Sometimes my screen will randomly go black, coinciding with the gpu spinning up the fans very loudly. I can see that the power stays relatively stable and low. If audio was playing when the screen gos black, it’ll keep on playing. I did manage to send a message with the black screen once too, so I suspect I still have use of everything other than the monitor.
Removing the monitor from the dedicated gpu to the integrated doesn’t help, but if I’ve booted with the monitor plugged into the integrated, then I don’t lose the screen.
This was happening a bit before, I thought it might just be an installation thing, and after I did a system update a few times, it went away. Now it’s come back, and it currently happens every boot after ~10 min (I think, I haven’t clocked it yet.)
garuda-inxi:
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ff218736-6729-4d49-a2d2-0dc7487c0fc3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: ROG STRIX B760-G GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1210
date: 07/14/2023
Info: model: 13th Gen Intel Core i9-13900K bits: 64 type: MST AMCP
microcode: 0x119
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 2189 high: 5528 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 5505 2: 800 3: 800 4: 800
5: 5500 6: 5500 7: 5500 8: 800 9: 5500 10: 800 11: 5500 12: 800 13: 5500
14: 800 15: 5499 16: 5528 17: 800 18: 800 19: 2936 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 191692
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: DP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0300
Device-2: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: Gigabyte
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:2782
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
s-diag: 735mm (28.92")
Monitor-1: DP-1 model: LG (GoldStar) HDR WFHD serial: <filter> built: 2020
res: 2560x1080 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: Mesa Intel Graphics
(RPL-S) direct-render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 10de:22bc class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: b58e:9e84 class-ID: 0300
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
chip-ID: 8086:125c class-ID: 0200
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0033 class-ID: e001
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 1.82 TiB used: 151.23 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 30.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 151.23 GiB (8.1%)
used: 151.23 GiB (8.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.54 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 26.0 C mobo: N/A
Processes: 506 Uptime: 23m wakeups: 0 Memory: total: 64 GiB
available: 62.54 GiB used: 6.57 GiB (10.5%) Init: systemd v: 254
pm: pacman pkgs: 1962 libs: 560 tools: octopi,paru,yay Shell: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.29
System install date: 2023-08-22
Last full system update: 2023-09-26 ↻
I’ve put this in Newbie since I’m a relative noob with Garuda, and don’t really have a clue how to start looking at this. I’ve looked at other threads about screens going black and fans, and haven’t found anything that I think is relevant yet. Apologies if I’ve missed something (like I did the last time I posted a topic).
