected ip block number 6 <gfx_v12_0_0> (gfx_v12_0)
[ 9.222256] amdgpu 0000:03:00.0: amdgpu: detected ip block number 7 <sdma_v7_0_0> (sdma_v7_0)
[ 9.222257] amdgpu 0000:03:00.0: amdgpu: detected ip block number 8 <vcn_v5_0_0> (vcn_v5_0_0)
[ 9.222258] amdgpu 0000:03:00.0: amdgpu: detected ip block number 9 <jpeg_v5_0_0> (jpeg_v5_0_0)
[ 9.222259] amdgpu 0000:03:00.0: amdgpu: detected ip block number 10 <mes_v12_0_0> (mes_v12_0)
[ 9.222268] amdgpu 0000:03:00.0: amdgpu: Fetched VBIOS from VFCT
[ 9.222269] amdgpu: ATOM BIOS: 115-G295BP00-100
[ 9.312622] amdgpu 0000:03:00.0: vgaarb: deactivate vga console
[ 9.312624] amdgpu 0000:03:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 9.313648] amdgpu 0000:03:00.0: amdgpu: MEM ECC is not presented.
[ 9.313649] amdgpu 0000:03:00.0: amdgpu: SRAM ECC is not presented.
[ 9.313679] amdgpu 0000:03:00.0: amdgpu: vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 9.313683] amdgpu 0000:03:00.0: amdgpu: VRAM: 16304M 0x0000008000000000 - 0x00000083FAFFFFFF (16304M used)
[ 9.313685] amdgpu 0000:03:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 9.313735] amdgpu 0000:03:00.0: amdgpu: amdgpu: 16304M of VRAM memory ready
[ 9.313736] amdgpu 0000:03:00.0: amdgpu: amdgpu: 15589M of GTT memory ready.
[ 9.313788] amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
[ 9.314057] amdgpu 0000:03:00.0: amdgpu: [drm] Loading DMUB firmware via PSP: version=0x0A000601
[ 9.314326] amdgpu 0000:03:00.0: amdgpu: [VCN instance 0] Found VCN firmware Version ENC: 1.11 DEC: 9 VEP: 0 Revision: 1
[ 17.567475] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 17.567479] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
[ 17.567505] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000032, smu fw program = 0, smu fw version = 0x00684b00 (104.75.0)
[ 17.567508] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[ 18.061493] amdgpu 0000:03:00.0: amdgpu: SMU is initialized successfully!
[ 18.134064] amdgpu 0000:03:00.0: amdgpu: [drm] Display Core v3.2.351 initialized on DCN 4.0.1
[ 18.134065] amdgpu 0000:03:00.0: amdgpu: [drm] DP-HDMI FRL PCON supported
[ 18.152055] amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000601
[ 18.558722] snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 18.574723] amdgpu 0000:03:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 20.313420] amdgpu 0000:03:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 21.000525] amdgpu 0000:03:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 21.113025] amdgpu 0000:03:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 21.113359] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
[ 21.113361] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
[ 21.115672] amdgpu 0000:03:00.0: amdgpu: MES FW version must be >= 0x82 to enable LR compute workaround.
[ 21.181882] amdgpu: HMM registered 16304MB device memory
[ 21.183257] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 21.183272] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 21.183306] amdgpu: Virtual CRAT table created for GPU
[ 21.183380] amdgpu: Topology: Add dGPU node [0x7550:0x1002]
[ 21.183381] kfd kfd: amdgpu: added device 1002:7550
[ 21.183390] amdgpu 0000:03:00.0: amdgpu: SE 4, SH per SE 2, CU per SH 8, active_cu_number 64
[ 21.183393] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 21.183394] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 21.183394] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 21.183395] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 21.183395] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 21.183396] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 9 on hub 0
[ 21.183396] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 10 on hub 0
[ 21.183397] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 21.183398] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 21.189287] amdgpu 0000:03:00.0: amdgpu: Using BACO for runtime pm
[ 21.189568] amdgpu 0000:03:00.0: [drm] Registered 4 planes with drm panic
[ 21.189569] [drm] Initialized amdgpu 3.64.0 for 0000:03:00.0 on minor 1
[ 21.243666] fbcon: amdgpudrmfb (fb0) is primary device
[ 22.227283] amdgpu 0000:03:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 22.242719] amdgpu 0000:11:00.0: enabling device (0006 -> 0007)
[ 22.242800] amdgpu 0000:11:00.0: amdgpu: initializing kernel modesetting (IP DISCOVERY 0x1002:0x13C0 0x1462:0x7E26 0xCB).
[ 22.242822] amdgpu 0000:11:00.0: amdgpu: register mmio base: 0xF6700000
[ 22.242824] amdgpu 0000:11:00.0: amdgpu: register mmio size: 524288
[ 22.244398] amdgpu 0000:11:00.0: amdgpu: detected ip block number 0 <common_v1_0_0> (nv_common)
[ 22.244401] amdgpu 0000:11:00.0: amdgpu: detected ip block number 1 <gmc_v10_0_0> (gmc_v10_0)
[ 22.244402] amdgpu 0000:11:00.0: amdgpu: detected ip block number 2 <ih_v5_0_0> (navi10_ih)
[ 22.244403] amdgpu 0000:11:00.0: amdgpu: detected ip block number 3 <psp_v13_0_0> (psp)
[ 22.244403] amdgpu 0000:11:00.0: amdgpu: detected ip block number 4 <smu_v13_0_0> (smu)
[ 22.244404] amdgpu 0000:11:00.0: amdgpu: detected ip block number 5 <dce_v1_0_0> (dm)
[ 22.244405] amdgpu 0000:11:00.0: amdgpu: detected ip block number 6 <gfx_v10_0_0> (gfx_v10_0)
[ 22.244406] amdgpu 0000:11:00.0: amdgpu: detected ip block number 7 <sdma_v5_2_0> (sdma_v5_2)
[ 22.244406] amdgpu 0000:11:00.0: amdgpu: detected ip block number 8 <vcn_v3_0_0> (vcn_v3_0)
[ 22.244407] amdgpu 0000:11:00.0: amdgpu: detected ip block number 9 <jpeg_v3_0_0> (jpeg_v3_0)
[ 22.244414] amdgpu 0000:11:00.0: amdgpu: Fetched VBIOS from VFCT
[ 22.244415] amdgpu: ATOM BIOS: 102-RAPHAEL-008
[ 22.252672] amdgpu 0000:11:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 22.252695] amdgpu 0000:11:00.0: amdgpu: vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 22.252698] amdgpu 0000:11:00.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
[ 22.252700] amdgpu 0000:11:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 22.252747] amdgpu 0000:11:00.0: amdgpu: amdgpu: 512M of VRAM memory ready
[ 22.252748] amdgpu 0000:11:00.0: amdgpu: amdgpu: 15589M of GTT memory ready.
[ 22.253090] amdgpu 0000:11:00.0: amdgpu: [drm] Loading DMUB firmware via PSP: version=0x05002C00
[ 22.253286] amdgpu 0000:11:00.0: amdgpu: [VCN instance 0] Found VCN firmware Version ENC: 1.33 DEC: 4 VEP: 0 Revision: 14
[ 22.275303] amdgpu 0000:11:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
[ 22.343794] amdgpu 0000:11:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 22.349393] amdgpu 0000:11:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 22.349395] amdgpu 0000:11:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
[ 22.350935] amdgpu 0000:11:00.0: amdgpu: SMU is initialized successfully!
[ 22.351210] amdgpu 0000:11:00.0: amdgpu: [drm] Display Core v3.2.351 initialized on DCN 3.1.5
[ 22.351211] amdgpu 0000:11:00.0: amdgpu: [drm] DP-HDMI FRL PCON supported
[ 22.351957] amdgpu 0000:11:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x05002C00
[ 22.352506] snd_hda_intel 0000:11:00.1: bound 0000:11:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 22.352882] amdgpu 0000:11:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 22.352925] amdgpu 0000:11:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 22.352980] amdgpu 0000:11:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 22.353028] amdgpu 0000:11:00.0: amdgpu: [drm] PSR support 0, DC PSR ver -1, sink PSR ver 0 DPCD caps 0x0 su_y_granularity 0
[ 22.353265] amdgpu 0000:11:00.0: amdgpu: kiq ring mec 2 pipe 1 q 0
[ 22.379510] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 22.379517] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 22.393803] amdgpu: Virtual CRAT table created for GPU
[ 22.420030] amdgpu: Topology: Add dGPU node [0x13c0:0x1002]
[ 22.420033] kfd kfd: amdgpu: added device 1002:13c0
[ 22.426068] amdgpu 0000:11:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 22.426071] amdgpu 0000:11:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 22.426073] amdgpu 0000:11:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
[ 22.426074] amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
[ 22.426074] amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
[ 22.426075] amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 22.426075] amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 22.426076] amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 22.426077] amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 22.426077] amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 22.426078] amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 22.426078] amdgpu 0000:11:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
[ 22.426079] amdgpu 0000:11:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
[ 22.426079] amdgpu 0000:11:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[ 22.426079] amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[ 22.426080] amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[ 22.426080] amdgpu 0000:11:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[ 22.481151] amdgpu 0000:11:00.0: amdgpu: Runtime PM not available
[ 22.481359] amdgpu 0000:11:00.0: [drm] Registered 4 planes with drm panic
[ 22.481360] [drm] Initialized amdgpu 3.64.0 for 0000:11:00.0 on minor 0
[ 22.499306] amdgpu 0000:11:00.0: [drm] Cannot find any crtc or sizes
[ 23.257232] amdgpu 0000:03:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 23.257237] amdgpu 0000:11:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 606.245796] amdgpu 0000:03:00.0: amdgpu: Dumping IP State
[ 606.246647] amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
[ 606.246695] amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[ 606.246697] amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[ 606.246698] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=568095, emitted seq=568097
[ 606.246700] amdgpu 0000:03:00.0: amdgpu: Process GGST-Win64-Ship pid 28741 thread dxvk-submit pid 28842
[ 606.246701] amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
[ 608.807444] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=RESET
[ 608.807448] amdgpu 0000:03:00.0: amdgpu: failed to reset legacy queue
[ 608.807449] amdgpu 0000:03:00.0: amdgpu: reset via MES failed and try pipe reset -110
[ 608.807450] amdgpu 0000:03:00.0: amdgpu: The CPFW hasn't support pipe reset yet.
[ 608.807451] amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failed
[ 608.807453] amdgpu 0000:03:00.0: amdgpu: GPU reset begin!. Source: 1
[ 611.554933] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 611.554936] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 614.114182] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 614.114185] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 616.674359] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 616.674362] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 619.233339] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 619.233341] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 621.792412] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 621.792415] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 624.351462] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 624.351463] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 624.569427] [drm:gfx_v12_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[ 624.600523] amdgpu 0000:03:00.0: amdgpu: MODE1 reset
[ 624.600524] amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
[ 624.600572] amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
[ 625.638070] amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 625.638146] amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
[ 625.638175] amdgpu 0000:03:00.0: amdgpu: VRAM is lost due to GPU reset!
[ 625.638176] amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
[ 625.873088] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 625.873089] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
[ 625.873090] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[ 625.873093] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000032, smu fw program = 0, smu fw version = 0x00684b00 (104.75.0)
[ 625.873094] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[ 625.942576] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[ 625.942762] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
[ 625.942764] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
[ 625.953428] amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000601
[ 626.146739] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 626.146741] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 626.146742] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 626.146742] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 626.146743] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 626.146743] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 9 on hub 0
[ 626.146744] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 10 on hub 0
[ 626.146744] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 626.146745] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 626.152305] amdgpu 0000:03:00.0: amdgpu: GPU reset(1) succeeded!
[ 626.152559] amdgpu 0000:03:00.0: amdgpu: [drm] *ERROR* Failed to initialize parser -125!
[ 626.166324] amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
Here’s garuda-inxi
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=6be0e09d-a11f-4f60-858b-b44544647027 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Desktop Mobo: Micro-Star model: PRO B650-S WIFI (MS-7E26) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.I0 date: 12/27/2024
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404023
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2985 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2985 2: 2985 3: 2985
4: 2985 5: 2985 6: 2985 7: 2985 8: 2985 9: 2985 10: 2985 11: 2985 12: 2985
13: 2985 14: 2985 15: 2985 16: 2985 bogomips: 150399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
Writeback-2 bus-ID: 11:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 38.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x1440
display-ID: 0
Monitor-1: DP-2 pos: primary,left model: DP serial: <filter> built: 2023
res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 108 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-3 pos: right model: DP serial: <filter> built: 2023 res:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.6 DRM 3.64 6.18.2-zen2-1-zen) device-ID: 1002:7550
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.2-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 25.3.2-arch1.1 device-ID: 1002:13c0 surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM 21.1.6)
de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech H390 headset with microphone
lanes: 1 mode: 1.1 bus-ID: 1-10:9 chip-ID: 046d:0a8f class-ID: 0300
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0d:00.0
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0e:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp14s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:7 chip-ID: 0e8d:0616
Local Storage: total: 1.99 TiB used: 1015.57 GiB (49.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: KIOXIA model: EXCERIA SATA SSD
tech: SSD serial: <filter> fw-rev: 18.1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: KIOXIA model: EXCERIA SATA SSD
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 500GB
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 250GB
ID-5: /dev/sde maj-min: 8:64 vendor: KIOXIA model: EXCERIA SATA SSD
tech: SSD serial: <filter> fw-rev: 18.1 scheme: MBR
ID-1: / raw-size: 446.84 GiB size: 446.84 GiB (100.00%)
used: 55.14 GiB (12.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 446.84 GiB size: 446.84 GiB (100.00%)
ID-4: /var/log raw-size: 446.84 GiB size: 446.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 446.84 GiB size: 446.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.45 GiB used: 8 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.6 C mobo: 30.2 C
GPU: device: amdgpu temp: 38.0 C device: amdgpu temp: 49.0 C mem: 69.0 C
fan: 1 watts: 77.00
Memory: total: 32 GiB note: est. available: 30.45 GiB used: 5.51 GiB (18.1%)
Processes: 738 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1570 libs: 424 tools: octopi,paru Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.2
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-10-14
Garuda release: 251002
Last full system update: 2025-12-31 ↻
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
25/26 checks run in 0.62 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
I’ve tried validating both proton and the game itself but this looks like a driver issue.
