Hi folks, just discovered Garuda and was pretty interested and excited to find what I perceived as a more highly optimized and well tuned Manjaro-Arch variant. Unfortunately I've been hitting various walls after just starting.
I installed the KDE Dragonized edition and installed quite a few packages that were offered as options after installation.
Unfortunately after all of this and updates and a reboot, I found that my icon changes among other settings tweaks seemed to have not saved between sessions.
I also tried to set my network connection settings on the KDE System Settings -> Connections panel, but I get an error:
Cannot load library /usr/lib/qt/plugins/kcm_networkmanagement.so: (libqcaa-qt5.so.2: cannot open shared object file: No such file or directory)
I also noticed in the Add/Remove Software
app that the "Browse" tab is showing "No package found".
It just seems like a lot of things are broken and this has been a supremely frustrating experience thus far.
What should I do from this point to try to restore sanity and begin tracking down issues?
