Garuda KDE Dr460nized keep asking for wifi password everytime when I login
Hello Garuda users.
I recently installed Garuda KDE Dr460nized, By the way it's amazing experience all the UI and animations and developer productivity tools are given by default I loved it.
So what happens is that the first time when it asked me for wifi password I entered it and then it was asking for somekind of experience so yeasterday I didn't setup gpg key so I go with blowfish encryption in wifi.
Now everytime I login as user it ask me for wifi password to connect not saving the password, I guess it's because of blowfish but I can't see any option to now replace blowfish with my GPG encryption keys. can I reset it again? like for if wifi there is folder in ~/.local/config and I will be prompted again to choose from blowfish and gpg.
Kernel: 6.3.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d81c9e20-12ce-4bca-a5bd-4199f01659e5 rw rootflags=subvol=@
resume=UUID=e2f828e9-a24d-4ebb-b265-9c39b304a139 loglevel=3 ibt=off
Type: Laptop System: Dell product: Inspiron 5593 v: N/A
Mobo: Dell model: 0HP5Y9 v: A00 serial: <superuser required> UEFI: Dell
v: 1.26.0 date: 03/13/2023
ID-1: BAT0 charge: 21.8 Wh (100.0%) condition: 21.8/42.0 Wh (52.0%)
volts: 12.8 min: 11.4 model: BYD DELL 1VX1H99 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1229 high: 1300 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1234 2: 1200 3: 1200
4: 1200 5: 1300 6: 1300 7: 1200 8: 1200 bogomips: 19046
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Dell driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-05) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 bus-ID: 0000:01:00.0
chip-ID: 10de:1d11 class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0c45:671e
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: LG Display 0x05f2 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.0 renderer: Mesa Intel UHD Graphics (ICL GT1)
direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 0000:00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.3.4-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0 chip-ID: 10ec:8136
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:03:00.0
chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: br-c680a8bca5ba state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0cf3:e009
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.38 TiB used: 16.38 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: 11001101 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: SDM2 scheme: GPT
used: 16.38 GiB (3.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.53 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: 45.0 C gpu: nouveau temp: 48.0 C
Fan Speeds (RPM): cpu: 3108
Processes: 240 Uptime: 6m wakeups: 1053 Memory: available: 7.53 GiB
used: 3.53 GiB (46.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1198
libs: 330 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-27
Last full system update: 2023-05-28
Thanks.
If you are using KDE wallet, check this:
https://wiki.archlinux.org/title/KDE_Wallet#Unlock_KDE_Wallet_automatically_on_login
The easy way is to right click on your connection icon on your panel
click on configure network connections
Then choose to store your password for all users under wifi security settings.
