Hello,
First I want to say how much I love Garuda Linux. I have always preferred Arch distros, but Garuda runs so well, and performs great on all my systems. With that in mind I have one system I cant get to completely work.
That is my Surface Pro 5. Garuda in general runs great in laptop mode, however unfortunately I cant seem to work out how to get the touchscreen to work.
I have tried:
- Running in Xorg
*Loading the hid_multitouch module in rc.local (and it is running) - Running in in Wayland (Currently on that trying, touchscreen shows no device)
- I have tried installing libwacom.surface
- I have looked at xinput -list and it shows no touchscreen
- I have looked at
libwacom-list-local-devicesand it shows no known devices
*I have tried to runiptsd /dev/hidraw0and it reports no display config (this may be something and I am trying to determine what values I may need an where (also not as versed in Wayland as I am Xorg so may switch back) ---- Also got/dev/hidraw0fromdmesgoutput.
I have tried other distros (Endeavor most recently) and most of them work as soon as I install and boot the surface kernel. But I really only want this on Garuda since it is far superior ![]()
I have also explored udev rules making sure something wasnt getting blacklisted (not that it would with out me doing it).
I have also searched the forums here and on the Arch wiki and tried everything I can find in both locations to no avail.
At this point I am a bit lost as to why I cant get this to work. And why from a Garuda standpoint it seems at least at some level there is no touchscreen.
Again Garuda runs great on this tablet, just only as a laptop with the keyboard/touchpad cover installed, really would love touchscreen
I am running the latest "Raptor" 230305 updated to today (10 March 2023)
If anyone has any advise or pointers on how to get the touchscreen to show (in either Xorg or Wayland) I would be eternally grateful. Also let me know if there is a guide on what to possibly configure in either Wayland or Xorg if that is my issue.
Thanks in advance and below is the output of garuda-inxi:
╭─loki@Kaida in ~
╰─λ garuda-inxi
Kernel: 6.2.2-arch1-2-surface arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-surface
root=UUID=0f78d28a-4e79-4784-850c-353f43d5ae4c rw rootflags=subvol=@
resume=UUID=30a3cc19-8c96-4a63-851b-18c781c41aba loglevel=3
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Type: Laptop System: Microsoft product: Surface Pro
v: 124000000000000000000000D:0B:09F:5C:09P:38S:01E:0
Mobo: Microsoft model: Surface Pro serial: <superuser required>
UEFI: Microsoft v: 238.167.768 date: 05.07.2014
ID-1: BAT1 charge: 35.0 Wh (100.0%) condition: 35.0/45.0 Wh (77.9%)
volts: 8.6 min: 7.6 model: SMP M1009169 type: Li-ion serial: <filter>
status: full cycles: 93
Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 699 high: 700 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 699 3: 700 4: 700
bogomips: 21607
Device-1: Intel HD Graphics 620 vendor: Microsoft driver: i915 v: kernel
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
Monitor-1: eDP-1 res: 2027x1351 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0
chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host driver: ipu3-cio2 alternate: ipu3_cio2
bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
Sound API: ALSA v: k6.2.2-arch1-2-surface running: yes
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 11ab:2b38 class-ID: 0200
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 1-1.4.4.2:6 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Marvell Bluetooth and Wireless LAN Composite type: USB
driver: btusb v: 0.8 bus-ID: 1-5:7 chip-ID: 1286:204c class-ID: e001
address: <filter>
Local Storage: total: 704.61 GiB used: 10.51 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 0AMS0102 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: USB3.2 FLASH DRIVE
size: 466.14 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 10.51 GiB (4.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C pch: 37.0 C mobo: N/A
Processes: 206 Uptime: 13m wakeups: 2 Memory: 7.68 GiB
used: 3.27 GiB (42.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1485
libs: 379 tools: octopi,pamac,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-09
Last full system update: 2023-03-10
╭─loki@Kaida in ~ took 2s
╰─λ cat /etc/rc.local
File: /etc/rc.local
modprobe hid_multitouch
╭─loki@Kaida in ~ took 26ms
╰─λ xinput -list
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ xwayland-pointer:12 id=6 [slave pointer (2)]
⎜ ↳ xwayland-relative-pointer:12 id=7 [slave pointer (2)]
⎜ ↳ xwayland-pointer-gestures:12 id=8 [slave pointer (2)]
⎜ ↳ xwayland-touch:12 id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ xwayland-keyboard:12 id=9 [slave keyboard (3)]
╭─loki@Kaida in ~ took 8ms
╰─λ libwacom-list-local-devices
Failed to find any devices known to libwacom.
╭─loki@Kaida in ~ took 735ms
╰─λ sudo iptsd /dev/hidraw0
[sudo] password for loki:
[09:02:09.898] [error] No display config for this device was found!
╭─loki@Kaida in ~ as 🧙 took 8s
[🔴] × garuda-inxi
microcode: 0xF0
Speed (MHz): avg: 700 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 21607
address: <filter>
lanes: 2 type: SSD serial: <filter> rev: 0AMS0102 temp: 41.9 C scheme: GPT
System Temperatures: cpu: 54.0 C pch: 42.0 C mobo: N/A
Processes: 199 Uptime: 30m wakeups: 2 Memory: 7.68 GiB
used: 3.38 GiB (44.0%) Init: systemd v: 253 default: graphical
Garuda (2.6.15-1):
