root=UUID=cc659700-4bd5-4cbc-931e-79c9f3b6542a rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3003
date: 12/04/2020
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3785 high: 3800 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3643
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800
20: 3800 21: 3800 22: 3599 23: 3800 24: 3800 bogomips: 182390
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0c:00.0 chip-ID: 1002:731f
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2030x571mm (79.92x22.48")
s-diag: 2109mm (83.02")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: Samsung LU28R55 serial: <filter> built: 2021 res: 3840x2160 hz: 60
dpi: 154 gamma: 1.2 size: 632x360mm (24.88x14.17") diag: 727mm (28.6")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Samsung LU28R55
serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 154 gamma: 1.2
size: 632x360mm (24.88x14.17") diag: 727mm (28.6") ratio: 16:9 modes:
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (navi10 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:731f memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 3-3.1:6 chip-ID: 0951:16a4 class-ID: 0300
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:11b1
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.29 TiB used: 989.88 GiB (42.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.0 temp: 45.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 989.86 GiB (53.2%)
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 29.7 MiB (1.5%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 989.86 GiB (53.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 87 MiB (0.3%) priority: 100
System Temperatures: cpu: 35.0 C mobo: 37.0 C gpu: amdgpu temp: 41.0 C
mem: 62.0 C
Fan Speeds (rpm): cpu: 1109 gpu: amdgpu fan: 65535
Processes: 477 Uptime: 9h 27m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 7.4 GiB (23.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2110 libs: 580 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-04-19
Last full system update: 2023-10-30 ↻
Running garuda-update currently shows the following error, how is the best way to resolve this? Being as it involves the garuda-dr460nized package I’d rather not break everything.
I used pacman -Syu which allowed me to manually say no to the replace and let everything else install.
garuda-update
:: Synchronising package databases...
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
blackarch is up to date
warning: insomnia: local (2023.5.8-2) is newer than chaotic-aur (8.3.0-1)
warning: kde-servicemenus-pdf-encrypt-decrypt: local (1-1.4) is newer than chaotic-aur (1-1)
:: Replace sweet-kde-theme-git with chaotic-aur/plasma5-themes-sweet-kde-git? [Y/n] y
:: Replace sweet-theme-full-git with chaotic-aur/plasma5-themes-sweet-full-git? [Y/n] y
resolving dependencies...
:: removing sweet-theme-full-git breaks dependency 'sweet-theme-full-git' required by garuda-dr460nized
I have same problem
root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw rootflags=subvol=@
quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB35 serial: <filter> UEFI: FUJITSU // Phoenix
v: Version 1.13 date: 11/18/2013
ID-1: BAT0 charge: 0.7 Wh (100.0%) condition: 0.7/4.5 Wh (14.5%) volts: 12.3
min: 10.8 model: PTL CP651527-01 type: Li-ion serial: <filter>
status: not charging cycles: 277
Info: model: Intel Core i7-4702MQ socket: rPGA988B (On Board) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x16
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2199 high: 2200 min/max: 800/3200 base/boost: 2200/2200
scaling: driver: intel_cpufreq governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 2195 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200
7: 2200 8: 2200 bogomips: 35119
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 10f1:1a58 class-ID: 0e02
Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.2
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Fujitsu . 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Server-1: PipeWire v: 0.3.83 status: n/a (root, process) with:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
vendor: Fujitsu driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: virbr2 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:07dc
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 931.51 GiB used: 162.97 GiB (17.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 23 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 206d 4h cycles: 2197
written: 11.8 TiB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
used: 162.97 GiB (17.7%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
used: 694 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 283.5 MiB (3.6%)
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 68.0 C pch: 54.0 C mobo: N/A
Processes: 291 Uptime: 1d 3m wakeups: 7 Memory: total: 8 GiB
available: 7.67 GiB used: 4.57 GiB (59.6%) igpu: 32 MiB Init: systemd v: 254
Packages: pm: pacman pkgs: 1895 libs: 459 tools: pamac,paru
inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2021-03-13
Last full system update: 2023-10-29
Total system updates: 1515
--> Updates per week: 11
error log:
download di garuda in corso...
download di core in corso...
download di extra in corso...
download di multilib in corso...
download di chaotic-aur in corso...
SGS
30 October 2023 19:11
4
The “fix” is on the road. Just wait some hours.
:: Synchronizing package databases…
core is up to date
extra is up to date
chaotic-aur 2.6 MiB 804 KiB/s 00:03 [------------------------------------] 100%
→ Refreshing mirrorlists using rate-mirrors, please be patient…
garuda downloading…
core downloading…
extra downloading…
multilib downloading…
chaotic-aur downloading…
blackarch downloading…
:: Starting full system upgrade…
resolving dependencies…
looking for conflicting packages…
:: removing sweet-theme-full-git breaks dependency ‘sweet-theme-full-git’ required by garuda-dr460nized
i am facing the same problem how can i fix this
SGS
31 October 2023 05:27
6
SGS:
Developers also have to sleep sometimes. It won’t be long and everything will be back to normal.
system
Closed
2 November 2023 05:33
8
