I did an update, it failed to finish (seemed to hang on joplin desktop if i am remembering right?). Power cycled and now get dropped into emergency mode. journalctl is not a known command.
Tried some snapshots but older ones fail to start the Light Display Manager and all fail to start the pacman files database update.
are there any good options or just reinstall garuda?
If your root partition can’t be mounted, you just won’t have access to those files.
Boot up into a live session, press the chroot button in garuda welcome and once you have a root shell after a successful chroot, you can try a normal update or if that fails, try reinstalling all packages via update remote reinstall
If the update fails, you could try to btrfs check your partition or eg fsck other partitions.
If you have other partitions mounted, you could try to give a look at the /etc/fstab vs the uuids in blkid...
