Do you use GNOME applications? Then yes.
You dont use GNOME applications? Delete it
(as you can see most of the settings are GNOME related, epiphany, gedit -> all GNOME settings)
Wayfire does use GNOME applications, which is why its included
I see you set the GTK3 via that too? I do have GTK3 apps so I'll have it with just that?
GTK3 is set here already, so there is no need to include that
OK! No need for the file then! Thank you!
For wayland you have to do it via scheme
Those config in ~/.config aren't read for gtk themes
Oops, didnt know that - no real Wayland experience here.
I put a script for GTK3 themes to be set every time after boot or reload. It does the same thing right?
#!/bin/sh
# usage: import-gsettings
config="${XDG_CONFIG_HOME:-$HOME/.config}/gtk-3.0/settings.ini"
if [ ! -f "$config" ]; then exit 1; fi
gnome_schema="org.gnome.desktop.interface"
gtk_theme="$(grep 'gtk-theme-name' "$config" | cut -d'=' -f2)"
icon_theme="$(grep 'gtk-icon-theme-name' "$config" | cut -d'=' -f2)"
cursor_theme="$(grep 'gtk-cursor-theme-name' "$config" | cut -d'=' -f2)"
font_name="$(grep 'gtk-font-name' "$config" | cut -d'=' -f2)"
gsettings set "$gnome_schema" gtk-theme "$gtk_theme"
gsettings set "$gnome_schema" icon-theme "$icon_theme"
gsettings set "$gnome_schema" cursor-theme "$cursor_theme"
gsettings set "$gnome_schema" font-name "$font_name"
No don't use autostart scripts
Use scheme override
OK! Will do! Thank you!
EDIT : DONE!
In Packages-Desktop you need to remove networkmanager. It conflicts with conman-support. Sorry! I forget you used conman!
Done
ISO Building for me now! Let's see...
garuda-sway-settings is in repo now btw
Edit: and an iso is there as well
I'll have to download that ISO and spin it somewhere.
I'm sorry to say it has lots of warts. It tries to start wayfire (not sway), and when I manually launched sway, it blew up when I tried dmenu.
Quality control time
Downloading now, slow connection from my provider but will take it for a ride.
Edit: error wayfire not found.
Got it!
####---->> DESKTOP THEMING
capitaine-cursors
garuda-wayfire-settings
gtk-engine-murrine
kvantum-qt5
kvantum-theme-nordic-git
nordic-darker-theme
qt5ct
tela-circle-icon-theme-git
Should be garuda-sway-settings! God that was a silly mistake sorry! Could someone with acess change it! In Packages-Desktop
capitaine-cursors
gtk-engine-murrine
kvantum-qt5
nordic-darker-theme
qt5ct
I see no difference.
It should be garuda-sway-settings not wayfire. I sent it to show you what part. Sorry I am on my phone!
Change to garuda-sway-settings.
