Hey all,
So, I think it's important to denote that I'm brand new to Linux, a friend was gaming on his garuda lappy, and praising how gaming is finally viable on Linux. I had always thought about trying Linux, but gaming is really al I do on the pc. So, now that it's viable I decided to go ahead and grab the Garuda Dr460nized gaming edition, chunked off a decent sized partition, IDK if this is relevant but I formatted said partition in Fat32, and then began the install. I chose to replace a partition, and selected my newly chunked partition, and it install with no problems. Rebooted, and was met with the Setup Assistant which instantly told me to update, I did, and that's where it errored out. Here's the garuda-inxi file(?) that the template asked for...
[spoiler]
â•─sansdeity46290@Firewyrm in ~
╰─λ garuda-inxi
root=UUID=98fc3c4d-2f37-483c-b890-c8634fcc798f rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE WIFI serial: <superuser required>
UEFI: American Megatrends LLC. v: F37d date: 07/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3759 high: 4340 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3598 2: 3635
3: 3595 4: 3700 5: 3588 6: 4311 7: 3694 8: 3598 9: 4340 10: 3655 11: 3700
12: 3700 bogomips: 88799
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0d:00.0
chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-3 mapped: DisplayPort-2 model: AOC U34G2G4R3
serial: <filter> built: 2020 res: 3440x1440 hz: 60 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 6750 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.13-zen-1-zen) direct-render: Yes
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 1102:0012 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-5:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 2.29 TiB used: 7.4 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: RKT30Q.1 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 7.39 GiB (3.7%)
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 17.1 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 200 GiB size: 200 GiB (100.00%)
used: 7.39 GiB (3.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.2 C mobo: 36.0 C gpu: amdgpu temp: 51.0 C
mem: 46.0 C
Processes: 332 Uptime: 3m wakeups: 0 Memory: 15.54 GiB
used: 2.55 GiB (16.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1783
libs: 517 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-05-29
Last full system update: 2023-05-29
[/spoiler]
and then here's a screenshot of the output from the terminal where it errored out.
(If someone can suggest a better way to use privatebin, I'd appreciate the advice. I didn't really know what I was doing and just asked chatgpt)
Any help would be amazing as I'm not entirely sure how to even query a google search for the problem. I'm sorry if I put this in the wrong spot, or am overstepping in any way. It's just that trying to learn Linux is like trying to drink from a firehose. Also, do spoiler tags not work here, or did I do it wrong? TIA
