Garuda boot menu is not visable
    root=UUID=f5acc047-d731-4dff-be40-33c0ee2a98d8 rw rootf[email protected]
    loglevel=3 ibt=off
  Type: Desktop System: Apple product: iMac12,1 v: 1.0
    serial: <superuser required> Chassis: type: 13 v: Mac-942B5BF58194151B
  Mobo: Apple model: Mac-942B5BF58194151B serial: <superuser required>
    UEFI: Apple v: 87.0.0.0.0 date: 06/14/2019
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
  Info: model: Intel Core i5-2400S bits: 64 type: MCP arch: Sandy Bridge
    desc: 1x6 MiB
  Speed (MHz): avg: 2400 high: 2931 min/max: 1600/3300 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 2931 2: 1596 3: 2700
    4: 2375 bogomips: 19954
    driver: i915 v: kernel arch: Gen-6 code: Sandybridge process: Intel 32nm
    built: 2011 ports: active: none empty: VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0102 class-ID: 0380
  Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
    vendor: Apple driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2
    code: Evergreen process: TSMC 32-40nm built: 2009-15 pcie: gen: 2
    speed: 5 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, VGA-2 bus-ID: 01:00.0 chip-ID: 1002:6741
  Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
    bus-ID: 1-2:3 chip-ID: 05ac:850b class-ID: 0e02 serial: <filter>
    compositor: kwin_x11 driver: X: loaded: modesetting,radeon
    alternate: fbdev,intel,vesa dri: r600,crocus gpu: radeon display-ID: :0
  Monitor-1: eDP-1 mapped: eDP model: Apple iMac built: 2010 res: 1920x1080
    hz: 60 dpi: 103 gamma: 1.2 size: 475x267mm (18.7x10.51") diag: 545mm (21.5")
  API: OpenGL v: 4.5 Mesa 23.0.3 renderer: AMD TURKS (DRM 2.50.0 /
    6.2.13-zen-1-zen LLVM 15.0.7) direct-render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
    vendor: Apple driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
  API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
    vendor: Apple AirPort Extreme driver: ath9k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0030 class-ID: 0280
  Device-1: Apple Built-in Bluetooth 2.0+EDR HCI type: USB driver: btusb
    v: 0.8 bus-ID: 1-1.1.1:7 chip-ID: 05ac:8215 class-ID: fe01 serial: <filter>
  Local Storage: total: 465.76 GiB used: 192.48 GiB (41.3%)
    model: WD5000AAKS-402AA0 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1D02 scheme: GPT
    used: 142.16 GiB (30.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-1: swap-1 type: zram size: 3.8 GiB used: 2.07 GiB (54.4%) priority: 100
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1199
  Processes: 251 Uptime: 4h 22m wakeups: 47 Memory: 3.81 GiB
  used: 2.93 GiB (77.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1957
  libs: 536 tools: octopi,pamac,paru Shell: fish v: 3.6.1 running-in: yakuake
  inxi: 3.3.26
  System install date:     2023-04-28
  Last full system update: 2023-04-30 ↻
hello , any help would be graetly appreciated ..... after the update that caused issues with plymouth-sddm (i believe it was named that) i lost the ability to see the garuda boot menu....... is there a way to fix this or atleast a way to load snapper snapshots from the tty menu?
Try to boot from a live USB.
You'll find tools like "Garuda boot repair" or you'll be able to reinstall the GRUB.
In case of troubles there is also a tutorial to do it manually.
the boot menu works i just cant see the graphical interface, would that still be a grub issue ? im talking about the menu that you can choose to boot with different kernels or snapshots, just before garuda boots into the os
Please post output from
cat /etc/default/grub | grep GRUB_TIMEOUT
as text.
evidently the body seems unclear with such a short reply , so im sorry about this useless sentence.
GRUB_TIMEOUT=5
GRUB_TIMEOUT=5
There is certainly a problem of understanding here. :slight_smile:
So the menu items for kernel change and snapshot selection are missing?
Have you made any changes?
Used the grub customizer?
the whole screen is gone, the only thing that i see during the startup is a black screen with a single under score ( _ ) .... after that boot timeout i see a black screen with 3 dots ( . . . ) until my login screen is loaded..... however i can navigate the menu from looking at the menu on another computer ..... and i haven't made any changes to grub or used a grub customizer
