Sorry, I actually love reading but didn't realize there was a spot in the wiki for the forum. Thank you for your help. Here's the info, I hope you don't mind that I have quite a few hard drives.
╰─λ inxi -Fxxxza
sudo parted -l
cat /etc/fstab
sudo blkid
lsblk -f
sudo os-prober
System: Kernel: 5.10.12-116-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq-westmere
root=UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda rw [email protected] splash
loglevel=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: P6T DELUXE V2 v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 1202 date: 12/22/2010
Battery: Device-1: hidpp_battery_0 model: Logitech MK700 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: Intel Xeon X5675 bits: 64 type: MT MCP arch: Nehalem family: 6
model-id: 2C (44) stepping: 2 microcode: 1F L2 cache: 12 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 98294
Speed: 3910 MHz min/max: 1600/3068 MHz boost: enabled Core speeds (MHz): 1: 3910
2: 3945 3: 4048 4: 3987 5: 3999 6: 3930 7: 3951 8: 3933 9: 3946 10: 3997 11: 3918
12: 3894
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 02:00.0 chip ID: 1002:67df
class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL:
renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.10.12-116-tkg-bmq LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:3a3e class ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 02:00.1
chip ID: 1002:aaf0 class ID: 0403
Device-3: Logitech Webcam B500 type: USB driver: snd-usb-audio,uvcvideo bus ID: 2-5:3
chip ID: 046d:0807 class ID: 0102 serial: <filter>
Device-4: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-6.2:7 chip ID: 046d:0a4d
class ID: 0300
Sound Server: ALSA v: k5.10.12-116-tkg-bmq
Network: Device-1: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK driver: sky2 v: 1.30
port: b800 bus ID: 04:00.0 chip ID: 11ab:4364 class ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK driver: sky2 v: 1.30
port: d800 bus ID: 06:00.0 chip ID: 11ab:4364 class ID: 0200
Drives: Local Storage: total: 3.58 TiB used: 151.56 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500413AS size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: JC4B
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: ABB0
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 120GB
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1B6Q
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD3200AAKS-00UU3A0
size: 298.09 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 3B01
Partition: ID-1: / raw size: 244.14 GiB size: 244.14 GiB (100.00%) used: 145.83 GiB (59.7%)
fs: btrfs dev: /dev/sdd1 maj-min: 8:49
ID-2: /home raw size: 244.14 GiB size: 244.14 GiB (100.00%) used: 145.83 GiB (59.7%)
ID-3: /var/log raw size: 244.14 GiB size: 244.14 GiB (100.00%)
used: 145.83 GiB (59.7%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49
ID-4: /var/tmp raw size: 244.14 GiB size: 244.14 GiB (100.00%)
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: zram size: 1.3 GiB used: 4.3 MiB (0.3%) priority: 32767
ID-2: swap-2 type: zram size: 1.3 GiB used: 3.7 MiB (0.3%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.3 GiB used: 4.1 MiB (0.3%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.3 GiB used: 4 MiB (0.3%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.3 GiB used: 4.4 MiB (0.3%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.3 GiB used: 4.1 MiB (0.3%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.3 GiB used: 4.2 MiB (0.3%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.3 GiB used: 3.9 MiB (0.3%) priority: 32767
dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.3 GiB used: 4.3 MiB (0.3%) priority: 32767
dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.3 GiB used: 4.3 MiB (0.3%) priority: 32767
dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.3 GiB used: 4 MiB (0.3%) priority: 32767
dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.3 GiB used: 3.9 MiB (0.3%) priority: 32767
dev: /dev/zram11
ID-13: swap-13 type: partition size: 9.77 GiB used: 0 KiB (0.0%) priority: 1024
dev: /dev/sdd2 maj-min: 8:50
Sensors: System Temperatures: cpu: 54.0 C mobo: 49.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): cpu: 1506 psu: 0 case-1: 0 case-2: 0 case-3: 0 gpu: amdgpu fan: 935
Power: 12v: 11.86 5v: N/A 3.3v: 3.30 vbat: N/A gpu: amdgpu watts: 45.09
Info: Processes: 468 Uptime: 2h 41m wakeups: 12 Memory: 15.62 GiB used: 11.54 GiB (73.9%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: 1724 pacman: 1699
lib: 430 flatpak: 16 snap: 9 Shell: fish v: 3.1.2 default: Zsh v: 5.8
running in: alacritty inxi: 3.3.00
[sudo] password for :
Model: ATA ST3500413AS (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17.4kB 16.8MB 16.8MB Microsoft reserved partition msftres
2 16.8MB 500GB 500GB ntfs Basic data partition msftdata
Model: ATA TOSHIBA DT01ACA3 (scsi)
Disk /dev/sdb: 3001GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
1 17.4kB 134MB 134MB Microsoft reserved partition msftres
2 135MB 1085GB 1085GB ntfs Basic data partition msftdata
3 1085GB 3001GB 1916GB ext4 legacy_boot
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sdc: 120GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 577MB 576MB primary ntfs boot
2 577MB 119GB 119GB primary ntfs
3 119GB 120GB 559MB primary ntfs msftres
Model: ATA WDC WD3200AAKS-0 (scsi)
Disk /dev/sdd: 320GB
Disk Flags:
1 1049kB 262GB 262GB primary btrfs boot
2 262GB 273GB 10.5GB primary linux-swap(v1)
3 273GB 320GB 47.4GB primary btrfs
Model: Unknown (unknown)
Disk /dev/zram5: 1398MB
Sector size (logical/physical): 4096B/4096B
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 1398MB 1398MB linux-swap(v1)
Disk /dev/zram11: 1398MB
Disk Flags:
Disk /dev/zram3: 1398MB
Disk Flags:
Disk /dev/zram1: 1398MB
Disk Flags:
Disk /dev/zram8: 1398MB
Disk Flags:
Disk /dev/zram6: 1398MB
Disk Flags:
Disk /dev/zram4: 1398MB
Disk Flags:
Disk /dev/zram10: 1398MB
Disk Flags:
Disk /dev/zram2: 1398MB
Disk Flags:
Disk /dev/zram0: 1398MB
Disk Flags:
Disk /dev/zram9: 1398MB
Disk Flags:
Disk /dev/zram7: 1398MB
Disk Flags:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda / btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /home btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /root btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /srv btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /var/cache btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /var/log btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=34fed22a-0e5a-4edf-bd0e-398c33d60bda /var/tmp btrfs [email protected],defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
#UUID=f524dde9-c436-4038-b4fd-daf7e8d2dd41 swap swap defaults,noatime 0 0
/dev/sdd1: UUID="34fed22a-0e5a-4edf-bd0e-398c33d60bda" UUID_SUB="9f2c764c-3412-4b54-83ad-92cfefd18a9b" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="a5aa5e4b-01"
/dev/sdd2: UUID="8541fc7e-2d3e-430d-8fb5-d9ee073df104" TYPE="swap" PARTUUID="a5aa5e4b-02"
/dev/sdd3: UUID="85f16b97-2494-456f-88c2-c2f2d8587cca" UUID_SUB="ddc59379-1c21-42aa-bdc0-f7c82e4574e7" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="a5aa5e4b-03"
/dev/sda2: LABEL="Data" BLOCK_SIZE="512" UUID="7AA43E78A43E374B" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="e640304f-0252-45f9-9a80-65075289837e"
/dev/sdc1: LABEL="System Reserved" BLOCK_SIZE="512" UUID="1092634C926334FE" TYPE="ntfs" PARTUUID="9f99ee1d-01"
/dev/sdc2: BLOCK_SIZE="512" UUID="2CEC7C56EC7C1C70" TYPE="ntfs" PARTUUID="9f99ee1d-02"
/dev/sdc3: BLOCK_SIZE="512" UUID="46405B53405B4937" TYPE="ntfs" PARTUUID="9f99ee1d-03"
/dev/sdb2: LABEL="Data" BLOCK_SIZE="512" UUID="3CBEAA17BEA9C9AA" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="0b91ebed-bd31-4597-9889-bf652ea65356"
/dev/sdb3: LABEL="LinuxData" UUID="5e5abff0-5b65-4b73-baa1-d324ae25af81" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="58dac25f-9b56-a644-9cee-1265fd6288f2"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/zram0: UUID="2a2af6dd-f3c3-4cd3-ae7c-06a729cbe539" TYPE="swap"
/dev/zram1: UUID="501b1eab-1386-4dc9-a6c1-6d687ac8a676" TYPE="swap"
/dev/zram2: UUID="52f6544b-bd44-4cd2-bad6-bdb04fc326d8" TYPE="swap"
/dev/zram3: UUID="419bdccc-798f-40f3-8848-f91a8e01d410" TYPE="swap"
/dev/zram4: UUID="e1b30812-8be0-45dd-ad6f-3c22dfa5e5a5" TYPE="swap"
/dev/zram5: UUID="ea42f7ea-e070-429e-8eb3-2df60a91ef68" TYPE="swap"
/dev/zram6: UUID="991f165a-3446-4cbb-b0ec-213af4d62b93" TYPE="swap"
/dev/zram7: UUID="ffa60597-1ca8-4b8b-9c83-96356c391f98" TYPE="swap"
/dev/zram8: UUID="27930cf9-dd5b-4b9c-b7f4-a614e6379e35" TYPE="swap"
/dev/zram9: UUID="ef54bdbb-2f45-4bb0-8495-e53abc3d9469" TYPE="swap"
/dev/zram10: UUID="02478592-0aa9-4fae-bd49-6829fe535315" TYPE="swap"
/dev/zram11: UUID="4b260042-ec7e-4d96-a1ab-22250a468534" TYPE="swap"
/dev/sda1: PARTLABEL="Microsoft reserved partition" PARTUUID="ebbecc3e-77b3-45e5-9ad2-ca43528cc7b5"
/dev/sdb1: PARTLABEL="Microsoft reserved partition" PARTUUID="d9fd3a99-8dea-48be-b1a4-8236ace783f4"
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
fd0
loop0 squashfs 4.0 0 100% /snap/gtk-
loop1 squashfs 4.0 0 100% /snap/gnom
loop2 squashfs 4.0 0 100% /snap/ramb
loop3 squashfs 4.0 0 100% /snap/core
loop4 squashfs 4.0 0 100% /snap/snap
loop5 squashfs 4.0 0 100% /snap/spot
loop6 squashfs 4.0 0 100% /snap/core
loop7 squashfs 4.0 0 100% /snap/core
loop8 squashfs 4.0 0 100% /snap/gnom
sda
├─sda1
└─sda2 ntfs Data 7AA43E78A43E374B
sdb
├─sdb1
├─sdb2 ntfs Data 3CBEAA17BEA9C9AA
└─sdb3 ext4 1.0 LinuxData 5e5abff0-5b65-4b73-baa1-d324ae25af81
sdc
├─sdc1 ntfs System Reserved 1092634C926334FE
├─sdc2 ntfs 2CEC7C56EC7C1C70
└─sdc3 ntfs 46405B53405B4937
sdd
├─sdd1 btrfs 34fed22a-0e5a-4edf-bd0e-398c33d60bda 97.3G 60% /run/times
├─sdd2 swap 1 8541fc7e-2d3e-430d-8fb5-d9ee073df104 [SWAP]
└─sdd3 btrfs 85f16b97-2494-456f-88c2-c2f2d8587cca 36.9G 13% /mnt
sr0
zram0 [SWAP]
zram1 [SWAP]
zram2 [SWAP]
zram3 [SWAP]
zram4 [SWAP]
zram5 [SWAP]
zram6 [SWAP]
zram7 [SWAP]
zram8 [SWAP]
zram9 [SWAP]
zram10 [SWAP]
zram11 [SWAP]
/dev/sdc1:Windows 10:Windows:chain
/dev/sdd3:openSUSE Leap 15.2:openSUSE:linux
/dev/sdd3:openSUSE Leap 15.2:openSUSE1:linux:btrfs:UUID=85f16b97-2494-456f-88c2-c2f2d8587cca:[email protected]/.snapshots/1/snapshot
