EDIT 2: SOLVED (kinda):
When windoed even though the cursor is "locked" moving it down too far caused latte to pop up. So i run it fullscreen with latte off and could not reproduce the issue.
The problem is probably latte dock trying to pop up over a maximized win app causing the system to have a stroke.
EDIT: Formated the post to be readable
So i have a fresh install of garuda. Downloaded war thunder.
The game plays better BUT at some point, either if i tab out and back in or it is about to load something the monitor freezes (still image of whatever was happening the moment of event.).
Nothing can be done, even ctrl+f* does nothing. The only way to "fix" the situation is to hold down the power button until my system ceases.
My old os was OpenSuse Tumbleweed and i was having both less fps and a slight input lag.
On this os i get better fps and smoothness.
It does not happen in windowed mode only fullscreen (Just had a 3hr session windowed, smooth as honey)
The chassis does not warm up more than normal nor the fans ramp up to an alarming degree at any point
The audio keeps playing only if it was queued so a youtube video will keep giving audio normally but in game audio will not change with time as expected.
I managed to save the live wine output from the terminal to a file, keep in mind that i only have what was saved before i had to suffocate the laptop
nohup: ignoring input
ERROR: ld.so: object '/usr/lib/coreutils/libstdbuf.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type
00000005007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type
00000005Gtk-Message: 17:34:26.223: Failed to load module "appmenu-gtk-module"
(launcher:15137): GLib-CRITICAL **: 17:34:30.739: Source ID 40 was not found when attempting to remove it
(launcher:15137): GLib-CRITICAL **: 17:34:32.393: Source ID 59 was not found when attempting to remove it
[S_API] SteamAPI_Init(): SteamAPI_IsSteamRunning() did not locate a running instance of Steam.
[S_API] SteamAPI_Init(): Loaded '/home/george/.local/share/Steam/linux64/steamclient.so' OK.
[S_API FAIL] SteamAPI_Init() failed; create pipe failed.ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_route.c:877:(find_matching_chmap) Found no matching channel map
ALSA lib pcm_dmix.c:999:(snd_pcm_dmix_open) unable to open slave
malloc(): unsorted double linked list corrupted
inxi:
Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=79156c3e-ec3d-41b1-a484-07bf29a9edbd rw rootflags=subvol=@
quiet
cryptdevice=UUID=2a59eaba-0d11-4ee9-8f86-1c94621a8847:luks-2a59eaba-0d11-4ee9-8f86-1c94621a8847
root=/dev/mapper/luks-2a59eaba-0d11-4ee9-8f86-1c94621a8847 quiet splash
resume=/dev/mapper/luks-bf5a2f2b-5e63-4d85-8b45-dc06f7e2dc8d loglevel=3
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
Mobo: Dell model: 0N2FW9 v: A00 serial: <superuser required> UEFI: Dell
v: 1.6.2 date: 01/25/2018
ID-1: BAT0 charge: 25.1 Wh (100.0%) condition: 25.1/42.0 Wh (59.7%)
volts: 12.5 min: 11.4 model: Samsung SDI DELL CYMGM7B type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2144 high: 2300 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2212 2: 2115 3: 2115
4: 2114 5: 2103 6: 2300 7: 2100 8: 2100 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Dell driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:174d
class-ID: 0302
Monitor-1: eDP-1 model: Najing CEC Panda 0x0021 built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 1-2:3 chip-ID: 1532:0527
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 class-ID: 0300
serial: <filter> chip-ID: 8086:9d71 class-ID: 0403
Device-2: Razer USA RZ04-0318 Gaming Headset [Kraken Ultimate] type: USB
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-7:5 chip-ID: 8087:0a2a class-ID: e001
address: <filter>
Local Storage: total: 238.47 GiB used: 69.7 GiB (29.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: KSG60ZMV256G M.2 2280
256GB size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4101 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 69.7 GiB (30.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2a59eaba-0d11-4ee9-8f86-1c94621a8847
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.5 GiB used: 50 MiB (0.7%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-bf5a2f2b-5e63-4d85-8b45-dc06f7e2dc8d
System Temperatures: cpu: 58.0 C pch: 52.5 C mobo: 52.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2585
Processes: 264 Uptime: 54m wakeups: 2687 Memory: 7.51 GiB
used: 4.13 GiB (55.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1287
libs: 360 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-19
Last full system update: 2023-01-21
! for you
