I've tried doing some changes but I haven't modified much. I'm using Dragonized Gaming edition and the biggest change I can consider is turning off the taskbar dock zoom animation which gives it a vibe like mac. Now icon doesn't zoom up and follows just simple hover animation but this seems to help reduce the lag a little bit better.
I understand that having heavy transitions might be the cause of it but the thing is that I already have the decent config (shared below). So rendering shouldn't be the problem here? except if I'm lacking some sort of driver or etc. Hopefully below output will help pros here to find the cause here ![]()
Kernel: 6.0.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2724b483-ebe2-46f3-b250-be0931b048ce rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DY_FX505DY v: 1.0
Mobo: ASUSTeK model: FX505DY v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DY.315 date: 03/09/2020
ID-1: BAT0 charge: 34.9 Wh (100.0%) condition: 34.9/48.0 Wh (72.7%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2100 2: 2100 3: 2100 4: 2100
5: 2100 6: 2100 7: 2100 8: 2100 bogomips: 33537
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380 temp: 43.0 C
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 54.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x002d built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.48
6.0.5-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
Sound API: ALSA v: k6.0.5-zen1-1-zen running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 1.14 TiB used: 602.14 GiB (51.7%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
rev: 111110WD temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 174d 3h cycles: 1,131 read-units: 37,951,273
[19.4 TB] written-units: 32,038,329 [16.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0J temp: 34 C
SMART: yes state: enabled health: PASSED on: 264d 22h cycles: 1684
Old-Age: g-sense error rate: 1096
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%) used: 21.14 GiB
(9.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%) used: 21.14
GiB (9.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%) used: 21.14
maj-min: 259:2
ID-5: /var/tmp raw-size: 232.59 GiB size: 232.59 GiB (100.00%) used: 21.14
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.31 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3800
GPU: device: amdgpu temp: 53.0 C device: amdgpu temp: 42.0 C watts: 8.12
Processes: 314 Uptime: 0m wakeups: 1 Memory: 15.31 GiB used: 2.47 GiB
(16.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1866 libs: 510
tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
Garuda (2.6.9-1):
System install date: 2022-10-16
Last full system update: 2022-10-29
Windows dual boot: Yes
