No. I use micro. Did I do something wrong. I have a feeling a did...
For everyone who thinks this is actually a good idea because “what could possibly go wrong?”: dont do it. Learned this lesson a while back the hard way ![]()
Searching for ages what was broken in the iso-profiles - it was a little thing called BOM which got injected by LibreOffice.
Did I do that? In the sway iso-profile? I didn’t even clone the repository it was just one addition so I just changed it online
Sorry!
I wasnt telling this because you did something wrong, just as a general hint which I wish I had remembered when doing this
 Even found the offender, lol:
Actually Im currently downloading the iso to test logging in
Alright, so logging in via TTY is indeed not possible.
Damn, it looks good btw
Might be due to the fact that zsh is specified in profile.conf but not existant in the system? Building a new iso with that fixed soon!
Yeah, that’s mainly why I still am afraid of using Wayland. If the desktop hangs, it requires a restart, and I might be unable to go into tty even then.
I've been starting from tty...works for me so far.  Was that what you meant @dr460nf1r3 or you were talking about editing from tty?
Yes, been there...never edit with non programming editor, Windows CR/LF, and other such invisible characters are stealth complications.
I was trying to login at LiveCD tty, which didnt work.
Here is a new build with fish in profile.conf, hopefully this fixed it ![]()
Are the build down? It don't download for me....
DL work here , cant make a screenshot FF closed the DL part if I use Prt ![]()
done.
Hmmm. It stops at 1.8gb for me.
Probably just my internet! I'll try again!
 sgs@i3 in /mnt/sdd1/miso
 ➜ ls | grep sway
.rw-r--r-- 2,1G sgs 12 Apr 20:34 garuda-sway-linux-zen-210412.iso
            Just sptit balling, perhaps incompatible keyboard layouts from different regions.
No the problem was the shell. Solved now with the new iso!
All I need to is a pick a default wallpaper (I shall do so soon)  then kindly ask @dr460nf1r3 to rebuild the package
Installing new iso now!
@SGS The problem was with the guest account in you can't download stuff. I'm stupid sorry for the trouble!
The first thing I delete
 It make only trouble, very new user log in and post: “all the time my data are changed after reboot.”
 Seems like you didn’t get much enough practice at EnOS
I hope you take one of mine ![]()
Or you can tell me what needs to be changed.
Are these wallpapers in the repo? Or should I download and set them manually?
They are amazing!
Install went good!
EDIT : I won't exist for an hour sorry! Need to go out!
\https://gitlab.com/SGSm/wallpaper/-/raw/master/Garuda/210402/sway-wp-sgs.png
\https://gitlab.com/SGSm/wallpaper/-/raw/master/Garuda/210402/sway-wp-02-sgs.png
I think you must change the name to background.png but IDK the sway configs.
So I just upload them to sway gitlab? Not add to the repo?
EDIT : Ok! Sure!
EDIT: I put them in /usr/share/wallpapers/garuda-wallpapers but won't that conflict?
