Hi.
I'm running Garuda KDe Dr460nized on my Laptop. I am dual-booting Windows.
For months now I've had an issue where, when booting the system, it would get stuck on the following text:
Loading Linux linux-zen ...
Loading initial ramdisk ...
When this happened, a few reboots would get the system to eventually start normally, or I was able to load a snapshot for it to work, so I didn't bother. However, that is not the case anymore. I'm writing this on a live USB.
So far, i've tried to run these commands to reinstall grub and see if it works. However, when running sudo mount /dev/sdxy /mnt/, I get the following error:
mount: /mnt: special device /dev/sdxy does not exist.
dmesg(1) may have more information after failed mount system call.
this is is lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 15.6M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 429.4M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.1G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 680M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 14.5G 0 disk /mnt
│ /run/miso/bootmnt
├─sda1 8:1 1 2.4G 0 part
└─sda2 8:2 1 4M 0 part
zram0 253:0 0 7.6G 0 disk [SWAP]
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:1 0 260M 0 part
├─nvme0n1p2 259:2 0 16M 0 part
├─nvme0n1p3 259:3 0 59.2G 0 part
├─nvme0n1p4 259:4 0 1000M 0 part
├─nvme0n1p5 259:5 0 200M 0 part
└─nvme0n1p6 259:6 0 394.3G 0 part
I've then tried to run sudo mount /dev/sda2 /mnt because sda2 is 4MB, but I get this error instead
mount: /mnt: /dev/sda2 already mounted or mount point busy.
I've also tried sudo mount /dev/sda /mnt
mount: /mnt: WARNING: source write-protected, mounted read-only.
running sudo chroot /mnt/@ after that gives me:
chroot: cannot change root directory to '/mnt/@': No such file or directory
i'm guessing that the @ stands for something, but there are three folders in /mnt, and rather than playing with fire and potentially destroy the bootloader with commands I don't understand, i've decided that i've reached a dead end.
Here is garuda-inxi:
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=fr tz=UTC
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LH_TUF566LH
Mobo: ASUSTeK model: FX506LH v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LH.310 date: 11/26/2021
ID-1: BAT1 charge: 39.1 Wh (99.0%) condition: 39.5/48.1 Wh (82.2%)
volts: 12.8 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1437 high: 2500 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2500 3: 800
4: 2500 5: 800 6: 800 7: 2500 8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-10) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 322e:202c class-ID: 0e02
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 491.4 GiB used: 0 KiB (0.0%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: USB DISK 2.0 size: 14.46 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 7.6 GiB used: 1.88 GiB (24.8%)
System Temperatures: cpu: 60.0 C pch: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 233 Uptime: 5m wakeups: 1 Memory: 7.6 GiB used: 3.73 GiB (49.1%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: pm: pacman pkgs: 1220 libs: 308 tools: octopi,paru
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2023-01-02
Last full system update: 2023-01-02 ↻
I'm not sure if it's related, but before garuda broke today, I was trying to follow the Arch Wiki to create a permanent configuration for my graphics tablet. I had created a file in /etc/X11/xorg.conf.d/72-wacom-options.conf following the wiki's instructions. Following this, I restarted my PC, and that's when it stopped working.
That's about all of the information I have on hand.
