Same error:
Garuda's PrivateBin
Visit this link to see the note. Giving the URL to anyone allows them to access the note, too.
Any help?
Please do not post here in the forum, like in chat forums.
As long as no one has responded to your post, you can edit your post.
If run calamares…
…you can’t start a second.
If, boot live iso → close rani → open konsole sudo -E calamares
that looks like this then…
That’s what I do… I ran it from konsole.
Your second picture. What is to see ? Inactive window behind with calamares and
actice window (terminal) with ? or ?
Perhaps a member here use also vmware and not kvm/qemu and can test this to help.
I switched 2 years from vmware to kvm, it was the better decision in retrospect.
Your second picture. What is to see ? Inactive window behind with calamares andactice window (terminal) with ? or ?
Konsole window shows : sudo -E calamares
Behind is error of installation at the end of it.
But calamares is active or ? (to exit calamares you must click on button “Done”)
Behind is the installation…. You mean that I have to close installation?
Of course..if it fails or what ever reason exist.
Btw.. we type here about the install over terminal with command sudo -E calameres
pls …look again at my posted picture
@gampel I already did that.
Rani is closed. Do you want to I close the Installation procedure and execute the command?
If it`s a new vm yes.. if not..delete the old vm , create a new ..boot live iso → etc
It is a new VM… I will do it.
Sorry, only this ?
Compare with my pictures.
Where is “create subvolume stuff” an so on …
Sorry, btw, as long that we here typing about this… i install with kvm 10x live isos or more and it’s equal which, with secure boot or not default settings.
Edit: to comment your last picture (i have this tested, current)
You have canceled calameres before press “install”
I don’t know why you doing this.
It is “after” installation, not before.
This thread is profoundly frustrating.
Do NOT click the “install Garuda Linux” shortcut. DO NOT have calamares open.
START CALAMARES with the command. DO NOT Install it first and THEN start it.
You need to START it in the terminal and keep the terminal open until the error.
OK, this is execution of calamares without the desktop icon, with Rani closed>
