Garuda system is asking me for wifi password every time
why my system is asking me for wifi password every time when i turn on it?
is there no auto connect option?
Yes, there is. Mine never asks for the WiFi password. :grinning:
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Kernel: 6.4.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=ee83ab19-5226-4c7d-bed7-e7e6f5e99335 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X411QA v: 1.0
Mobo: ASUSTeK model: X411QA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X411QA.307 date: 06/09/2021
ID-1: BAT0 charge: 11.5 Wh (53.5%) condition: 21.5/42.1 Wh (51.1%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 520
Info: model: AMD A12-9720P RADEON R7 12 COMPUTE CORES 4C+8G bits: 64
type: MT MCP arch: Excavator level: v3 note: check built: 2015
process: GF 28nm family: 0x15 (21) model-id: 0x65 (101) stepping: 1
microcode: 0x600611A
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2923 high: 3154 min/max: 1400/2700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3154 2: 2700
3: 2700 4: 3141 bogomips: 21559
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
built: 2014-19 ports: active: HDMI-A-1 empty: DP-1 bus-ID: 00:01.0
chip-ID: 1002:9874 class-ID: 0300
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 358x202mm (14.09x7.95")
s-diag: 411mm (16.18")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) TV
serial: <filter> built: 2015 res: 1360x768 hz: 60 dpi: 49 gamma: 1.2
size: 708x398mm (27.87x15.67") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 1280x720 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon R7 Graphics (carrizo
LLVM 15.0.7 DRM 3.52 6.4.1-zen2-1-zen) direct-render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
API: ALSA v: k6.4.1-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: IMC Networks driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:4 chip-ID: 13d3:3491
Local Storage: total: 476.94 GiB used: 24.6 GiB (5.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1102 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20180000 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 156.84 GiB size: 156.84 GiB (100.00%)
used: 24.58 GiB (15.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.9 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 156.84 GiB size: 156.84 GiB (100.00%)
ID-4: /var/log raw-size: 156.84 GiB size: 156.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 156.84 GiB size: 156.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.22 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 69.0 C mobo: N/A gpu: amdgpu temp: 69.0 C
Fan Speeds (RPM): cpu: 500
Processes: 235 Uptime: 22m wakeups: 1 Memory: available: 7.22 GiB
used: 2.52 GiB (34.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1866
libs: 549 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date:     2023-07-04
Last full system update: 2023-07-06
Try this:
there is no network manager
It’s a standard for KDE
