Hello,
Im having an issue with my garuda installation.
All of a sudden it no longer wants to boot, it goes through the process like usual and gets stuck at
‘[ ok ] finished permit user sessions.
Starting hold until boot process finishes up…
Starting terminate plymouth boot screen’
I tried loading a snapshot but it wouldnt work either,
i then tried to follow the instructions in the sticky thread
Sudo reflector -a5 -f5 --save /etc/pacman.d/mirrorlist
-gives me "warning failed to rate http(s) download (http://ftp.nluug.nl/os/linux…
Failed to rate rsync download (rsync://ftp.nluug.nl… etc.
Startx gives me “no unwind info found”
‘Sudo dkms autoinstall’ gives me
Error! Could not locate dkms.conf file
File: /var/lib/dkms/v412loopback/0.12.7/source/dkms.conf does not exist
My gpu is amd 390x i dont know if its related but i see messages about amdgpu hawaii not supported in kfd.
Any help is appreciated
Thanks!
