Garuda Settings Manager
So I'm trying to start Garuda Settings Manager, but it just doesn't work. I saw somewhere topic on forum here that we should check throught console typing garuda-settings-manager, but returns me error "No such file or directory". Do you have to fix it or?
I also want to change my brightness to make it bigger and I'm not even using night mode on. If anyone can help, that would be great.
Just go to - Garuda Welcome it should there. (KDE) You don't state what DE you are using - KDE, Gnome, etc.
I know where it is, but I can't open it. I tried using same name in console. and returns me no file or directory.
try garuda-settings-manager-git
Says unknown command
then install garuda-settings-manager with
pacman -Syu garuda-settings-manager
It says I'm not a root in my console
Maybe I need to type
sudo pacman -Syu garuda-settings-manager?
if you are a complete beginner then read Sudo - ArchWiki pacman - ArchWiki, that's one of the essentials of your Garuda Linux system. Linux involves getting knowledge about your system, and if you want to use it effectively you must learn the basics
Have you uninstalled it?
Check pacman log
grep "garuda-settings-manager" /var/log/pacman.log
shows me this
[2021-04-18T09:50:15+0200] [ALPM-SCRIPTLET] garuda-settings-manager-git r24.4646d26-1
[2021-04-18T09:50:15+0200] [ALPM-SCRIPTLET] garuda-settings-manager-kcm-git r24.4646d26-1
[2021-04-18T09:50:15+0200] [ALPM-SCRIPTLET] garuda-settings-manager-knotifier-git r24.4646d26-1
[2021-04-18T09:51:27+0200] [ALPM-SCRIPTLET] garuda-settings-manager-git r24.4646d26-1
[2021-04-18T09:51:27+0200] [ALPM-SCRIPTLET] garuda-settings-manager-kcm-git r24.4646d26-1
[2021-04-18T09:51:27+0200] [ALPM-SCRIPTLET] garuda-settings-manager-knotifier-git r24.4646d26-1
Well I can't open it, and if I type
garuda-settings-managerin my terminal I get that error
There is nothing to fix.
Read and learn how to search, install, uninstall packages and how to break your own system.
https://wiki.archlinux.org/index.php/Pacman
Okay thank you
 sgs@i3 in ~ took 6ms
[🔍] × garuda-settings-manager
garuda-settings-manager: error while loading shared libraries: libicuuc.so.68: cannot open shared object file: No such file or directory
[2021-01-27T21:02:31+0100] [ALPM-SCRIPTLET] garuda-settings-manager-git r22.fce11a8-1
[2021-01-27T21:03:14+0100] [ALPM-SCRIPTLET] garuda-settings-manager-git r22.fce11a8-1
[2021-02-01T21:32:11+0100] [ALPM] upgraded garuda-settings-manager-git (r22.fce11a8-1 -> r23.4ac04b3-1)
[2021-02-02T18:40:21+0100] [ALPM] upgraded garuda-settings-manager-git (r23.4ac04b3-1 -> r24.4646d26-1)
Since I never need it :wink: I just tried it.
Oh god please. Another of those icu rebuilds needed :bowing_man:
grep "garuda-settings-manager" /var/log/pacman.log doesn't work for me like that.
I get
[2021-04-18T09:51:27+0200] [ALPM-SCRIPTLET] garuda-settings-manager-knotifier-git r24.4646d26-1```
You have more then one manager :slight_smile: I think but you must post everytime your inxi.
Remove
Is that KDE?
As always
Read
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
:slight_smile:
sudo pacman -Syu garuda-settings-manager-git
The package has been rebuilt :slight_smile:
