Garuda Installation failed in vmware
Garuda installtion failed in:
Garuda Hyprland
Garuda i3
Garuda KDE Lite
Garuda Zen
Any help?
please provide a screenshot or reason for us to help you bro
In all that distros:
The bootloader could not be installed. The installation command boot-mkconfig -o /boot/grub/grub.cfg returned error code: 1.
Kernel: 6.12.41-2-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=3bc50495-a163-4556-a425-04d021d06cf2 rw rootflags=subvol=@
quiet resume=UUID=ad190a20-0362-44a1-9e8b-2a8b404739af loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: Dell product: Precision 7530 v: N/A
Mobo: Dell model: 0425K7 v: A00 serial: <superuser required> part-nu: 0831
uuid: <superuser required> UEFI: Dell v: 1.41.0 date: 03/04/2025
ID-1: BAT0 charge: 91.2 Wh (100.0%) condition: 91.2/97.0 Wh (94.0%)
volts: 12.6 min: 11.4 model: SMP DELL 0WMRC7B type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Coffee Lake
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4000 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 62431
ports: active: eDP-1 empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Dell
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:1cbb class-ID: 0300
Device-3: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7 chip-ID: 0bda:5650
gpu: i915,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: C24X3F built: 2024 res:
mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: LG Display 0x0540 built: 2017 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
GT2) device-ID: 8086:3e9b memory: 30.38 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.1.7-arch1.1
device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
name: Quadro P1000 driver: nvidia v: 580.76.05 device-ID: 10de:1cbb
surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM 20.1.8)
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
API: ALSA v: k6.12.41-2-lts status: kernel-api with: aoss
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 6f:00.0
IF: wlp111s0 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 953.87 GiB used: 826.36 GiB (86.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS001TD9TNI-L2A0B size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11010C10 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 171.55 GiB size: 171.55 GiB (100.00%)
used: 139.73 GiB (81.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 17.3 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 341.8 GiB size: 341.8 GiB (100.00%)
used: 330.74 GiB (96.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 171.55 GiB size: 171.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 171.55 GiB size: 171.55 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.1 GiB used: 774.2 MiB (2.4%)
ID-2: swap-2 type: partition size: 40.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 80.0 C mobo: N/A
Memory: total: 32 GiB available: 31.1 GiB used: 10.98 GiB (35.3%)
Processes: 391 Power: uptime: 3h 55m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.35 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2109 libs: 550 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.7.5-1):
System install date:     2024-07-31
Last full system update: 2025-08-14
20/21 checks run in 1.12 seconds ⌛
Powered by garuda-health 🦅
You need to enable UEFI in VMware. Garuda Linux does not support BIOS. If that does not help, we will need the full logs. To get the full logs, run sudo -E calamares in a terminal and copy and paste the entire terminal output after the installation fails to https://bin.garudalinux.org and share the link here.
OK, but in all previous installations of Garuda in vmware, it works… I will check that.
Without knowing what the error message is, it is impossible for anyone to know why it failed. Unfortunately, the helpers and I do not have the ability to peek beyond the veil yet, but rest assured we are working on our malign spells.
Done EFI enabled in vmware, same error. Cannot install.
An issue?
Please read the previous messages I posted.
This is the error:
Please read the messages again, this is not what I asked you to post. Without the full error, nobody will be able to help or narrow down the issue.
Think on it…garuda isos need 31 gb space…not less (my mind)
And sorry… i test very often some of these isos and no error like this.
Your vm settings are wrong perhaps or you make a mistake if you start calamares settings partitions. But without logs..no help is possible.
if own partitioning : efi (vfat/fat32) partition flag boot and not less then 300 mb. (example)
I have installed Linux Mint, Manjaro KDE, last year, Garuda xfce and Garuda Zen…. all as vmware guests. Right now, I’m working with Manjaro VM guest in vmware and I have also installed Manjaro xfce.
So…. Why I cannot install now others distros of Garuda as vmware guest?
VMware: No 3D enabled (0, Success).
libEGL warning: egl: failed to create dri2 screen
The bootloader could not be installed. The installation command boot-mkconfig -o /boot/grub/grub.cfg returned error code: 1.`
Well, i read the egl info but have nothing to do with this error :up_arrow:
You have no 3D support 2x → reason nvidia dgpu and not a amd dgpu or vdgpu from nvidia
and to enable 3d for your igpu you need manual intervention in your host.
Need more info, sorry
What you are doing if you start calamares special settings partition ? Delete (default) or manual ?
Do you have tested kvm/qemu ?
Never tested qemu, and as I told you before, I have Manjaro KDE and Manjaro xfce working as guest in vmware as virtual machines. Both are Arch Linux.
And never I coud get 3D Acceletrations work in vmware Workstatiosn as vmware says that ther is no support for Arch Linux. But, the VM’s work.
¿may be new ISO’s of Garuda cannot be installed as VM’s in vmware Workstation?
Nope.
It says calamres is already running.
Again, use this command to start calamares. Do not have it already open.
After running the command, it should not return.
Attempt a system install, wait for it to fail and THEN copy the logs.
I did that.
And that copy paste into bin was the error.
ok, but not the answer of my question/s about calamares.
On my kvm/qemu → i can run all isos from garuda without this error. As example live iso cinnamon from 08.01.25 installed on 08.01 → update 2 min “old”
cinna@cinna
                 x;XxXB%89b8:b8%b88:              -----------
              .8Xxd                8X:.           OS: Garuda Linux x86_64
            .8Xx;                    8x:.         Host: KVM/QEMU Standard PC (Q35 + ICH9, 2009) (pc-q35-10.0)
          .tt8x          .d            x88;       Kernel: 6.16.0-zen2-1-zen
       .@8x8;          .db:              xx@;     Uptime: 16 seconds
     ,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;    Packages: 1144 (pacman)[stable]
   .SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;    Shell: fish 4.0.2
 ,888S                                     pd!    Resolution: 1280x800
8X88/                                       q     DE: Cinnamon 6.4.10
8X88/                                             WM: Muffin (X11)
GBB.                                              WM Theme: Sweet-Dark (Sweet-Dark)
 x%88        d888@8@X@X@X88X@@XX@@X@8@X.          Theme: Sweet-Dark [GTK2/3/4]
   dxXd    dB8b8b8B8B08bB88b998888b88x.           Icons: BeautyLine [GTK2/3/4]
    dxx8o                      .@@;.              Terminal: GNOME Terminal 3.56.2
      dx88                   .t@x.                Terminal Font: Adwaita Mono 11
        d:SS@8ba89aa67a853Sxxad.                  CPU: 6 x AMD Ryzen 5 3600 (6) @ 3.599GHz
          .d988999889889899dd.                    GPU: Virtio 1.0 GPU
                                                  Memory: 1044MiB / 7913MiB
I’m reinstalling right now. Al the errors and capture screens will be here… if they appears.
