Games consistently crash within 2-5 hours. Ring Timeout, Context Lost, Pageflip
Hi all,
I built a new PC at the start of September and swapped to Linux (I still have Windows dual boot). At first I installed Linux Mint, but I learned the driver for the 9070 XT was not sufficient. I swapped to Bazzite which ran nicely, but I had issues with crashing. I have been unable to resolve the crashing so have been trying other distros.
I tried Opensuse Tumbleweed and experienced no crashing (19.5 hour game stress test)
I am now on Garuda and am experiencing the exact same crashing as on Bazzite.
Crashing
I am able to run games and get good performance. However after 2 - 5 hours the game will crash. Sometimes the desktop environment goes with it and I have to restart, sometimes it is able to recover.
The crash presents as a sudden freeze of the screen on both monitors, but audio keeps playing for several minutes. Game audio eventually stops, but any other audio source (video on second monitor for example) will keep playing.
The crash has mostly happened in World of Warcraft and Cities Skylines both played through Steam using Proton. I crashed once in Space Marine 2. I suspect any game would crash on a long enough session though, I just haven’t played other games as much.
Using journalctl I have pulled logs from many different crashes and there are a few repeating themes:
  • amdgpu ring timeout & reset
  • context lost
  • Sometimes Pageflip timeout
I will include the latest journalctl below. I have around 12 exports of different crash reports but don’t want to fill the post unnecessarily, but I have them saved and can check them for more info (But many come from Bazzite).
Nov 01 17:09:31 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:7 pasid:32803)
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:  Process Cities2.exe pid 25080 thread dxvk-submit pid 25136
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800002d18000 from client 10
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x0070153A
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: SQC (data) (0xa)
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x0
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          WALKER_ERROR: 0x5
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          MAPPING_ERROR: 0x1
Nov 01 17:09:32 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          RW: 0x0
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=27281061, emitted seq=27281063
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:  Process Cities2.exe pid 25080 thread dxvk-submit pid 25136
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset succeeded
Nov 01 17:09:42 Gilgamesh kernel: amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
Nov 01 17:09:42 Gilgamesh systemd[1]: Starting autorandr execution hook...
░░ Subject: A start job for unit autorandr.service has begun execution
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ A start job for unit autorandr.service has begun execution.
░░ The job identifier is 6980.
Nov 01 17:09:42 Gilgamesh systemd[1]: autorandr.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit autorandr.service has successfully entered the 'dead' state.
Nov 01 17:09:42 Gilgamesh systemd[1]: Finished autorandr execution hook.
░░ Subject: A start job for unit autorandr.service has finished successfully
░░ A start job for unit autorandr.service has finished successfully.
Nov 01 17:09:42 Gilgamesh lact[2950]: 2025-11-01T17:09:42.172649Z  INFO lact_daemon: got kernel drm subsystem event, reloading GPUs
Nov 01 17:09:42 Gilgamesh lact[2950]: 2025-11-01T17:09:42.177417Z  INFO lact_daemon::server::handler: initialized amdgpu controller for GPU 1002:7550-148C:2435-0000:03:00.0 at '/sys/class/drm/card1/device'
Nov 01 17:09:42 Gilgamesh lact[2950]: 2025-11-01T17:09:42.177424Z  INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying configuration
Nov 01 17:09:42 Gilgamesh lact[2950]: 2025-11-01T17:09:42.177447Z  INFO lact_daemon::server::handler: configuration applied
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=27281062, emitted seq=27281065
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:  Process Cities2.exe pid 25080 thread dxvk-submit pid 25136
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset succeeded
Nov 01 17:09:52 Gilgamesh kernel: amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
Nov 01 17:09:52 Gilgamesh systemd[1]: Starting autorandr execution hook...
░░ The job identifier is 7113.
Nov 01 17:09:52 Gilgamesh steam[19178]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is guilty of a hard recovery.
Nov 01 17:09:52 Gilgamesh steam[19178]: radv: GPUVM fault detected at address 0x800002d18000.
Nov 01 17:09:52 Gilgamesh steam[19178]: GCVM_L2_PROTECTION_FAULT_STATUS: 0x70153a
Nov 01 17:09:52 Gilgamesh steam[19178]:          CLIENT_ID: (SQC (data)) 0xa
Nov 01 17:09:52 Gilgamesh steam[19178]:          MORE_FAULTS: 0
Nov 01 17:09:52 Gilgamesh steam[19178]:          WALKER_ERROR: 5
Nov 01 17:09:52 Gilgamesh steam[19178]:          PERMISSION_FAULTS: 3
Nov 01 17:09:52 Gilgamesh steam[19178]:          MAPPING_ERROR: 1
Nov 01 17:09:52 Gilgamesh steam[19178]:          RW: 0
Nov 01 17:09:52 Gilgamesh systemd[1]: autorandr.service: Deactivated successfully.
Nov 01 17:09:52 Gilgamesh systemd[1]: Finished autorandr execution hook.
Nov 01 17:09:52 Gilgamesh lact[2950]: 2025-11-01T17:09:52.412459Z  INFO lact_daemon: got kernel drm subsystem event, reloading GPUs
Nov 01 17:09:52 Gilgamesh lact[2950]: 2025-11-01T17:09:52.417840Z  INFO lact_daemon::server::handler: initialized amdgpu controller for GPU 1002:7550-148C:2435-0000:03:00.0 at '/sys/class/drm/card1/device'
Nov 01 17:09:52 Gilgamesh lact[2950]: 2025-11-01T17:09:52.417854Z  INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying configuration
Nov 01 17:09:52 Gilgamesh lact[2950]: 2025-11-01T17:09:52.417889Z  INFO lact_daemon::server::handler: configuration applied
What I have tried
  • Changing Proton version (Using Experimental and various GE versions)
  • Lowering main monitor refresh rate (usually 180hz)
  • Setting both monitors to the same refresh rate (I initially thought this crash was caused by VRR)
  • Disabling VRR completely
  • Capping FPS below refresh rate (Capped to 120fps at 144hz)
  • Adding “RADV_DEBUG=nodcc %command%” to Steam launch command
  • Disabling “Direct Scan-Out” (Tested on Bazzite)
  • Disabling “AMDGPU runtime‑power‑management” (tested on Bazzite)
  • Tested different Kernels on Bazzite (Can’t remember exact versions but tested both Bazzite 42 and 43 which was kernel 6.16 to 6.17 I believe)
  • Tested different Kernels on Garuda (linux-zen 6.17.6.zen1-1 and linux-mainline 6.18rc3-1)
I still crashed in all of the above scenarios
I have also attempted to rule out hardware as follows:
  • Temperatures seem fine. Tested on both Windows and Linux. CPU peaked at 82 degrees but averaged around 65 degrees. GPU peaked at 70 degrees but also averaged around 65 (The junction / hotspot temperature on GPU was at 85 with occasional dips lower but never higher)
  • I have never crashed in Windows on this PC
  • I installed Opensuse Tumbleweed and left Cities Skylines 2 running overnight and through the work day. It ran for 19.5 hours with no crash (The longest Garuda has gone without a crash is 4 hours)
Help Me
I know I have said above that Tumbleweed was stable, and if I can’t resolve the crash I will swap to it for stability. However Garuda has been such a nice experience. Out of all the distros I’ve tried, I really would love to make it my main OS.
I welcome any suggestions. I’ll answer what I can and try whatever is suggested!
Thanks for your time.
lee@Gilgamesh in ~
╰─λ garuda-inxi
Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=7e947cb6-e2b8-415b-a232-aa8202323db5 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Mobo: ASUSTeK model: PRIME X870-P v: Rev 1.xx serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 1078
date: 07/14/2025
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404032
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4501 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4501 2: 4501 3: 4501
4: 4501 5: 4501 6: 4501 7: 4501 8: 4501 9: 4501 10: 4501 11: 4501 12: 4501
13: 4501 14: 4501 15: 4501 16: 4501 bogomips: 150399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Tul / PowerColor Reaper driver: amdgpu v: kernel
arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
gen: 5 speed: 32 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x2880
display-ID: 0
Monitor-1: DP-1 pos: bottom-r model: Acer XB273U V3 serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: DP-2 pos: primary,top-left model: Acer XB271HU serial: <filter>
built: 2018 res: mode: 2560x1440 hz: 144 scale: 178% (1.78) to: 1440x2560
dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.4 DRM 3.64 6.17.6-zen1-1-zen) device-ID: 1002:7550
API: Vulkan v: 1.4.328 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.2.6-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
lanes: 16 bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: SteelSeries ApS Arctis Nova 7
lanes: 1 mode: 1.1 bus-ID: 7-1:2 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 2b89:8761
Local Storage: total: 4.55 TiB used: 156.54 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
model: SSD 990 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QKXG7 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 34.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 32.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
ID-1: / raw-size: 305.29 GiB size: 305.29 GiB (100.00%)
used: 156.53 GiB (51.3%) fs: btrfs dev: /dev/nvme2n1p4 maj-min: 259:10
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 16.4 MiB (2.7%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:7
ID-3: /home raw-size: 305.29 GiB size: 305.29 GiB (100.00%)
ID-4: /var/log raw-size: 305.29 GiB size: 305.29 GiB (100.00%)
ID-5: /var/tmp raw-size: 305.29 GiB size: 305.29 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.98 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Memory: total: 32 GiB note: est. available: 30.98 GiB used: 5.53 GiB (17.8%)
Processes: 449 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1857 libs: 546 tools: octopi,paru Compilers:
clang: 21.1.4 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.1.2
Garuda (2.11.1-1):
System install date:     2025-10-31
Garuda release:          251002
Last full system update: 2025-11-01 ↻
24/25 checks run in 0.57 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Deprecated/Outdated/Removed packages should be removed: steam-native-runtime (fix available)
--- INFO ---
First, pls make a bios update
Second, pls next time reboot then open issue :upside_down_face:
Thirdly, the gpu is not card0 (my mind), perhaps that’s the problem.
I had a similiar problem with this and you should insert
initcall_blacklist=simpledrm_platform_driver_init
over Garuda Boot Options or manual /etc/default/grub (GRUB_CMDLINE_LINUX_DEFAULT)
As a test, install the znver5 kernel + headers. (my mind)
sudo pacman -S linux-znver5 linux-znver5-headers
Hi,
Thanks for the response. I’ve updated my BIOS.
Sorry about the inxi, I had just rebooted when I started the issue but as I was writing the post I applied some minor patches and pulled the inxi at the end. Here is a new one immediately after boot (And after the BIOS update).
λ garuda-inxi
quiet loglevel=3
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 1087
date: 09/19/2025
Speed (MHz): avg: 5229 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5229 2: 5229 3: 5229
4: 5229 5: 5229 6: 5229 7: 5229 8: 5229 9: 5229 10: 5229 11: 5229 12: 5229
13: 5229 14: 5229 15: 5229 16: 5229 bogomips: 150399
ssse3 svm
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-4, DP-5, HDMI-A-2, Writeback-2
bus-ID: 75:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 43.0 C
display-ID: 0
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.2.6-arch1.1 device-ID: 1002:13c0 surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 21.1.4 256 bits) driver: mesa llvmpipe
v: 25.2.6-arch1.1 (LLVM 21.1.4) device-ID: 10005:0000 surfaces: N/A
[Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 75:00.1 chip-ID: 1002:1640
Device-4: SteelSeries ApS Arctis Nova 7
Local Storage: total: 4.58 TiB used: 157.31 GiB (3.4%)
logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QKXG7 temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 30.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 28.9 C scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Toshiba model: TransMemory
size: 28.87 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
used: 157.3 GiB (51.5%) fs: btrfs dev: /dev/nvme2n1p4 maj-min: 259:10
ID-1: swap-1 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.5 C mobo: 54.5 C
GPU: device: amdgpu temp: 43.0 C device: amdgpu temp: 34.0 C mem: 36.0 C
fan: 0 watts: 45.00
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 4.58 GiB (15.0%)
Processes: 453 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1859 libs: 546 tools: octopi,paru Compilers:
Garuda (2.11.1-1):
Last full system update: 2025-11-02
24/25 checks run in 0.62 seconds ⌛
--- LOW ---
On the GPU being card0 I don’t really understand the line you quoted but I do know that my motherboard has an on-board GPU which is also AMD and was showing up on my system when I first booted it. I used the bios to disable it.
Looking at LACT I do now see that it shows as GPU1 with the on-board showing as GPU0.
I will apply the boot option you provided and also the linux-znver5 kernel you suggested. It will be tomorrow before I can post results though as it can take hours for the crash to occur.
Thanks again!
Hi,
I booted into the linux-znver5 kernel with the boot parameter provided. Set up Cities Skylines running with the intention of leaving it overnight to test. However it crashed within about five minutes while I was still at the PC playing around with it.
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:157 vmid:7 pasid:32803)
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:  Process Cities2.exe pid 16596 thread dxvk-submit pid 16652
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800002ca4000 from client 10
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x0070153B
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: SQC (data) (0xa)
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x1
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          WALKER_ERROR: 0x5
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          MAPPING_ERROR: 0x1
Nov 02 23:06:48 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:          RW: 0x0
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card0/device/devcoredump/data
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=383869, emitted seq=383871
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu:  Process Cities2.exe pid 16596 thread dxvk-submit pid 16652
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset succeeded
Nov 02 23:06:58 Gilgamesh kernel: amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
Happy to hear any further suggestions
If you leave now disabled the igpu you can delete also the entry. (boot parameter)
Do you read this ?
https://www.protondb.com/app/949230
As test you can install another dxvk but not shure if this can help.
Hi,
Thanks for the link. I’m working on the assumption that the crash isn’t specific to Cities Skylines 2 though as I also get them frequently with World of Warcraft. Cities Skylines 2 is just an easier test to leave on overnight.
I have an update though. After the znver5 kernel crashed immediately I left Bazzite on testing overnight with an underclock on my GPU. Woke up to a crash so that did nothing (Though I did learn how to set a proper fan curve with LACT and now my hotspot temperatures don’t go above 70 degrees instead of being locked at 85).
After that while at work I booted into Garuda again this time using the kernal Linux RT (Linux 6.14.0-rt3-arch1-3-rt). The game ran for 11.5 hours with no crashes. So that is a very promising sign. I will test again tonight on this kernel but it means I have something stable to swap to Garuda with.
I do have another question now though, how do Kernel updates work on Garuda? I’ve tried to find documentation but couldn’t see anything. I suspect I might be experiencing a bug in the AMD driver in the more recent kernels which is why the 6.14 didn’t crash. If I keep using this one, I’m concerned it will be updated and introduce the crash again.
So how and when are kernels updated? Am I able to ‘pin’ a kernel and keep using it without update for a period (Until hopefully the issue is fixed on more current kernels)?
Thanks again for the help so far
EDIT: Please let me know if this question should be another forum issue post instead, I’m putting it here as it’s directly related but I know the template says one issue per ticket).
hi
as gampel recommended i also would try a other dxvk variant. At my Games few times i even have to swap the wine version to get a game running. may you can try the paru -S dxvk-async-git i also have the libdxvk installed.
I may have spoken too soon. Went to do a second test overnight and it crashed within five minutes again. Still on the 6.14.0-rt3-arch1-3-rt kernel which ran for 11+ hours earlier today :frowning:
Thanks Duke, I don’t understand everything about that suggestion but I’ll look in to it and see if I can give it a try.
hi,
i was checking the protondb website. It seems the Game is problematic at all and there would be many options to try settings and you will need a while to figure the right settings out.
The dxvk-async-git has a better Vram managment and bypass memory issues a bit better but it dosnt mean it will not crash just helps by async-compiling shaders to reduce stutters/crashes.This is also is a bit tricky to install because you have it to do for every game seperatly. There you can search in the web for it. I did it a long time ago and dont know it works as same as i did.
You are using Steam so normally it should load the correct stuff but not all time. I switched to Lutris or Heroic Game Launcher for my Games because i can set it up better as like in Steam.
Maybe you can try to add the Game in the Lutris Launcher .( you need to find the steam game folder for it ./steamapps/common in my case).
Did you have protonup-qt installed for managing proton versions and so on for Steam? I just see they say proton-GE (10-25)works mostly better.
sudo pacman -S protonup-qt
This bug has been known for a long time and mainly affects the amd gpu driver/drm (in rare cases, mesa is the cause).
Since this bug can also be triggered by browsers and other applications, you should first go through your other logs and check whether it only occurs in games.
There is no magic bullet for this bug, but you can try disabling GFXOFF with this kernel parameter:
amdgpu.ppfeaturemask=0xf7fff
The 0xf7fff flag enables all features including overdrive but disables PP_GFXOFF_MASK.
Try disabling the power management on Garuda with:
amdgpu.runpm=0
to prevent the GPU from being dynamically shut down during runtime.
Another kernel parameter you can test is:
amdgpu.aspm=0
to disable AMD Active State Power Management.
And if you use OC for the GPU and/or mods for the games (including shader mods), then disable/uninstall it.
Hi all,
Thanks for the replies. After what some of you have said I decided to do additional testing of Cities Skylines 2 on Windows to be sure I was on the right track. I set it away overnight and came back to a desktop and no AMD Adrenaline software running, so it would seem the game may have it’s own problems and my testing so far has been unreliable (Either that or it’s a hardware fault!).
Cities Skylines 2 was a very convenient game to launch and leave playing to test stability, the other game which has had the most crashes is WoW but you get logged out after 30 minutes of inactivity so I can only test it with real playing.
I saw a new Linux mainline kernel was released at 6.18 which has some specific AMD driver bugfixes in it. I will test in Garuda with that kernel and see if I get any more crashes. If I do I will capture the logs and return here, and then I will also try some of the suggestions above to see if they resolve it.
Thank you again
Sadly specifically CitySkylines 2 performance and stability is all over the place.
What can I advice is to try to enable bleeding edge branch on proton experimental. Valve may put into that branch some optimisations.
Hi all,
I decided to go with Garuda as my main OS for now despite the crashing. So I have format my Linux drive and given it over entirely to Garuda. Got everything set up. I will provide a new Garuda-Inxi at the bottom of this post from the fresh install.
Unfortunately I have installed WoW and immediately had a crash. Looks like it’s giving the pageflip error which the CS2 crashes weren’t. I have attached the journalctl and dmesg from the crash (I’ve had to reduce them to the most relevant bits as they’re too big and I can’t upload text files).
I hope this gives some extra context to help resolve this issue.
Thank you
Journalctl
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: QImage::pixel: coordinate (49,0) out of range
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Plugin changed to:  "org.kde.kwin.aurorae"
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Searching for plugins:  "org.kde.kwin.aurorae"
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Factory:  true
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Couldn't find QML Decoration  ""
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:225:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:220:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Reading preset: /usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/presets/Dr460nized Top Panel
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: QML Plugin org.kde.plasma.panelcolorizer loaded
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: No QSGTexture provided from updateSampledImage(). This is wrong.
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: file:///usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/main.qml:21:1: QML PlasmoidItem: Binding loop detected for property "cfg":
                                              file:///usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/main.qml:97:5
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Window Buttons : current plasma theme :::  "Dr460nized"
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Window Buttons : theme path :::  "/usr/share/plasma/desktoptheme/Dr460nized"
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: Window Buttons : theme widgets path :::  "/usr/share/plasma/desktoptheme/Dr460nized/widgets"
Nov 09 17:28:32 Gilgamesh kwin_wayland[26271]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Nov 09 17:28:32 Gilgamesh kwin_wayland[26271]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Nov 09 17:28:32 Gilgamesh kwin_wayland[26271]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: file:///usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/code/utils.js:873: TypeError: Cannot read property 'visible' of null
Nov 09 17:28:32 Gilgamesh plasmashell[98127]: recreating buttons
Nov 09 17:28:33 Gilgamesh kwin_wayland[26271]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Nov 09 17:28:33 Gilgamesh kwin_wayland[26271]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Nov 09 17:28:33 Gilgamesh kwin_wayland[26271]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Nov 09 17:28:38 Gilgamesh kernel: amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:86:crtc-0] flip_done timed out
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: 0x4: GL_CONTEXT_LOST in context lost
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: A graphics reset not attributable to the current GL context occurred.
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ShapeCorners: Writing Breeze outline intensity config "OutlineMedium"
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: KscreenConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: MagicLampConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: OverviewConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ShakeCursorConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: SlideConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: SlidingPopupsConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: WindowViewConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: WobblyWindowsConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ZoomConfig::instance called after the first use - ignoring
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ShapeCorners: loading shaders...
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ShapeCorners: shaders loaded.
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: ShapeCorners: Writing Breeze outline intensity config "OutlineOff"
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: QFSFileEngine::open: No file name specified
Nov 09 17:28:53 Gilgamesh garuda-rani[99422]: WARNING: radv is not a conformant Vulkan implementation, testing use only.
Nov 09 17:28:53 Gilgamesh plasmashell[98127]: Reading preset: /usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/presets/Dr460nized Top Panel Interaction
Nov 09 17:28:53 Gilgamesh plasmashell[98127]: file:///usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/main.qml:21:1: QML PlasmoidItem: Binding loop detected for property "cfg":
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Nov 09 17:28:53 Gilgamesh kwin_wayland[26271]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Nov 09 17:28:54 Gilgamesh garuda-rani[99467]: (node:99467) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
Nov 09 17:28:54 Gilgamesh garuda-rani[99467]: (Use `exe --trace-deprecation ...` to show where the warning was created)
Nov 09 17:28:54 Gilgamesh garuda-rani[99359]: INFO [17:28:54.045]: Renderer - Loaded 1 settings from store
Nov 09 17:28:54 Gilgamesh garuda-rani[99359]: INFO [17:28:54.302]: Renderer - Last update: 2025-11-09T16:02:26.000Z
Nov 09 17:28:54 Gilgamesh garuda-rani[99359]: INFO [17:28:54.437]: Renderer - No aur updates available
Nov 09 17:28:54 Gilgamesh kwin_wayland[26271]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Nov 09 17:28:54 Gilgamesh kwin_wayland[26271]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Nov 09 17:28:54 Gilgamesh kwin_wayland[26271]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Nov 09 17:28:55 Gilgamesh garuda-rani[99359]: INFO [17:28:55.125]: Renderer - No updates available
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: Listener adapter polkit_qt_listener_initiate_authentication
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: GSimpleAsyncResult: 0x55deac78a770
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: polkit_qt_listener_initiate_authentication callback for  0x55deacd6c690
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: Initiating authentication
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: Action description has been found
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: qrc:/qml/QuickAuthDialog.qml:57:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 70. Use 'sequences: [ <key> ]' to bind to all of them.
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: User:  "unix-user:lee"
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: Trying again
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: REQUEST
Nov 09 17:28:59 Gilgamesh polkit-kde-authentication-agent-1[26566]: Request:  "Password: "  echo:  false
Nov 09 17:29:02 Gilgamesh polkit-kde-authentication-agent-1[26566]: Dialog cancelled
Nov 09 17:29:02 Gilgamesh polkit-kde-authentication-agent-1[26566]: Finishing obtaining privileges
Nov 09 17:29:02 Gilgamesh polkit-kde-authentication-agent-1[26566]: Finish obtain authorization: true
Nov 09 17:29:02 Gilgamesh polkitd[822]: Operator of unix-session:5 successfully authenticated as unix-user:lee to gain ONE-SHOT authorization for action org.freedesktop.policykit.exec for unix-process:99467:339386 [/proc/self/exe --type=renderer --enable-crash-reporter=ecc8a564-cf73-480f-99f0-bf1a51275cf5,no_channel --user-data-dir=/home/lee/.config/garuda-rani --app-path=/usr/lib/garuda-rani/app.asar --no-sandbox --no-zygote --ozone-platform=wayland --lang=en-GB --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=4 --time-ticks-at-unix-epoch=-1762705939703992 --launch-time-ticks=3393864192 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=3,i,17977789449688989135,10389922430498132634,262144 --enable-features=PdfUseShowSaveFilePicker --disable-features=ScreenAIOCREnabled,SpareRendererForSitePerProcess,TraceSiteInstanceGetProcessCreation --variations-seed-version] (owned by unix-user:lee)
Nov 09 17:29:02 Gilgamesh pkexec[99664]: pam_unix(polkit-1:session): session opened for user root(uid=0) by lee(uid=1000)
Nov 09 17:29:02 Gilgamesh pkexec[99664]: lee: Executing command [USER=root] [TTY=unknown] [CWD=/usr/lib/garuda-rani] [COMMAND=/usr/bin/journalctl -xe --no-pager]
Dmesg
[ 1021.513368] x86/split lock detection: #DB: CHTTPClientThre/35039 took a bus_lock trap at address: 0xf3dc7c84
[ 2227.526656] input: Microsoft X-Box 360 pad 0 as /devices/virtual/input/input27
[ 2256.529910] input: Microsoft X-Box 360 pad 0 as /devices/virtual/input/input28
[ 2289.351074] ntfs3: Enabled Linux POSIX ACLs support
[ 2289.351077] ntfs3: Read-only LZX/Xpress compression included
[ 2606.743348] input: Microsoft X-Box 360 pad 0 as /devices/virtual/input/input29
[ 2622.928476] input: Microsoft X-Box 360 pad 0 as /devices/virtual/input/input30
[ 3352.383138] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383143] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383145] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4f3e000 from client 10
[ 3352.383146] amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00501031
[ 3352.383147] amdgpu 0000:03:00.0: amdgpu: 	 Faulty UTCL2 client ID: TCP (0x8)
[ 3352.383147] amdgpu 0000:03:00.0: amdgpu: 	 MORE_FAULTS: 0x1
[ 3352.383148] amdgpu 0000:03:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[ 3352.383148] amdgpu 0000:03:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x3
[ 3352.383149] amdgpu 0000:03:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[ 3352.383149] amdgpu 0000:03:00.0: amdgpu: 	 RW: 0x0
[ 3352.383152] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383153] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383154] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4ece000 from client 10
[ 3352.383158] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383159] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383159] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4ece000 from client 10
[ 3352.383162] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383162] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383162] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4f3e000 from client 10
[ 3352.383165] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383165] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383166] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a512e000 from client 10
[ 3352.383168] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383168] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383169] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4ece000 from client 10
[ 3352.383171] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383171] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383172] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4f3e000 from client 10
[ 3352.383174] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383174] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383175] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a512e000 from client 10
[ 3352.383177] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383177] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383178] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4ece000 from client 10
[ 3352.383180] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32814)
[ 3352.383181] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3352.383181] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x00008002a4f3e000 from client 10
[ 3362.827718] amdgpu 0000:03:00.0: amdgpu: Dumping IP State
[ 3362.828361] amdgpu 0000:03:00.0: amdgpu: Dumping IP State Completed
[ 3362.828393] amdgpu 0000:03:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
[ 3362.828394] amdgpu 0000:03:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
[ 3362.828395] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=3627040, emitted seq=3627042
[ 3362.828396] amdgpu 0000:03:00.0: amdgpu:  Process WoW.exe pid 97641 thread vkd3d_queue pid 97734
[ 3362.828396] amdgpu 0000:03:00.0: amdgpu: Starting gfx_0.0.0 ring reset
[ 3365.035661] amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failed
[ 3365.035665] amdgpu 0000:03:00.0: amdgpu: GPU reset begin!. Source:  1
[ 3367.266839] amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
[ 3367.266843] amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
[ 3367.474033] [drm:gfx_v12_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
[ 3367.501753] amdgpu 0000:03:00.0: amdgpu: MODE1 reset
[ 3367.501756] amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
[ 3367.501795] amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
[ 3368.524818] amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 3368.524881] amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
[ 3368.524904] amdgpu 0000:03:00.0: amdgpu: VRAM is lost due to GPU reset!
[ 3368.524905] amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
[ 3368.750484] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 3368.750486] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
[ 3368.750488] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[ 3368.750490] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000032, smu fw program = 0, smu fw version = 0x00684a00 (104.74.0)
[ 3368.750492] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[ 3368.819124] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[ 3368.819311] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
[ 3368.819314] amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
[ 3368.830417] amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000400
[ 3369.122051] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 3369.122055] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 3369.122056] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 3369.122057] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 6 on hub 0
[ 3369.122057] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 7 on hub 0
[ 3369.122058] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 8 on hub 0
[ 3369.122058] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 9 on hub 0
[ 3369.122058] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 3369.122059] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[ 3369.126456] amdgpu 0000:03:00.0: amdgpu: GPU reset(1) succeeded!
[ 3369.126582] amdgpu 0000:03:00.0: amdgpu: [drm] *ERROR* Failed to initialize parser -125!
[ 3369.140123] amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
[ 3379.211818] amdgpu 0000:03:00.0: [drm] *ERROR* [CRTC:86:crtc-0] flip_done timed out
Garuda-inxi
╰─λ garuda-inxi
Kernel: 6.18.0-rc4-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=7bccce8b-51b5-4255-acdb-3cae91fe3055 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.19.0
date: 09/19/2025
Speed (MHz): avg: 5220 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5220 2: 5220 3: 5220
4: 5220 5: 5220 6: 5220 7: 5220 8: 5220 9: 5220 10: 5220 11: 5220 12: 5220
13: 5220 14: 5220 15: 5220 16: 5220 bogomips: 150399
ssse3 svm
display-ID: 0
gfx1201 LLVM 21.1.4 DRM 3.64 6.18.0-rc4-1-mainline) device-ID: 1002:7550
lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.18.0-rc4-1-mainline status: kernel-api with: aoss
Local Storage: total: 4.55 TiB used: 1.47 TiB (32.2%)
ID-1: /dev/nvme0n1 maj-min: 259:8 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 35.9 C scheme: GPT
used: 264 GiB (28.4%) fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:2
used: 6.1 MiB (2.0%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 30.99 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 64.4 C mobo: 55.5 C gpu: amdgpu temp: 49.0 C
mem: 50.0 C
Memory: total: 32 GiB note: est. available: 30.99 GiB used: 7.12 GiB (23.0%)
Processes: 537 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,
Packages: 1882 pm: pacman pkgs: 1871 libs: 498 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 21.1.5 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.1.2 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2025-11-08
Last full system update: 2025-11-09
24/25 checks run in 0.54 seconds ⌛
amdgpu.runpm=0
amdgpu.aspm=0
Now that I’ve had a confirmed crash on another game (To rule out this being just Cities Skylines) on a fresh Garuda install, I’ve applied these three kernel parameters using the Rani Boot options.
I will report back if I crash again
All three at once? It’s best to test them individually first, you can always combine them later. :slightly_smiling_face:
Haha, I’m so sick of troubleshooting now I thought I’d go for all three and if I stop crashing I can disable them one at a time to find the solution.
If you think it’s better though I can try them one at a time? What order would you suggest, or just any?
Also out of interest, you said this bug has been known for a long time; is there any hope of it being fixed any time in the near future? After a few months of crashing I’m really ready to just do whatever works and I’m kind of regretting swapping to AMD for the first time.
Thanks
Personally, I would test them individually and extensively, in the order I posted. And if that doesn’t work, then combine them with each other.
I don’t have much hope:
Well at your advice I applied only
as a boot parameter and I haven’t crashed since. I’ve been playing less WoW recently and obviously I can’t do overnight tests on it but I’ve logged a good dozen + hours of WoW with no crashes and no other game has crashed either.
Still not 100% certain that this is the solution but we’re at 11 days with no crashes under normal usage and that’s pretty good. If I get a crash I’ll come back with the logs but I’m now cautiously optimistic.
Thanks
Okay I’ve had another crash in WoW under the above setup. The Journalctl is too long to post so I’ve posted a cut version below. I’ve tried to only remove non-relevant stuff such as repeated context lost messages but I’ve had to cut a lot.
After the crash the system limped along for a while in a very stuttery manner. I took some screenshots of LACT and Mission Center at the time of the crash and then rebooted.
Nov 24 20:11:13 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: Ring gfx_0.0.0 reset failed
Nov 24 20:11:13 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
Nov 24 20:11:15 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
Nov 24 20:11:15 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: failed to unmap legacy queue
Nov 24 20:11:15 Gilgamesh kernel: [drm:gfx_v12_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
Nov 24 20:11:15 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
Nov 24 20:11:15 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
Nov 24 20:11:15 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset succeeded, trying to resume
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: VRAM is lost due to GPU reset!
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000032, smu fw program = 0, smu f>
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
Nov 24 20:11:16 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000600
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 6 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 7 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 8 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 9 on hub 0
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
Nov 24 20:11:17 Gilgamesh kwin_wayland_wrapper[5921]: amdgpu: The CS has cancelled because the context is lost. This context is innocent.
Nov 24 20:11:17 Gilgamesh steam[10626]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
Nov 24 20:11:17 Gilgamesh firefox[148478]: amdgpu: The CS has cancelled because the context is lost. This context is innocent.
Nov 24 20:11:17 Gilgamesh firefox[148478]: Redirecting call to abort() to mozalloc_abort
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: amdgpu: GPU reset(1) succeeded!
Nov 24 20:11:17 Gilgamesh kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Nov 24 20:11:17 Gilgamesh lact[10707]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
Nov 24 20:11:17 Gilgamesh lact[10707]: Vulkan: ../mesa-25.2.7/src/amd/vulkan/radv_queue.c:1977: vkQueueSubmit() failed (VK_ERROR_DEVICE_LOST)
Nov 24 20:11:17 Gilgamesh lact[10707]: vkQueueSubmit(): The logical or physical device has been lost. (VK_ERROR_DEVICE_LOST) (-4)
Nov 24 20:11:17 Gilgamesh lact[10707]: vkQueuePresentKHR(): The logical or physical device has been lost. (VK_ERROR_DEVICE_LOST) (-4)
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: 0x4: GL_CONTEXT_LOST in context lost
Nov 24 20:11:17 Gilgamesh lact[10707]: vkGetFenceStatus(): The logical or physical device has been lost. (VK_ERROR_DEVICE_LOST) (-4)
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: A graphics reset not attributable to the current GL context occurred.
Nov 24 20:11:17 Gilgamesh systemd-coredump[174743]: Process 5921 (Xwayland) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Nov 24 20:11:17 Gilgamesh systemd[1]: Created slice Slice /system/systemd-coredump.
Nov 24 20:11:17 Gilgamesh systemd[1]: Started Process Core Dump (PID 174743/UID 0).
Nov 24 20:11:17 Gilgamesh kernel: browser 4 :cs0[149383]: segfault at 0 ip 00005572a5d0d247 sp 00007f509f1fea20 error 6 in firefox[86247,5572a5ca9000+9a000]>
Nov 24 20:11:17 Gilgamesh kernel: Code: 35 76 79 03 00 49 8b 36 ff 15 2d 7a 03 00 49 8b 36 bf 0a 00 00 00 ff 15 af 7a 03 00 48 89 1d 10 b4 03 00 31 c0 b9 23>
Nov 24 20:11:17 Gilgamesh systemd-coredump[174748]: Process 148478 (RDD Process) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Nov 24 20:11:17 Gilgamesh kernel: amdgpu 0000:03:00.0: [drm] device wedged, but recovered through reset
Nov 24 20:11:17 Gilgamesh systemd[1]: Started Process Core Dump (PID 174748/UID 0).
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ShapeCorners: Writing Breeze outline intensity config "OutlineMedium"
Nov 24 20:11:17 Gilgamesh systemd[1]: Starting autorandr execution hook...
Nov 24 20:11:17 Gilgamesh org_kde_powerdevil[10138]: [165743] Udev event detected
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: KscreenConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: MagicLampConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: OverviewConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ShakeCursorConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: SlideConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: SlidingPopupsConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: WindowViewConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: WobblyWindowsConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ZoomConfig::instance called after the first use - ignoring
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ShapeCorners: loading shaders...
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ShapeCorners: shaders loaded.
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: ShapeCorners: Writing Breeze outline intensity config "OutlineOff"
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: QFSFileEngine::open: No file name specified
Nov 24 20:11:17 Gilgamesh missioncenter[10708]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
Nov 24 20:11:17 Gilgamesh missioncenter[10708]: Vulkan: ../mesa-25.2.7/src/amd/vulkan/radv_queue.c:1977: vkQueueSubmit() failed (VK_ERROR_DEVICE_LOST)
Nov 24 20:11:17 Gilgamesh missioncenter[10708]: vkQueueSubmit(): The logical or physical device has been lost. (VK_ERROR_DEVICE_LOST) (-4)
Nov 24 20:11:17 Gilgamesh missioncenter[10708]: vkQueuePresentKHR(): The logical or physical device has been lost. (VK_ERROR_DEVICE_LOST) (-4)
Nov 24 20:11:17 Gilgamesh systemd[1]: autorandr.service: Deactivated successfully.
Nov 24 20:11:17 Gilgamesh systemd[1]: Finished autorandr execution hook.
Nov 24 20:11:17 Gilgamesh lact[5658]: 2025-11-24T20:11:17.327278Z  INFO lact_daemon: got kernel drm subsystem event, reloading GPUs
Nov 24 20:11:17 Gilgamesh lact[5658]: 2025-11-24T20:11:17.332250Z  INFO lact_daemon::server::handler: initialized amdgpu controller for GPU 1002:7550-148C:2>
Nov 24 20:11:17 Gilgamesh lact[5658]: 2025-11-24T20:11:17.332258Z  INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying configura>
Nov 24 20:11:17 Gilgamesh lact[5658]: 2025-11-24T20:11:17.341045Z  INFO lact_daemon::server::handler: configuration applied
Nov 24 20:11:17 Gilgamesh systemd-coredump[174747]: [🡕] Process 5921 (Xwayland) of user 1000 dumped core.
Stack trace of thread 9720:
#0  0x00007feb562255df abort (libc.so.6 + 0x255df)
#1  0x00007feb5366d1e3 n/a (libgallium-25.2.7-arch1.1.so + 0xa6d1e3)
#2  0x00007feb536714d4 n/a (libgallium-25.2.7-arch1.1.so + 0xa714d4)
#3  0x00007feb53120955 n/a (libgallium-25.2.7-arch1.1.so + 0x520955)
#4  0x00007feb5316784d n/a (libgallium-25.2.7-arch1.1.so + 0x56784d)
#5  0x00007feb5629698b n/a (libc.so.6 + 0x9698b)
#6  0x00007feb5631a9cc n/a (libc.so.6 + 0x11a9cc)
Nov 24 20:11:17 Gilgamesh systemd[1]: systemd-coredump@0-1-174743_174744-0.service: Deactivated successfully.
Nov 24 20:11:17 Gilgamesh systemd[1]: systemd-coredump@0-1-174743_174744-0.service: Consumed 129ms CPU time, 144.3M memory peak.
Nov 24 20:11:17 Gilgamesh fcitx5[10536]: W2025-11-24 20:11:17.375098 xcbeventreader.cpp:52] XCB connection ":1" got error: 1
Nov 24 20:11:17 Gilgamesh steam[10626]: XIO:  fatal IO error 110 (Connection timed out) on X server ":1"
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 141 requests (141 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 228 requests (228 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 248 requests (248 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 163 requests (163 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 252 requests (252 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 71 requests (71 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh steam[10626]:       after 736 requests (736 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh discord[14341]: XIO:  fatal IO error 13 (Permission denied) on X server ":1"
Nov 24 20:11:17 Gilgamesh discord[14341]:       after 16 requests (16 known processed) with 0 events remaining.
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: The X11 connection broke (error 1)
Nov 24 20:11:17 Gilgamesh kded6[10223]: X connection to :1 broken (explicit kill or server shutdown).
Nov 24 20:11:17 Gilgamesh discord[14261]: [14261:1124/201117.373134:ERROR:ui/gfx/x/connection.cc:65] X connection error received.
Nov 24 20:11:17 Gilgamesh xembedsniproxy[10139]: The X11 connection broke (error 1). Did the X11 server die?
Nov 24 20:11:17 Gilgamesh discord[14211]: [14211:1124/201117.373669:FATAL:electron/shell/browser/electron_browser_main_parts.cc:501] Failed to shutdown.
Nov 24 20:11:17 Gilgamesh gmenudbusmenuproxy[10135]: The X11 connection broke (error 1). Did the X11 server die?
Nov 24 20:11:17 Gilgamesh kaccess[10136]: The X11 connection broke (error 1). Did the X11 server die?
Nov 24 20:11:17 Gilgamesh ksmserver[9989]: The X11 connection broke (error 1). Did the X11 server die?
Nov 24 20:11:17 Gilgamesh pipewire[5912]: mod.x11-bell: X11 I/O error handler called on display :1
Nov 24 20:11:17 Gilgamesh pipewire[5912]: mod.x11-bell: X11 display (:1) has encountered a fatal I/O error
Nov 24 20:11:17 Gilgamesh systemd[1]: home-lee-pCloudDrive.mount: Deactivated successfully.
Nov 24 20:11:17 Gilgamesh kded6[9991]: Service  ":1.102" unregistered
Nov 24 20:11:17 Gilgamesh fcitx5[10536]: W2025-11-24 20:11:17.387829 xcbconnection.cpp:251] Can not convert keyval=32 to keycode!
Nov 24 20:11:17 Gilgamesh fcitx5[10536]: W2025-11-24 20:11:17.387870 xcbconnection.cpp:251] Can not convert keyval=32 to keycode!
Nov 24 20:11:17 Gilgamesh fcitx5[10536]: I2025-11-24 20:11:17.387958 xcbmodule.cpp:90] Disconnected from X11 Display :1
Nov 24 20:11:17 Gilgamesh discord[14230]: [1124/201117.393917:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
Nov 24 20:11:17 Gilgamesh kwin_wayland[5831]: Could not delete render time query because no context is current
Nov 24 20:11:17 Gilgamesh systemd[1]: Started Process Core Dump (PID 174798/UID 0).
Nov 24 20:11:17 Gilgamesh systemd[5692]: plasma-kaccess.service: Main process exited, code=exited, status=1/FAILURE
Nov 24 20:11:17 Gilgamesh systemd[5692]: plasma-kaccess.service: Failed with result 'exit-code'.
Nov 24 20:11:17 Gilgamesh systemd-coredump[174750]: [🡕] Process 148478 (RDD Process) of user 1000 dumped core.
Stack trace of thread 149383:
#0  0x00005572a5d0d247 mozalloc_abort (/usr/lib/firefox/firefox + 0x87247)
#1  0x00005572a5cc5c19 abort (/usr/lib/firefox/firefox + 0x3fc19)
#2  0x00007f50a946d1e3 n/a (libgallium-25.2.7-arch1.1.so + 0xa6d1e3)
#3  0x00007f50a947267d n/a (libgallium-25.2.7-arch1.1.so + 0xa7267d)
#4  0x00007f50a8f20955 n/a (libgallium-25.2.7-arch1.1.so + 0x520955)
#5  0x00007f50a8f6784d n/a (libgallium-25.2.7-arch1.1.so + 0x56784d)
#6  0x00005572a5ced037 n/a (/usr/lib/firefox/firefox + 0x67037)
#7  0x00007f511029698b n/a (libc.so.6 + 0x9698b)
#8  0x00007f511031a7f4 __clone (libc.so.6 + 0x11a7f4)
Nov 24 20:11:17 Gilgamesh systemd[1]: systemd-coredump@1-2-174748_174749-0.service: Deactivated successfully.
Nov 24 20:11:17 Gilgamesh systemd[1]: systemd-coredump@1-2-174748_174749-0.service: Consumed 253ms CPU time, 294.8M memory peak.
Nov 24 20:11:20 Gilgamesh systemd[1]: systemd-coredump@4-8193-174798_174799-0.service: Deactivated successfully.
Nov 24 20:11:20 Gilgamesh systemd[1]: systemd-coredump@4-8193-174798_174799-0.service: Consumed 2.442s CPU time, 1.9G memory peak.
Nov 24 20:11:20 Gilgamesh systemd[5692]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
Nov 24 20:11:20 Gilgamesh systemd[5692]: plasma-plasmashell.service: Failed with result 'core-dump'.
Nov 24 20:11:20 Gilgamesh systemd[5692]: plasma-plasmashell.service: Consumed 35.097s CPU time, 891.8M memory peak, 66.1M memory swap peak.
Nov 24 20:11:20 Gilgamesh kwin_wayland[5831]: Pageflip arrived after all, 2409ms after the commit
Nov 24 20:11:20 Gilgamesh systemd[5692]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 1.
Nov 24 20:11:20 Gilgamesh systemd[5692]: Starting KDE Plasma Workspace...
Nov 24 20:11:20 Gilgamesh systemd[5692]: Started KDE Plasma Workspace.
About two weeks w/o crashing isn’t bad. It’s certainly better than before.
Please post the complete journal. For large logs that exceed the character limit, you can use Garuda PrivateBin.
