Have multiple boot machines have not checked to see if Garuda breaks after update.
PopOS installed Kernel 6.2 & still boots with no problems.
Although can not check Garuda because having this same issue again.
GPGME Error no data when attempting to update
This time it will not update & Update Remote Fix does not fix the issue.
Also Snapper breaks as was happening before as well.
Will reinstall Garuda & see if it works.
Hope this helps to fix these 3 issues that look to be an exploit to packages downloading via payload.
Also system keyboard lag is happening at the time of this post & usually happens in this forum. Maybe some memory leaks or Java Script vulnerabilities.
Much appreciated.
Update Fail before Update Remote Fix
[sudo] password for foiejfie:
error: GPGME error: No data
garuda is up to date
core 156.5 KiB 619 KiB/s 00:00 [------------------------------------] 100%
extra 1741.2 KiB 3.54 MiB/s 00:00 [------------------------------------] 100%
community 7.3 MiB 14.5 MiB/s 00:01 [------------------------------------] 100%
multilib 162.3 KiB 624 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur is up to date
error: failed to synchronize all databases (unexpected error)
chaotic-aur 2.4 MiB 2.47 MiB/s 00:01 [####################################] 100%
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
Failed to update mirrorlist
core downloading...
--> Applying keyring updates before starting full system update..
error: database 'core' is not valid (invalid or corrupted database (PGP signature))
error: database 'extra' is not valid (invalid or corrupted database (PGP signature))
error: database 'community' is not valid (invalid or corrupted database (PGP signature))
error: database 'multilib' is not valid (invalid or corrupted database (PGP signature))
Press enter to exit
Update Remote Fix Failed & Also Update After Failed
Cannot find the mcfly binary, please make sure that mcfly is in your path before sourcing mcfly.fish
.%;888:8898898: foiejfie@fpejkfefjeoijfe
x;XxXB%89b8:b8%b88: ------------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: VivoBook_ASUSLaptop X412DAP_F412DA 1.0
.tt8x .d x88; Kernel: 6.1.14-hardened1-1-hardened
.@8x8; .db: xx@; Uptime: 3 mins
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 1251 (pacman)[stable]
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish 3.6.0
,888S pd! Display: 1920x1080
8X88/ q DE: KDE Plasma 5.27.2
8X88/ WM: KWin (X11)
GBB. WM Theme: Sweet-Dark
x%88 d888@8@X@X@X88X@@XX@@X@8@X. Theme: kvantum-dark Sweet [Plasma], Sweet-Dark [GTK2/3/4]
dxXd dB8b8b8B8B08bB88b998888b88x. Icons: BeautyLine [QT], BeautyLine [GTK2/3/4]
dxx8o .@@;. Terminal: konsole 22.12.3
dx88 .t@x. Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad. CPU: AMD Ryzen 3 3250U (4) @ 2.6 GHz
.d988999889889899dd. GPU: AMD Radeon Vega 3
Memory: 1.32 GiB / 5.75 GiB
╭─foiejfie@fpejkfefjeoijfe in ~
╰─λ update remote fix
I wish to make a complaint.
He has fallen in the water!
This will reset a few configuration files like pacman.conf 🛑Are you sure? (y/n)
y
--2023-03-09 12:16:56-- https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 78.46.178.133, 2a01:4f8:c2c:51e2::1
Connecting to pkgbuild.com (pkgbuild.com)|78.46.178.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4.4M) [application/octet-stream]
Saving to: ‘/tmp/tmp.WrzZ1tEogs’
/tmp/tmp.WrzZ1tEogs 100%[=========================================>] 4.39M 3.38MB/s in 1.3s
2023-03-09 12:16:58 (3.38 MB/s) - ‘/tmp/tmp.WrzZ1tEogs’ saved [4606712/4606712]
.--. Pacman v6.0.1 - libalpm v13.0.1
/ _.-' .-. .-. .-. Copyright (C) 2006-2021 Pacman Development Team
\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
--2023-03-09 12:16:58-- https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
Resolving gitlab.com (gitlab.com)... 172.65.251.78, 2606:4700:90:0:f22e:fbec:5bed:a9b9
Connecting to gitlab.com (gitlab.com)|172.65.251.78|:443... connected.
Length: 2515 (2.5K) [text/plain]
Saving to: ‘/etc/pacman.conf’
/etc/pacman.conf 100%[=========================================>] 2.46K --.-KB/s in 0s
2023-03-09 12:16:59 (11.9 MB/s) - ‘/etc/pacman.conf’ saved [2515/2515]
--2023-03-09 12:16:59-- https://archlinux.org/mirrorlist/all/
Resolving archlinux.org (archlinux.org)... 95.217.163.246, 2a01:4f9:c010:6b1f::1
Connecting to archlinux.org (archlinux.org)|95.217.163.246|:443... connected.
Length: 49351 (48K) [text/plain]
Saving to: ‘/etc/pacman.d/mirrorlist’
/etc/pacman.d/mirrorlist 100%[=========================================>] 48.19K 289KB/s in 0.2s
2023-03-09 12:17:00 (289 KB/s) - ‘/etc/pacman.d/mirrorlist’ saved [49351/49351]
--2023-03-09 12:17:00-- https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 185.199.108.153, 185.199.109.153, 185.199.110.153, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|185.199.108.153|:443... connected.
Length: 2899 (2.8K) [text/plain]
Saving to: ‘/etc/pacman.d/chaotic-mirrorlist’
/etc/pacman.d/chaotic-mirro 100%[=========================================>] 2.83K --.-KB/s in 0s
2023-03-09 12:17:01 (13.9 MB/s) - ‘/etc/pacman.d/chaotic-mirrorlist’ saved [2899/2899]
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/134C478F5384C3EC2821E7A5AEB6FB7C83227A75.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from archlinux.gpg...
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 11 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
-> Disabled 37 keys.
gpg: depth: 0 valid: 1 signed: 11 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 11 signed: 95 trust: 0-, 0q, 0n, 11m, 0f, 0u
gpg: depth: 2 valid: 72 signed: 27 trust: 72-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-03-30
gpg: key A6234074498E9CEE: 4 duplicate signatures removed
gpg: key A6234074498E9CEE: 1 signature reordered
gpg: key A6234074498E9CEE: "Christian Hesse <eworm@archlinux.org>" 8 signatures cleaned
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" not changed
gpg: Total number processed: 2
gpg: unchanged: 1
gpg: signatures cleaned: 8
-> Locally signed 2 keys.
gpg: depth: 0 valid: 1 signed: 12 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 12 signed: 94 trust: 1-, 0q, 0n, 11m, 0f, 0u
gpg: depth: 2 valid: 71 signed: 27 trust: 71-, 0q, 0n, 0m, 0f, 0u
rm: cannot remove '/var/cache/pacman/pkg/*': No such file or directory
core 156.5 KiB 262 KiB/s 00:01 [------------------------------------] 100%
extra 1744.8 KiB 2019 KiB/s 00:01 [------------------------------------] 100%
community 7.3 MiB 6.60 MiB/s 00:01 [------------------------------------] 100%
multilib 162.3 KiB 257 KiB/s 00:01 [------------------------------------] 100%
╭─foiejfie@fpejkfefjeoijfe in ~ as 🧙 took 1m28s
Kernel: 6.1.14-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
root=UUID=05bceb4d-b058-461f-b1fc-5c0e56056f6b rw rootflags=subvol=@
quiet
cryptdevice=UUID=fb551a59-b1f6-4fb4-a902-0a18c46bbd4c:luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c
root=/dev/mapper/luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c quiet splash
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DAP_F412DA
Mobo: ASUSTeK model: X412DAP v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X412DAP.300 date: 12/25/2019
ID-1: BAT0 charge: 16.1 Wh (51.9%) condition: 31.0/37.1 Wh (83.4%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 68
Info: model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1331 high: 1395 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1222 2: 1354
3: 1353 4: 1395 bogomips: 20769
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 55.0 C
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f6 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Vega 3 Graphics
(raven2 LLVM 15.0.7 DRM 3.49 6.1.14-hardened1-1-hardened)
direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound API: ALSA v: k6.1.14-hardened1-1-hardened running: yes
Message: No PCI device data found.
Device-1: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.4:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp3s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 9.37 GiB (3.9%)
model: MZVLQ256HAJD-00000 size: 238.47 GiB block-size: physical: 512 B
rev: FXV7000Q temp: 17.9 C scheme: GPT
ID-1: / raw-size: 45.9 GiB size: 45.9 GiB (100.00%) used: 9.1 GiB (19.8%)
mapped: luks-fb551a59-b1f6-4fb4-a902-0a18c46bbd4c
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 277.4 MiB (55.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
used: 9.1 GiB (19.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
ID-5: /var/tmp raw-size: 45.9 GiB size: 45.9 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.8 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): cpu: 0
Processes: 212 Uptime: 21m wakeups: 1 Memory: 5.75 GiB
used: 2.37 GiB (41.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1251
libs: 330 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-01-04
Last full system update: 2023-03-03
Failed units: dev-disk-by-diskseq-1-part2.swap
