Just restart your pc and share output of
lsblk
And present it as text, not screenshot.
lsblk
Dude just click Next!
If you have issue during the install,
just try as I mentioned.
Close the Calamares( the install program window)
To open KDE Partition Manager --> Right-Click on Desktop -->
Show Krunner --> Search.. --> type: Partition --> Open it.
After you finished Partitioning --> Click on Apply button (at the left corner)
Close KDE Partition Manager
Restart your Notebook
dude i just want to say thank you so much for having so much patience with me I really appreciate! you have no idea how much I appreciate that
You're Welcome!
ok it ran into a error
command 'grub-install --target=x84_64-efi-directory=/boot/eft --bootloader-id=Garuda --force' returned non-zero exit status 1.
installing for x84_64-efi platform.
could not prepare variable: no space left on device
grub-install" error: efibootmgr failed to register the boot entry: input/output error.
traceback:
File "/usr/lib/calamares/modules/bootloader/main.py", line 447, in run prepare_bootloader(fw_type)
File "usr/lib/calamares/modules/bootloader/main.py", line 449, in preare_bootloader
File "<string>", line 6, in <module>
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
greetings SGS
share output of
lsblk
do i put that in the Konsole?
Yes. This will show your partition table.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 15.2M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 306M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1005.4M 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 679.9M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 28.9G 0 disk /run/miso/bootmnt
├─sda1 8:1 1 2.1G 0 part
└─sda2 8:2 1 4M 0 part
zram0 253:0 0 2.6G 0 disk [SWAP]
zram1 253:1 0 2.6G 0 disk [SWAP]
zram2 253:2 0 2.6G 0 disk [SWAP]
zram3 253:3 0 2.6G 0 disk [SWAP]
zram4 253:4 0 2.6G 0 disk [SWAP]
zram5 253:5 0 2.6G 0 disk [SWAP]
zram6 253:6 0 2.6G 0 disk [SWAP]
zram7 253:7 0 2.6G 0 disk [SWAP]
zram8 253:8 0 2.6G 0 disk [SWAP]
zram9 253:9 0 2.6G 0 disk [SWAP]
zram10 253:10 0 2.6G 0 disk [SWAP]
zram11 253:11 0 2.6G 0 disk [SWAP]
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 242.1G 0 part /tmp/calamares-root-4ujdctcy/var/tmp
└─nvme0n1p2 259:2 0 260M 0 part /tmp/calamares-root-4ujdctcy/boot/efi~~~
Again
Simply give more space to efi partition (500mb instead of 260mb)
sorry didn't see that you edited it until after you posted the second time
same error again
├─nvme0n1p1 259:1 0 500M 0 part /tmp/calamares-root-814uyh2_/boot/efi
└─nvme0n1p2 259:2 0 242.1G 0 part /tmp/calamares-root-814uyh2_/var/tmp ~~~
Show screenshot of calameres partition.
how do i do that i tried on my phone and it wouldn't let me post over 10 mb?
Use prtscrn button on keyboard
Share output of
efibootmgr
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0002
Boot0001* UEFI: USB DISK 3.0 PMAP
Boot0002* UEFI: USB DISK 3.0 PMAP, Partition 2~~~
Ok so it's not the issue.
Check your BIOS settings:
Looking for "Secure Boot" entry if its enabled disable it.
I have HP Elitebook with an old UEFI system,
In my situation with the same error the solution was Changing the Boot Order,
and Saved it Restart my laptop, than changed the Boot Order back, restart and after install was success.
