I'm not happy because I want things I can't have..lol..was laying in bed and thinking. 'Wouldn't it be neat if the bars (at least) could have a theme that was patternable, like a texture or something not just a color?'
Why hasn't the GTK toolkit supported this? (yes pipedreams apparently..or at least no one does it...just a flashback to web page backgrounds of the '90s). Hmm, maybe too much Mountain Dew this morning?
I find refreshing times something not to have everything in motley.
Moreover, if possible, it can still customize everyone for themselves.
Iâll keep riding on it because you donât give a clear answer.
Is the script in the Github/Gitlab?
Just because the âBerlinerâ made it doesnât mean that it can be used freely, maybe you have to name him and yourself as author (in the script)? ![]()
Yes it is. It can be used freely.
Sorry!
Youâre rightâŚIâm sure itâs just because I had too much caffeine. Otherwise, I guess things could get a bit gaudy
@dbarron when you install last did greetd show up? Or did you have to log in from tty?
Yes, on the current (as far as I know a new iso wasn't built yesterday) ISO, I had greetd running.
Could we build a new iso? Some additions and fixes.
Things that have changed:
- Switched shell to fish
- Keybinding helper added
- Keyboard icon in waybar to open helper
- Wlsunset
- Activites Menu (mod+p)
@dr460nf1r3 would you hurt me if I told you I'd been extremely stupid and forgot to tell you to rebuild the sway settings packages before you built the iso.
I couldve thought about that myself too, no worries ![]()
Doing that now, then we will have a new iso soon ![]()
Edit: Its ready btw, link didnt change as it was built the same day ![]()
Forgot to update profile to fish syntax mended on gitlab now.
There is no ttf-nerd-fonts in the shared packages-desktop? Shall I add it in separately? Or do you guys use a specific patched version? I remember you added one in....
Just include one you like - for Dr460nized for example a patched version of FantasqueSansMono is used. There are lots of other patched Nerd fonts as well
The font's seemed to be the only problem I noticed. It no longer crashes anymore when terminal is launched too. YAY! Activity's work , the wlsunset script to get lan and long work. Keybinding thing looks nice! YAY! Everything works finally! (After about 10 iso's sorry about that)!
Rome was not built in a single ISO.
Unfortunately something went wrong....my password doesn't work after install...I installed twice to check typing very carefully and it is not recognised?
Anyone have any idea? Why it happened?
(I chrooted and chnaged it then it works but why?)
@dbarron did that to you?
NowâŚthat right there, is bloody good mixed metaphor! ![]()
Thank you! ![]()
Well, I'm hesitant to kill my somewhat customized install..but the likely things would be (your caps key was on and you didn't notice?, something wrong with salt encryption (much less likely, as I don't think calamares version was increased), or other miscellaneous).
If you're 99.9% or greater certain that your caps key wasn't on, I'll reinstall and see if I have the problem.
Of course you dont need too! I can't try again now but i'll be free in a few hours or tmrw so I triple check!
No need to install but could someone load up the live iso switch to tty and check if the live user login and password work. 'garuda' 'garuda' do not work for me.
I'll edit this post with the calamares log after i install.
By any chance you used libreoffice to edit files ?
