Good evening all,
Pulling my hair out a little bit, garuda is flat out refusing to connect to my wifi connection even after using DKMS to install what were (as far as i could find) the latest drivers.
It just gives me an error and deactivates itself, even if I do a fresh install.
Please note, I am dual booted with Windows 11, secure boot is disabled in BIOS and fastboot is disabled in Windows itself. I also only boot Garuda from a full shutdown, never via restart from Windows. Computer goes off at the wall after a full shutdown prior to loading up Garuda.
I’m using a TPLink dongle (Realtek RTL8812BU), full paste below.
I am aware I have access to a wired connection, I am temporarily using a powerline adapter ( which is not on the same mains-loop in the house so not a viable long term solution, and is frankly slower than a brick sliding uphill ), but I do get full wifi speeds of around 650-700mbps on the same adapter within Windows. I know Windows does funky stuff thanks to fastboot hence why it’s all been disabled.
Any advice would be hugely appreciated, alternatively feel free to give me a slap and say “you’ve done this and broken it” haha.
If there’s any further information that you need just let me know and I’ll pop it in replies (or edit original post where required).
I do not plan to stay on Windows long-term, this current install is basically a bridge to get me used to Linux to do a full swap, but because of usage I can’t just drop Windows straight away as I need to confirm compatibility of various software that I use for work.
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=6c522481-29d5-4591-950c-e91006418768 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Mobo: ASUSTeK model: PRIME B550M-K v: Rev X.0x
UEFI: American Megatrends v: 2403 date: 06/16/2021
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3447 high: 3956 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3956 16: 3609 bogomips: 108595
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DP-3
bus-ID: 0a:00.0 chip-ID: 10de:2489 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 4240x2130
display-ID: 0
Monitor-1: HDMI-A-1 pos: bottom-r res: 1680x1050 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: primary,top-left res: 2560x1080 size: N/A
modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2489
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 0a:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Logitech G435 Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 046d:0acb class-ID: 0300
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] driver: rtw_8822bu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4
chip-ID: 2357:012d class-ID: 0000 serial: <filter>
IF: wlp1s0f0u4 state: down mac: <filter>
Local Storage: total: 1.8 TiB used: 27.52 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: P1.5 scheme: GPT
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD4
tech: SSD serial: <filter> fw-rev: 022 scheme: GPT
ID-1: / raw-size: 146.34 GiB size: 146.34 GiB (100.00%)
used: 27.5 GiB (18.8%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 28.2 MiB (29.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 146.34 GiB size: 146.34 GiB (100.00%)
ID-4: /var/log raw-size: 146.34 GiB size: 146.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.34 GiB size: 146.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.6 C mobo: N/A
Memory: total: 32 GiB available: 31.23 GiB used: 2.83 GiB (9.1%)
Processes: 357 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1801 libs: 534 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-08-18
Last full system update: 2024-08-18
