As it says in the title, gamescope carches immediatelly after launching.
Steam generates this error log
[gamescope] [Info]  console: gamescope version 3.15.9-8-gddf0d76d (gcc 14.2.1)
No CAP_SYS_NICE, falling back to regular-priority compute and threads.
Performance will be affected.
ATTENTION: default value of option vk_khr_present_wait overridden by environment.
[gamescope] [Info]  vulkan: selecting physical device 'AMD Radeon RX 6700 XT': queue family 1 (general queue family 0)
[gamescope] [Info]  vulkan: physical device supports DRM format modifiers
Fossilize INFO: Overriding serialization path: "/home/marcelojcs/.local/share/Steam/steamapps/shadercache/1252330/fozpipelinesv6/steamapprun_pipeline_cache".
[gamescope] [Error] vulkan: vkAllocateDescriptorSets failed
SDL_Vulkan_CreateSurface failed: VK_KHR_wayland_surface extension is not enabled in the Vulkan instance.terminate called without an active exception
Uploaded AppInterfaceStats to Steam
Game Recording - game stopped [gameid=1252330]
Removing process 170311 for gameID 1252330
My system info:
Kernel: 6.10.6-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=0982a547-6fb9-49a2-b4d9-47950c60c9f3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
UEFI: American Megatrends v: 4203 date: 07/25/2023
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3130 min/max: 1550/3400 boost: disabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3130 2: 3130 3: 3130
4: 3130 5: 3130 6: 3130 7: 3130 8: 3130 9: 3130 10: 3130 11: 3130 12: 3130
bogomips: 81630
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Tul / PowerColor Red Devil
active: DP-1,DP-3,HDMI-A-1 empty: DP-2,Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: SunplusIT Webcam Digital MIC driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 2b16:6689 class-ID: 0102 serial: <filter>
gpu: amdgpu d-rect: 5440x1980 display-ID: 0
Monitor-1: DP-1 pos: top-center res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: bottom-r res: 1600x900 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: primary,top-left res: 1920x1080 size: N/A
modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
navi22 LLVM 18.1.8 DRM 3.57 6.10.6-AMD-znver3) device-ID: 1002:73df
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu
name: AMD Radeon RX 6700 XT driver: amd v: (AMD proprietary shader compiler)
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: AMD Radeon RX 6700 XT (RADV NAVI22)
driver: mesa radv v: 24.2.3-arch1.1 device-ID: 1002:73df
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM 18.1.8)
bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0d:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: SunplusIT Webcam Digital MIC driver: snd-usb-audio,uvcvideo
Device-4: Goldvish S.A. Redragon Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 1c1f:2214 class-ID: 0300
API: ALSA v: k6.10.6-AMD-znver3 status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 0bda:8771
Local Storage: total: 2.16 TiB used: 1.65 TiB (76.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 120 GB
size: 111.8 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Lexar model: SSD size: 238.47 GiB
serial: <filter> fw-rev: V4.7 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
used: 764.34 GiB (82.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.27 GiB used: 10 MiB (0.0%) priority: 100
System Temperatures: cpu: 42.8 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 44.0 C
Memory: total: 32 GiB available: 31.27 GiB used: 4.9 GiB (15.7%)
Processes: 413 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2487 libs: 608 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date:     2024-04-30
Last full system update: 2024-10-04
