Hi, I’m a new Garuda and Linux user since three days ago.
I used to have windows mainly for games (I use mac for work) and I wanted to switch to Linux tired of microsoft.
I am currently dual booting, since I’m still testing the environment.
I’ve been messing around with heroic launcher to boot games previously installed: i have my windows drive on one ssd, and other several external drives; decided to test this on a drive without the win system installed.
I experienced a freeze while playing a game (The Last Spell, on GOG):
everything on screen freezing, audio keeps going regularly, computer totally unresponsive. Waited a couple minutes, tried all key combinations I could source online but nothing would work and had to hard reboot.
Afterwards, three disks on the computer where “impossible to mount”; had to login into windows and run chkdsk
on all three, which fixed it. (those were the three ssd on which i keep applications, includind the win system drive).
I was having problems with reading the original save file from the game, which doesn’t save in cloud, and figured I’d better not mess with those directory, so decided to restore what changes I made and just play a new game.
The freeze happend again, in the same way, however no problem with the drives this time.
Last time, the freeze happened while just watching netflix, with another browser open doing nothing. The mode was slightly different: the playback froze, video and audio, from the player. Than it stuttered for a fraction of a second, and froze again. Everything unresponsive, had to hard reboot. This happened over two days. I’ve checked system temperatures and they were nothing unusual.
I’ve checked some other threads about seemingly random freezes, but they were describing different situation (audio also freezing, black screens, which did not happen). One thread which looked promising got abandoned, they were refering to an older post on the arch forum suggesting to downgrade nvidia graphics driver to 460xx, or changing kernel (which I still don’t really understand as a process and has led me to ask here).
I want to point out that a deciding factor that made me want to try linux is a freeze I got on windows while playing the same game which happened in the exact same fashion as described for the first two. Which makes me suspect this might have something to do with the gpu rather than the software but it’s pure conjecture.
I also tried to run journalctl -p3
and encountered A LOT of errors, which really I wouldn’t know where to start to troubleshoot. I’ll post it here below the inxi.
i tried to be as thorough as possible, hope I was not too thorough. Let me know if there’s any other relevant info I left out. Thank you very much in advance
Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=f85fd176-bb04-4ae5-825e-710a7ed6402a rw rootflags=subvol=@
quiet resume=UUID=7de06f12-1e0a-479b-9fff-1e950a46da81 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-F GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 1302 date: 09/02/2019
Info: model: Intel Core i5-9600KF bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x102
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4400 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 4400 2: 4400 3: 4400 4: 4400 5: 4400 6: 4400
bogomips: 44398
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 2 link-max: lanes: 16 ports: active: none
off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:1f06
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:10
d-rect: 5760x2160 display-ID: 0
Monitor-1: DP-3 pos: right model: ASUS VG289 serial: <filter> built: 2023
res: mode: 3840x2160 hz: 60 scale: 170% (1.7) to: 2259x1271 dpi: 157
gamma: 1.2 size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9
modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 pos: primary,left model: Dell S2240L serial: <filter>
built: 2013 res: mode: 1920x1080 hz: 60 scale: 105% (1.05) to: 1829x1029
dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51") diag: 546mm (21.5")
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 SUPER driver: nvidia v: 570.144 device-ID: 10de:1f06
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i4 driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 1235:800a
class-ID: fe01
API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api tools: N/A
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 6.58 TiB used: 33.59 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR311 temp: 42.9 C
model: WD40EFAX-68JH4N1 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A83 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480BX500SSD1
tech: SSD serial: <filter> fw-rev: 054 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 250GB
tech: SSD serial: <filter> fw-rev: BB0Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD1002FAEX-00Z3A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Crucial model: CT500MX500SSD1
ID-1: / raw-size: 198.21 GiB size: 198.21 GiB (100.00%)
used: 33.58 GiB (16.9%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 612 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 198.21 GiB size: 198.21 GiB (100.00%)
ID-4: /var/log raw-size: 198.21 GiB size: 198.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 198.21 GiB size: 198.21 GiB (100.00%)
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
ID-2: swap-2 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 44.2 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 32 GiB available: 31.25 GiB used: 5.44 GiB (17.4%)
Processes: 317 Power: uptime: 26m states: freeze,mem,disk suspend: deep
Packages: 1970 pm: pacman pkgs: 1964 libs: 473 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date: 2025-05-01
Last full system update: 2025-05-03
journalctl -p3:
mag 03 13:48:55 home-tower-station systemd-tmpfiles[960]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
mag 03 13:48:55 home-tower-station kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
mag 03 13:48:55 home-tower-station kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
mag 03 13:48:55 home-tower-station kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
mag 03 13:48:55 home-tower-station kernel: ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
mag 03 14:01:52 home-tower-station dbus-broker-launch[972]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 520d284ce235427eb54ab4ec1529100e --
mag 03 14:06:40 home-tower-station kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mag 03 14:06:43 home-tower-station kernel:
mag 03 14:06:45 home-tower-station systemd-sslh-generator: Configuration directory '/etc/sslh/' does not exist! No units generated.
mag 03 14:06:45 home-tower-station systemd-udevd[682]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
mag 03 14:06:46 home-tower-station systemd-tmpfiles[963]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
mag 03 14:06:47 home-tower-station kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
mag 03 14:06:47 home-tower-station kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
mag 03 14:06:47 home-tower-station kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
mag 03 14:06:47 home-tower-station kernel: ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
mag 03 14:15:36 home-tower-station plasmashell[36388]: aurorae: Couldn't find QML Decoration ""
mag 03 14:15:36 home-tower-station org_kde_powerdevil[36435]: [ 36435] Error(s) opening ddc devices
mag 03 14:15:36 home-tower-station org_kde_powerdevil[36435]: [ 36435] Error OK(0): success opening /dev/i2c-5
mag 03 14:16:02 home-tower-station kioworker[38015]: qt.imageformats.tiff: "TIFF directory is missing required \"StripOffsets\" field"
mag 03 14:16:22 home-tower-station dbus-broker-launch[976]: Activation request for 'org.freedesktop.Avahi' failed.
mag 03 14:16:22 home-tower-station plasmashell[36388]: qml: '/usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/tools/gdbus_get_signal.sh' session luisbocanegr>
mag 03 14:16:22 home-tower-station plasmashell[36388]: qml: python3 '/usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/tools/service.py' 3 11 15 1
mag 03 14:16:22 home-tower-station plasmashell[36388]: qml: python3 '/usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/tools/service.py' 25 26 15 1
mag 03 14:16:22 home-tower-station dbus-broker-launch[36202]: Activation request for 'org.freedesktop.portal.Desktop' failed.
mag 03 14:17:02 home-tower-station dbus-broker-launch[976]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 270eb1fde6b64d689a1b56431ab8189e --
mag 03 14:20:06 home-tower-station kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mag 03 14:20:09 home-tower-station kernel:
mag 03 14:20:11 home-tower-station systemd-sslh-generator: Configuration directory '/etc/sslh/' does not exist! No units generated.
mag 03 14:20:11 home-tower-station systemd-udevd[671]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
mag 03 14:20:12 home-tower-station systemd-tmpfiles[958]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
mag 03 14:20:13 home-tower-station kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
mag 03 14:20:13 home-tower-station kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
mag 03 14:20:13 home-tower-station kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
mag 03 14:20:13 home-tower-station kernel: ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
mag 03 14:20:21 home-tower-station 30-systemd-environment-d-generator[3334]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignor>
mag 03 14:20:21 home-tower-station 30-systemd-environment-d-generator[3614]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignor>
mag 03 14:20:25 home-tower-station plasmashell[3796]: aurorae: Couldn't find QML Decoration ""
mag 03 14:20:27 home-tower-station org_kde_powerdevil[3840]: [ 3840] Error detecting VCP version using VCP feature xDF: Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, ca>
mag 03 14:20:27 home-tower-station org_kde_powerdevil[3840]: [ 3840] Error(s) opening ddc devices
mag 03 14:20:27 home-tower-station org_kde_powerdevil[3840]: [ 3840] Error OK(0): success opening /dev/i2c-5
mag 03 14:20:38 home-tower-station sudo[5453]: thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 03 14:42:58 home-tower-station dbus-broker-launch[967]: Activation request for 'org.freedesktop.Avahi' failed.
mag 03 14:42:58 home-tower-station dbus-broker-launch[3611]: Activation request for 'org.freedesktop.portal.Desktop' failed.
mag 03 14:42:58 home-tower-station plasmashell[3796]: qml: '/usr/share/plasma/plasmoids/luisbocanegra.panel.colorizer/contents/ui/tools/gdbus_get_signal.sh' session luisbocanegra>
...skipping...
mag 04 20:44:34 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mag 04 20:44:35 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mag 04 20:44:35 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mag 04 20:44:35 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mag 04 20:44:36 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mag 04 20:44:36 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mag 04 20:44:36 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mag 04 20:44:37 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mag 04 20:44:37 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mag 04 20:44:37 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mag 04 20:44:38 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mag 04 20:44:38 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mag 04 20:44:38 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
mag 04 20:44:39 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
mag 04 20:44:39 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
mag 04 20:44:39 home-tower-station kwin_wayland[3678]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
-- Boot dc52f84b69e14535b44fb676ed82c2a9 --
mag 04 20:45:03 home-tower-station kernel:
mag 04 20:45:05 home-tower-station systemd-sslh-generator: Configuration directory '/etc/sslh/' does not exist! No units generated.
mag 04 20:45:05 home-tower-station systemd-udevd[676]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
mag 04 20:45:06 home-tower-station systemd-tmpfiles[963]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
mag 04 20:45:07 home-tower-station kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
mag 04 20:45:07 home-tower-station kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
mag 04 20:45:07 home-tower-station kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
mag 04 20:45:07 home-tower-station kernel: ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
mag 04 20:45:15 home-tower-station 30-systemd-environment-d-generator[3363]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignor>
mag 04 20:45:16 home-tower-station 30-systemd-environment-d-generator[3661]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignor>
mag 04 20:45:19 home-tower-station wireplumber[3774]: spa.alsa: can't open control for card hw:3: No such file or directory
mag 04 20:45:20 home-tower-station plasmashell[3844]: aurorae: Couldn't find QML Decoration ""
mag 04 20:45:22 home-tower-station org_kde_powerdevil[3888]: [ 3888] Error detecting VCP version using VCP feature xDF: Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, ca>
mag 04 20:45:22 home-tower-station org_kde_powerdevil[3888]: [ 3888] Error(s) opening ddc devices
mag 04 20:45:22 home-tower-station org_kde_powerdevil[3888]: [ 3888] Error OK(0): success opening /dev/i2c-5
mag 04 20:45:25 home-tower-station kwin_wayland[3672]: kwin_scene_opengl: Invalid framebuffer status: "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
mag 04 20:46:09 home-tower-station sudo[7126]: thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:03:29 home-tower-station sudo[31560]: thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:07:59 home-tower-station sudo[37754]: thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:08:01 home-tower-station sudo[37819]: thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:11:12 home-tower-station sudo[43161]: thomas : a password is required ; TTY=pts/1 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:11:19 home-tower-station sudo[43463]: thomas : a password is required ; TTY=pts/1 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 04 21:32:25 home-tower-station sudo[73240]: thomas : a password is required ; TTY=pts/2 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
