I just installed a new gpu into my computer and re-installed the proper drivers, mesa, xf86, vulkan. The problem I'm having is that my computer is running in slow motion, If I boot with the DP on the gpu it just black screens, but if I use the intergrated graphics it boots up just fine but when I switch the DP back to the gpu then everything is in slow motion.
My specs are: 5600G, B550 by gigabyte, RX 6600 XT.
Stuff I did to get the gpu to work so far (I was black screening) was I changed the intergrated graphics from forces to auto and I set the PCEI from auto to gen 3.
Kernel: 5.15.34-1-lts arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=801484a3-5548-4ad2-bf28-82530730d844 rw rootflags=subvol=@
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550M AORUS PRO v: x.x
serial: <superuser required> UEFI: American Megatrends v: F10
date: 09/18/2020
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA500007
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1795 high: 3981 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1330 2: 1374
3: 1511 4: 3566 5: 1426 6: 1401 7: 1497 8: 1349 9: 1364 10: 3981 11: 1331
12: 1420 bogomips: 93415
STIBP: always-on, RSB filling
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:73ff class-ID: 0300
Device-2: AMD Cezanne vendor: Gigabyte driver: amdgpu v: kernel pcie:
active: DP-3 empty: HDMI-A-3 bus-ID: 0b:00.0 chip-ID: 1002:1638
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
Monitor-1: DP-3 mapped: DisplayPort-2 model: MSI G241 serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 0b:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 0b:00.6 chip-ID: 1022:15e3
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.34-1-lts running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 131.42 GiB (28.2%)
rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
used: 131.42 GiB (28.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.1 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 16.8 C mobo: N/A
GPU: device: amdgpu temp: 25.0 C device: amdgpu temp: 34.0 C mem: 32.0 C
fan: 0 watts: 7.00
Processes: 349 Uptime: 1h 3m wakeups: 0 Memory: 15.1 GiB
used: 3.75 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1171 lib: 328 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-03-18
Last full system update: 2022-04-23 ↻
