Garuda Rani - preview releases and testing
If you eve have something like that on most linux desktops you can hold meta and right click an drag to resize and left click drag to move the window.
Thanks @elite worked great i have the windof button pressed and worked. i dont use this button much at all :grinning_cat_with_smiling_eyes:
inform
inform² ? :smiley:
Oops :smiley: you have sharp eyes :wink:
Ah yeah you wrote already, im on the phone :wink:
[2.3.0] - 2025-03-21
:rocket: Features
  • (packages) Use searchable table instead for display
  • (system-tools) Only load components when tab has been selected
  • (kernels) Add kernels component
  • (kernels) Add dkms module check and loading indicator
  • (gaming) Add more WINE versions
  • (language-packs) New component
  • (settings) Move to dedicated page
  • (maintenance) Allow merging pacdiff files interactively
  • (system-status) Warn about pending reboot
  • (system-settings) Add bpftune
:bug: Bug Fixes
  • (system-components) Scanning-support never being enabled
  • (os-interact) Check for systemd sockets as well, fixing non-recognized sockets
  • (pnpm-lock.yaml) Sync with package.json
  • (config-service) Apply Loglevel on settings change
  • (notifications) Unbreak not-sending notifications
:tractor: Refactor
  • Massively improve performance by caching and using services
  • Use pacman regex for prefiltering, print commands used
:gear: Miscellaneous Tasks
  • Drop ununsed code
Warning worked for reboot :wink:
:smiley:
I partially crippled my pacman and / or repositories the other day trying to “remedy” my pacdiff situation. It somehow prevented the system from seeing the chaotic-aur repo. Couldn’t find anything wrong and tried to solve it a number of ways. However, the only thing that worked was remote fix. Solved it with one command, which made me laugh afterward. I wasted 2-3 hours when I could have just remote fix’ed it.
i had something near last year but just did garuda-update in the Terminal and it fixed itself IIRC :wink:
Then perhaps Nico and TNE would be better off adding three “informs”. :grinning_face_with_smiling_eyes:
It might be useful down the line to have a direct link to pacman/Rosetta - ArchWiki or have it pop up the main ones a ubuntu/fedora user would want to use. the word Rosetta doesn’t make a lot of sense to the uninitiated so maybe giving it a more simple name.
Damn, really missing a button to start the coffeemaker in the kitchen so far :face_with_raised_eyebrow:
Sorry, this is not meant to be a criticism, just couldn’t resist :upside_down_face:
Keep up this great work :+1:
Love the new Rani, however, I can’t find ‘Garuda Boot Options.’ Has this been removed?
Welcome page right.
Strange, my Welcome Page looks like this and no Boot Tools.
garuda-rani-git?
No, ‘garuda-rani’. I will switch. BTW, kind of confusing to have both or is it suppose to be different?
