I just tried to install one piece of software, it failed at the start with the message that Guarda-Pulse was in conflict with PulseAudio and should be removed.
I do not know how to copy/paste from Pamac to Firefox to here.
gary
gary
sudo pacman -Rns garuda-pipewire pipewire-alsa pipewire-pulse
then
sudo pacman -Syu
thank you so much. sound works.
Same problem, thanks for the solution.
Btw,
worked great thanks alot
