Garuda Zen Mokka - apparently random System freezes - lots of errors
After some research, the only relevant thing I found is this thread suggesting performance mode may have an impact on this problem.
However I can’t find any documentation regarding hash tables outside of programming software. Nvidia forums have a couple threads regarding driver errors and some users report the same issue, among others, but it just gets mentioned.
From my understanding, since hash table resizing/resetting is possible, performance settings might influence the way the system handles RAM (in this case vRAM) in limiting how much can be used.
I will wait for some feedback and/or other sources before trying to change more settings.
At this moments the only things mentioned that look reasonable to me would be switching kernel and/or changing power manager and tweaking power management modes/settings. But I wouldn’t know where it would be better to start.
IMHO
Do them as follows:
  1. Change Kernels
  2. Tweak power management settings
  3. Change power managers
If you are gonna do these. Should you do these first disregarding @nepti 's advice? I don’t think so because he certainly is a wizard :wink:.
Should you even do these? Idk. I would probably be bald pulling my hairs at this point.
I’ve gone bald reading this thread - yikes!
:face_with_peeking_eye:
If your system now works longer without issues and you no longer get a “GPU has fallen of the bus” error message, then the correct reinstallation of the GPU should have fixed this source of error.
This is a bug in the nvidia driver, try switching to an x11 session (you can switch between wayland and x11 at the bottom left of the login screen) and check if everything works there without issues.
Hello, sorry for not updating but I’ve been really busy.
Last things I did were switching to performance energy mode and switching to x11 session.
I’ve encountered no freezes so far, but there’s more. Both monitors look very stuttery as if there’s a massive CPU load. I’ve checked CPU loads and they look normal, however if I, for example, scroll through a series of hover menus really quickly, the cpu load goes to the stars (and the refreshing of those menus is very very laggy)
I’m starting to become really frustrated with all this… It’s become a very unenjoyable experience and basically I’m losing the will to turn on the computer since it seems to never end
But wait! There’s more!
Today I booted up and got a freeze at boot on this screen:
error log:
mag 23 20:49:15 home-tower-station kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
mag 23 20:49:15 home-tower-station kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mag 23 20:49:18 home-tower-station kernel:
mag 23 20:49:20 home-tower-station systemd-sslh-generator: Configuration directory '/etc/sslh/' does not exist! No units generated.
mag 23 20:49:21 home-tower-station systemd-udevd[679]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
mag 23 20:49:21 home-tower-station systemd-tmpfiles[951]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
mag 23 20:49:22 home-tower-station kernel: nvidia-gpu 0000:02:00.3: i2c timeout error e0000000
mag 23 20:49:22 home-tower-station kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
mag 23 20:49:22 home-tower-station kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
mag 23 20:49:22 home-tower-station kernel: ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
mag 23 20:50:32 home-tower-station 30-systemd-environment-d-generator[7529]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
mag 23 20:50:33 home-tower-station 30-systemd-environment-d-generator[7672]: /home/thomas/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
mag 23 20:50:37 home-tower-station org_kde_powerdevil[8008]: [  8008] Error(s) opening ddc devices
mag 23 20:50:37 home-tower-station org_kde_powerdevil[8008]: [  8008] Error OK(0): success opening /dev/i2c-5
mag 23 20:50:39 home-tower-station plasmashell[7917]: aurorae: Couldn't find QML Decoration  ""
mag 23 20:50:41 home-tower-station sudo[8444]:   thomas : a password is required ; TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
mag 23 20:51:26 home-tower-station sudo[11073]:   thomas : a password is required ; TTY=pts/1 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/true
Sidenot: when i Right Click, the contextual menu always happens to open up on the other monitor. I don’t know what to think anymore
