So I was also trying to flash garuda linux to usb drive , but getting this issue.
( I am not able to add image here , so adding the text from it)
ISOHybrid image detected
The image you have selected is an ISOHybrid, but its creators have not made it compatible with ISO/File copy mode. As a result, DD image writing mode will be enforced.
OK
I searched for the same and found this post - Unable to Burn To USB. Which is kind of related to my problem but I did't got any solution from it , so posting it again here. Please help
Have you tried Ventoy? It makes things a ton easier. Once you have a drive set up with it, all you have to do is drag and drop ISOs into the drive and it will work its magic.
@Hitesh06 have you actually clicked on OK when you saw that message? It is not an issue/error, it's an explication of what will happen once you press OK, which you should.
Not any specific error , after the flashing is complete , some thing like this Unable to Burn To USB happens. It shrinks the size of pen drive and mark the other available space as unallocated.
