Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 12.2.0
root=UUID=0835c123-90c3-472c-9a1b-dfcf8707ad14 rw
rootflags=subvol=@ quiet quiet splash
resume=UUID=af7fcfee-ac9e-475a-92f0-39334ebc060a
Desktop: i3 v: 4.20.1 info: i3bar, polybar vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux
Type: Laptop System: Dell product: G5 5590 v: N/A
serial: <superuser required> Chassis: type: 10
Mobo: Dell model: 0CRKJ6 v: A00
serial: <superuser required> UEFI: Dell v: 1.20.0
date: 07/08/2022
ID-1: BAT0 charge: 44.7 Wh (100.0%) condition: 44.7/60.0
Wh (74.6%) volts: 17.1 min: 15.2 model: LGC-LGC3.985
DELL 8622M99 type: Li-ion serial: <filter> status: full
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Coffee Lake gen: core 9 built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32
KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 1100 high: 2600 min/max: 800/4500
scaling: driver: intel_pstate governor: powersave cores:
1: 801 2: 800 3: 800 4: 2600 5: 800 6: 2600 7: 800
8: 800 9: 801 10: 800 11: 800 12: 800 bogomips: 62399
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: conditional
cache flushes, SMT vulnerable
Type: mmio_stale_data mitigation: Clear CPU buffers;
SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store
Bypass disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers
and __user pointer sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Dell driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Dell driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing
code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0c45:671f
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: Picom
v: git-7e568 driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,intel,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0860 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell
alternate: snd_soc_skl,snd_sof_pci_intel_cnl
Device-2: NVIDIA TU116 High Definition Audio
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek vendor: Dell driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless
Network Adapter vendor: Dell driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 3d:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8
bus-ID: 1-14:5 chip-ID: 0cf3:e007 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up
address: <filter>
Local Storage: total: 588.73 GiB used: 20.86 GiB (3.5%)
SMART Message: Required tool smartctl not installed.
Check --recommends
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3 NVMe 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 92103051
temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston
model: SA400S37120G size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0005 scheme: GPT
ID-1: / raw-size: 94.51 GiB size: 94.51 GiB (100.00%)
used: 20.85 GiB (22.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB
(99.80%) used: 7.6 MiB (2.5%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 94.51 GiB size: 94.51 GiB
(100.00%) used: 20.85 GiB (22.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 94.51 GiB size: 94.51 GiB
ID-5: /var/tmp raw-size: 94.51 GiB size: 94.51 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB
(0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.98 GiB used: 0
KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 44.0 C pch: 47.0 C mobo: N/A
Processes: 329 Uptime: 52m wakeups: 7209
Memory: 15.44 GiB used: 3.81 GiB (24.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pacman: 1284 lib: 329 Shell: Zsh
v: 5.9 running-in: xfce4-terminal inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-28
Last full system update: 2022-08-31 ↻
Guys, I'm having problems with updating and managing Garuda with the System Assistants.
When I try to do something in the assistants, these messages appear:
**AUTHENTICATING FOR org.garuda.libs.pkexe.polyce.run Authentication is required to install software**
**Polkit-agent-helper-1: error response to Policykit daemon: GDbus.Error:org.freedesktop.Policykit1.Error.failed: No session for cookie**
**Error executing command as another user: Not authorized**
**This incident has been reported.**
