My magic ball just arrived from repair-shop and asked it about your issue.
Imagine the answer!!
You have to stop booting into your ISO installer medium over and over again!
If this is not true, post your system info:
inxi -Fxxxza
inxi -Fxxxza
@jonathon no, I initially reported the broken system and then did another fresh install. The problem here is identical breakage in both cases. In the second situation, that we're on now, I'm having the same experience after NOT installing a lot of offered packages. I refused "Ultimate" and did not install anything.
I did try a restoration the first time and that also changed nothing and so I proceeded with reinstall.
@petsam no, I am not booting to the installer medium - it is not actually mounted, I just happened to have it plugged in. I yanked it out - same results and here you go:
~> inxi -Fxxxza
System: Kernel: 5.11.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=00f45af5-32d3-43c8-a12c-db3f3fc4828a
systemd.unified_cgroup_hierarchy=1 resume=UUID=d3c53eb3-38b2-4aa3-b500-f3b3df0b6d6f loglevel=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO ALPHA v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 3801 date: 03/14/2018
CPU: Info: Quad Core model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S family: 6
model-id: 5E (94) stepping: 3 microcode: E2 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 63999
Speed: 4201 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4201 2: 4200 3: 4201 4: 4200
5: 4201 6: 4200 7: 4201 8: 4201
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1921x2280 s-dpi: 96 s-size: 507x602mm (20.0x23.7") s-diag: 787mm (31")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x260mm (18.9x10.2")
diag: 546mm (21.5")
Monitor-2: DVI-D-0 res: 1920x1200 hz: 60 dpi: 94 size: 519x324mm (20.4x12.8")
diag: 612mm (24.1")
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0 5.11.11-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.11.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: f000
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: ASUSTeK
driver: ath10k_pci v: kernel modules: wl port: e000 bus-ID: 0b:00.0 chip-ID: 168c:003e
IF: wlp11s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel
port: c000 bus-ID: 0f:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp15s0 state: down mac: <filter>
Device-4: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel
port: b000 bus-ID: 10:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp16s0 state: down mac: <filter>
Device-5: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple driver: wl v: kernel
modules: bcma port: b000 bus-ID: 12:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp18s0 state: dormant mac: <filter>
Bluetooth: Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8 bus-ID: 1-14.3:10
chip-ID: 05ac:828d class-ID: fe01
Report: ID: hci1 state: up address: <filter>
Device-2: ASUSTek Qualcomm Bluetooth 4.1 type: USB driver: btusb v: 0.8 bus-ID: 1-9:4
chip-ID: 0b05:1825 class-ID: e001
Drives: Local Storage: total: 476.94 GiB used: 19.31 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: MZVPV512HDGL-000 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B serial: <filter> rev: 300Q scheme: GPT
Partition: ID-1: / raw-size: 407.66 GiB size: 407.66 GiB (100.00%) used: 19.31 GiB (4.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 407.66 GiB size: 407.66 GiB (100.00%) used: 19.31 GiB (4.7%) fs: btrfs
ID-4: /var/log raw-size: 407.66 GiB size: 407.66 GiB (100.00%) used: 19.31 GiB (4.7%) fs: btrfs
ID-5: /var/tmp raw-size: 407.66 GiB size: 407.66 GiB (100.00%) used: 19.31 GiB (4.7%) fs: btrfs
ID-1: swap-1 type: partition size: 69.02 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 7.84 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 668
Info: Processes: 294 Uptime: 5h 06m wakeups: 0 Memory: 62.75 GiB used: 3.88 GiB (6.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1642 lib: 503
Shell: fish v: 3.2.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.03
Post
inxi -r
~> inxi -r
Repos: Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
1: https://random-mirror.chaotic.cx/$repo/$arch
2: https://cdn-mirror.chaotic.cx/$repo/$arch
3: https://us-tx-2-mirror.chaotic.cx/$repo/$arch
4: https://us-wa-mirror.chaotic.cx/$repo/$arch
5: https://us-ut-mirror.chaotic.cx/$repo/$arch
6: https://us-ca-mirror.chaotic.cx/$repo/$arch
7: https://nl-mirror.chaotic.cx/$repo/$arch
8: https://es-mirror.chaotic.cx/$repo/$arch
9: https://de-1-mirror.chaotic.cx/$repo/$arch
10: http://de-2-mirror.chaotic.cx/$repo/$arch
11: https://be-bru-mirror.chaotic.cx/$repo/$arch
12: https://kr-mirror.chaotic.cx/$repo/$arch
13: https://bg-mirror.chaotic.cx/$repo/$arch
14: https://ca-mirror.chaotic.cx/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: https://mirror.sergal.org/archlinux/$repo/os/$arch
2: https://mirror.pseudoform.org/$repo/os/$arch
3: https://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
4: https://mirror.selfnet.de/archlinux/$repo/os/$arch
5: https://mirror.ubrco.de/archlinux/$repo/os/$arch
Disable random server, rank mirrors and normalize packages:
bash
sudo sed -i '/random-mirror/s/^/#/g' /etc/pacman.d/chaotic-mirrorlist
sudo rankmirrors -r chaotic-aur /etc/pacman.d/chaotic-mirrorlist > /etc/pacman.d/chaotic-mirrorlist.ranked
sudo mv /etc/pacman.d/chaotic-mirrorlist /etc/pacman.d/chaotic-mirrorlist.orig
sudo mv /etc/pacman.d/chaotic-mirrorlist.ranked /etc/pacman.d/chaotic-mirrorlist
exit
sudo pacman -Syyuu
I tried to post these just after you messaged me yesterday, but apparently a bug or problem that the moderators hit would not allow me to post until I reached the next day.
results:
$ sudo pacman -Syyuu
core 131.4 KiB 626 KiB/s 00:00 [------------------------------------] 100%
extra 1620.9 KiB 6.06 MiB/s 00:00 [------------------------------------] 100%
community 5.5 MiB 7.83 MiB/s 00:01 [------------------------------------] 100%
multilib 148.9 KiB 20.8 MiB/s 00:00 [------------------------------------] 100%
chaotic-aur 856.0 KiB 1093 KiB/s 00:01 [------------------------------------] 100%
warning: garuda-common-settings: downgrading from version 1.1.3-2 to version 1.1.3-1
resolving dependencies...
:: nohang-git and nohang are in conflict. Remove nohang? [y/N] y
Packages (4) faudio-21.04-1 garuda-common-settings-1.1.3-1 nohang-0.2.0-1 [removal]
nohang-git-0.2.0.r7.gb025479-1
Total Download Size: 0.23 MiB
Total Installed Size: 0.76 MiB
Net Upgrade Size: 0.01 MiB
:: Retrieving packages...
faudio-21.04-1-x86_64 125.2 KiB 620 KiB/s 00:00 [------------------------------------] 52%
nohang-git-0.2.0.r7.gb025479-1-any 183.9 KiB 278 KiB/s 00:01 [------------------------------------] 76%
garuda-common-settings-1.1.3-1-any 240.0 KiB 272 KiB/s 00:01 [------------------------------------] 100%
(3/3) checking keys in keyring [------------------------------------] 100%
(3/3) checking package integrity [------------------------------------] 100%
(3/3) loading package files [------------------------------------] 100%
(3/3) checking for file conflicts [------------------------------------] 100%
(4/4) checking available disk space [------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/sda2 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,autodefrag,subvolid=5,subvol=/
Creating new backup...(BTRFS)
Saving to device: /dev/sda2, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-04-02_19-02-45
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-04-02_19-02-45/@
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-04-02_19-02-45/@home
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-04-02_19-02-45/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-04-02_19-02-45': ondemand
Maximum backups exceeded for backup level 'hourly'
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-04-02 19:02:45 | timeshift-btrfs/snapshots/2021-04-02_19-02-45/@
Found snapshot: 2021-04-02 19:00:01 | timeshift-btrfs/snapshots/2021-04-02_19-00-01/@
Found snapshot: 2021-04-02 18:00:01 | timeshift-btrfs/snapshots/2021-04-02_18-00-01/@
Found snapshot: 2021-04-02 17:00:01 | timeshift-btrfs/snapshots/2021-04-02_17-00-01/@
Found snapshot: 2021-04-02 15:40:36 | timeshift-btrfs/snapshots/2021-04-02_15-40-36/@
Found snapshot: 2021-04-02 14:54:50 | timeshift-btrfs/snapshots/2021-04-02_14-54-50/@
Found snapshot: 2021-04-02 14:08:14 | timeshift-btrfs/snapshots/2021-04-02_14-08-14/@
Found snapshot: 2021-04-02 14:00:01 | timeshift-btrfs/snapshots/2021-04-02_14-00-01/@
Found snapshot: 2021-04-02 12:08:12 | timeshift-btrfs/snapshots/2021-04-02_12-08-12/@
Found snapshot: 2021-04-02 12:02:19 | timeshift-btrfs/snapshots/2021-04-02_12-02-19/@
Found 10 snapshot(s)
done
(1/1) removing nohang [------------------------------------] 100%
(1/3) upgrading faudio [------------------------------------] 100%
(2/3) installing nohang-git [------------------------------------] 100%
Optional dependencies for nohang-git
libnotify: to show GUI notifications [installed]
sudo: to show GUI notifications if nohang started with UID=0 [installed]
logrotate: maintaining a separate log is one of the options [installed]
(3/3) downgrading garuda-common-settings [------------------------------------] 100%
==> Attempting to enable services...
==> Updating font cache...
==> Performing misc postinstall operations...
==> Done!
( 1/10) Syncing all file systems...
( 2/10) Reloading system manager configuration...
( 3/10) Arming ConditionNeedsUpdate...
( 4/10) Foreign/AUR package notification
python2-bcrypt 3.1.7-4
syncthing-gtk 1:0.9.4.4-2
( 5/10) Orphaned package notification...
=> No orphans found.
( 6/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/systemd/system.conf.pacnew
Please check and merge
( 7/10) Updating pkgfile database...
( 8/10) Checking which packages need to be rebuilt
( 9/10) Updating the desktop file MIME type cache...
(10/10) Syncing all file systems...
And just to be clear, same System Settings -> Connections error (no such file or directory
) as well as the other aforenoted problems of not saving settings between sessions, etc.
I cannot find out what this is or where it belongs.
Itās like you are running a Franken-systemā¦
If this is not a user created error/situation and suspecting Garuda is responsible for affecting user account settings is very serious thing.
In no way should the user settings get changed because of a system or package behavior.
I doubt it is not a user fault.
If it were, there would be more reports about it, even on unofficial support web-pages.
A possible (but unlikely probable) reason could be an AUR program.
I run Arch, so I canāt objectively exclude anything on a Garuda system, so I would rather wait for a Garuda user or dev to investigate this more confidently.
@librewish @TNE @dr460nf1r3 ? I am out of ideas
Well, there are several things which I dont understand here:
/usr/lib/qt/plugins/kcm_networkmanagement.so
which is preinstalled in dr460nized. I cant imagine anything Garuda related changing that particular fileThere is one situation in which the latest dotfiles are copied to the user directory in Garuda assistant after the initial upgrade. Did you run the setup assistant multiple times? @yaruda
@dr460nf1r3 can you find this file with pacman -F <file>
@yaruda I see you have syncthing installed from AUR. Is there a chance you have set it to sync your $HOME folder or any user config folders with syncthing? That is a reasonable answer to this but so much awkward settingā¦
Not at all
That being said, I have plasma-nm installed and working nevertheless
No. I only ran the mirror selection tool + updates. That is the only thing I did that presented problems on this clean install @dr460nf1r3.
@petsam I literally did nothing else in the way of customization on this install. No synchronization, nada.
I suppose I can do a final 3rd fresh install as a sanity check here for you guys before moving on to another distro. I'm quite losing my mind at this point and my Hackintosh is more sane than this thus far, which in and of itself is insane. I hate to just dump this since it really seems you've done a great job @dr460nf1r3 in making this look more macOS like and I'm trying to find a Linux distro based on KDE that really brings the complete macOS UX to a Linux platform right now.
If I do a final 3rd try at a fresh install, can you please explicitly tell me what steps to follow following the installation before doing anything else? Including a proper setup of Timeshift to capture a "fresh install state" (which I thought I did this time and reversion to it does NOT fix this situation).
Read Garuda wiki. Itās all there.
Do not do anything else.
Reboot twice after full pacman updates.
Then change Window decoration theme. Save and reboot.
If the setting is lost, Iāll buy you a beer, or coffee.
I have done the 3rd reinstall. Observations:
Did NOT run any updates right off the bat. Did configuration without anything else first + reboot.
I set the installer to autologin, but this did not work.
I chose to not run the "Setup-Assistant"
I changed the Display Configuration - that worked and stayed (and did previously as well; 2 monitors)
Changed Touchpad settings (invert/natural scrolling + .3 pointer accel)
Networking config opened this time
Changed icons and desktop backgrounds
Set Startup and Shutdown autologin
Rebooted twice for good measure
Saved system vis Timeshift.
Noticed Touchpad settings not saved (lost both the acceleration + inverted scroll).
Opened Konsole and checked for upd
it was there this time. Executed it.
Got an error and paused here:
ā°āĪ» upd
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2021-04-04 02:02:45 UTC
# From: https://www.archlinux.org/mirrors/status/json/
# Retrieved: 2021-04-04 02:02:34 UTC
# Last Check: 2021-04-04 01:21:15 UTC
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Server = https://europe.mirror.pkgbuild.com/$repo/os/$arch
Server = https://asia.mirror.pkgbuild.com/$repo/os/$arch
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
warning: garuda-common-settings: local (1.1.3-2) is newer than chaotic-aur (1.1.3-1)
Packages (86) android-tools-31.0.0-1 bat-0.18.0-2 beautyline-20210330-1 blas-3.9.1-1
bluetooth-autoconnect-1.3-1 bluez-5.57-1 bluez-hid2hci-5.57-1 bluez-libs-5.57-1
bluez-plugins-5.57-1 bluez-utils-5.57-1 cblas-3.9.1-1 chaotic-keyring-20210330-1
chaotic-mirrorlist-20210329-1 cht.sh-git-r847.83bffa5-1 cronie-1.5.7-2 curl-7.76.0-1
dxvk-mingw-git-1.8.1.r37.ga690210e-1 exa-0.9.0-3 expac-10-2 faudio-21.04-1 file-5.40-1
fish-3.2.1-1 fish-autopair-1.0.3-1 fish-systemd-git-r8.b570b22-1 garuda-dr460nized-1.1.1-2
garuda-fish-config-1.1.0-1 garuda-setup-assistant-1.0.1-1 ghostscript-9.54.0-2
groff-1.22.4-5 gsettings-desktop-schemas-40.0-2 gtk-update-icon-cache-1:4.2.0-2
gtksourceview3-3.24.11+28+g73e57b57-1 haskell-conduit-1.3.4.1-11 haskell-hashable-1.3.1.0-24
haskell-hslogger-1.3.1.0-104 haskell-mono-traversable-1.0.15.1-124 haskell-network-3.1.2.1-46
haskell-network-bsd-2.8.1.0-84 haskell-primitive-0.7.1.0-118 haskell-random-1.2.0-197
haskell-resourcet-1.2.4.2-76 haskell-sandi-0.5-217 haskell-split-0.2.3.4-126
haskell-splitmix-0.1.0.3-94 haskell-unordered-containers-0.2.13.0-57
haskell-utf8-string-1.0.2-31 haskell-vector-0.12.2.0-55 haskell-vector-algorithms-0.8.0.4-46
hedgewars-1.0.0-178 hostapd-2.9-5 imagemagick-7.0.11.6-1 lapack-3.9.1-1
latte-dock-git-r5190.f242bdf3-1 ldb-1:2.3.0-1 lib32-curl-7.76.0-1 lib32-faudio-21.04-1
lib32-libcurl-compat-7.76.0-1 lib32-libcurl-gnutls-7.76.0-1 lib32-systemd-248-1
libcurl-compat-7.76.0-1 libcurl-gnutls-7.76.0-1 libxres-1.2.1-1 linux-zen-5.11.11.zen1-1
linux-zen-headers-5.11.11.zen1-1 meld-3.20.3-1 networkmanager-openvpn-1.8.14-1 paru-1.5.0-1
performance-tweaks-1.0.1-1 proton-ge-custom-bin-6.5_GE_1-1
protontricks-git-1.4.5.dev6+g6b53c08-1 python-cryptography-3.4.7-1 python-gobject-3.40.1-1
python-idna-3.1-1 python-matplotlib-3.4.1-2 python-setuptools-1:54.2.0-1
python-urllib3-1.26.4-1 qt5-svg-5.15.2-2 rare-git-0.8.9.3.r3.gab895d4-1 re2-1:20210401-1
retroarch-autoconfig-udev-git-r1882.343ea73-1 rlwrap-0.43-4 systemd-248-2 systemd-libs-248-2
systemd-sysvcompat-248-2 timeshift-20.11.1+3+g08d0e59-3 whoogle-git-0.3.2_r278.gb1227bd-1
Total Download Size: 645.00 MiB
Total Installed Size: 1613.87 MiB
Net Upgrade Size: 37.83 MiB
systemd-libs-248-2-x86_64 556.5 KiB 2.38 MiB/s 00:00 [------------------------------------] 0%
curl-7.76.0-1-x86_64 1643.7 KiB 3.93 MiB/s 00:00 [------------------------------------] 0%
file-5.40-1-x86_64 1989.0 KiB 4.06 MiB/s 00:00 [------------------------------------] 0%
systemd-248-2-x86_64 8.2 MiB 10.3 MiB/s 00:01 [------------------------------------] 1%
cronie-1.5.7-2-x86_64 8.3 MiB 9.48 MiB/s 00:01 [------------------------------------] 1%
groff-1.22.4-5-x86_64 10.5 MiB 10.3 MiB/s 00:01 [------------------------------------] 1%
systemd-sysvcompat-248-2-x86_64 10.5 MiB 9.76 MiB/s 00:01 [------------------------------------] 1%
blas-3.9.1-1-x86_64 10.6 MiB 9.31 MiB/s 00:01 [------------------------------------] 1%
bluez-5.57-1-x86_64 11.5 MiB 9.11 MiB/s 00:01 [------------------------------------] 1%
python-gobject-3.40.1-1-x86_64 11.7 MiB 8.71 MiB/s 00:01 [------------------------------------] 1%
bluez-hid2hci-5.57-1-x86_64 11.7 MiB 8.36 MiB/s 00:01 [------------------------------------] 1%
bluez-libs-5.57-1-x86_64 11.8 MiB 7.97 MiB/s 00:01 [------------------------------------] 1%
bluez-plugins-5.57-1-x86_64 11.8 MiB 7.66 MiB/s 00:02 [------------------------------------] 1%
bluez-utils-5.57-1-x86_64 13.0 MiB 7.78 MiB/s 00:02 [------------------------------------] 2%
cblas-3.9.1-1-x86_64 13.1 MiB 7.53 MiB/s 00:02 [------------------------------------] 2%
gtk-update-icon-cache-1:4.2.0-2-... 13.1 MiB 7.29 MiB/s 00:02 [------------------------------------] 2%
gsettings-desktop-schemas-40.0-2-any 13.7 MiB 7.26 MiB/s 00:02 [------------------------------------] 2%
gtksourceview3-3.24.11+28+g73e57... 14.4 MiB 7.26 MiB/s 00:02 [------------------------------------] 2%
meld-3.20.3-1-any 15.2 MiB 7.24 MiB/s 00:02 [------------------------------------] 2%
qt5-svg-5.15.2-2-x86_64 15.3 MiB 7.06 MiB/s 00:02 [------------------------------------] 2%
libxres-1.2.1-1-x86_64 15.3 MiB 6.88 MiB/s 00:02 [------------------------------------] 2%
re2-1:20210401-1-x86_64 15.5 MiB 6.68 MiB/s 00:02 [------------------------------------] 2%
ghostscript-9.54.0-2-x86_64 33.2 MiB 10.8 MiB/s 00:03 [------------------------------------] 5%
imagemagick-7.0.11.6-1-x86_64 35.7 MiB 11.0 MiB/s 00:03 [------------------------------------] 5%
lapack-3.9.1-1-x86_64 38.1 MiB 11.3 MiB/s 00:03 [------------------------------------] 5%
ldb-1:2.3.0-1-x86_64 38.3 MiB 11.1 MiB/s 00:03 [------------------------------------] 5%
linux-zen-5.11.11.zen1-1-x86_64 135.5 MiB 19.0 MiB/s 00:07 [------------------------------------] 21%
linux-zen-headers-5.11.11.zen1-1... 159.5 MiB 19.5 MiB/s 00:08 [------------------------------------] 24%
networkmanager-openvpn-1.8.14-1-... 159.7 MiB 19.3 MiB/s 00:08 [------------------------------------] 24%
python-cryptography-3.4.7-1-x86_64 160.3 MiB 19.2 MiB/s 00:08 [------------------------------------] 24%
python-idna-3.1-1-any 160.3 MiB 19.1 MiB/s 00:08 [------------------------------------] 24%
python-setuptools-1:54.2.0-1-any 160.9 MiB 18.9 MiB/s 00:09 [------------------------------------] 24%
python-urllib3-1.26.4-1-any 161.1 MiB 18.8 MiB/s 00:09 [------------------------------------] 24%
android-tools-31.0.0-1-x86_64 162.8 MiB 18.7 MiB/s 00:09 [------------------------------------] 25%
faudio-21.04-1-x86_64 162.9 MiB 18.6 MiB/s 00:09 [------------------------------------] 25%
bat-0.18.0-2-x86_64 164.9 MiB 18.5 MiB/s 00:09 [------------------------------------] 25%
rlwrap-0.43-4-x86_64 165.0 MiB 18.4 MiB/s 00:09 [------------------------------------] 25%
exa-0.9.0-3-x86_64 165.6 MiB 18.3 MiB/s 00:09 [------------------------------------] 25%
expac-10-2-x86_64 165.6 MiB 18.1 MiB/s 00:09 [------------------------------------] 25%
fish-3.2.1-1-x86_64 168.3 MiB 18.0 MiB/s 00:09 [------------------------------------] 26%
haskell-hashable-1.3.1.0-24-x86_64 168.4 MiB 17.8 MiB/s 00:09 [------------------------------------] 26%
haskell-split-0.2.3.4-126-x86_64 168.4 MiB 17.6 MiB/s 00:10 [------------------------------------] 26%
haskell-unordered-containers-0.2... 168.6 MiB 16.4 MiB/s 00:10 [------------------------------------] 26%
haskell-primitive-0.7.1.0-118-x86_64 168.8 MiB 16.1 MiB/s 00:10 [------------------------------------] 26%
haskell-vector-0.12.2.0-55-x86_64 169.7 MiB 15.9 MiB/s 00:11 [------------------------------------] 26%
haskell-vector-algorithms-0.8.0.... 169.8 MiB 15.8 MiB/s 00:11 [------------------------------------] 26%
haskell-mono-traversable-1.0.15.... 170.3 MiB 15.7 MiB/s 00:11 [------------------------------------] 26%
haskell-resourcet-1.2.4.2-76-x86_64 170.3 MiB 15.6 MiB/s 00:11 [------------------------------------] 26%
haskell-conduit-1.3.4.1-11-x86_64 170.6 MiB 15.4 MiB/s 00:11 [------------------------------------] 26%
haskell-network-3.1.2.1-46-x86_64 170.9 MiB 15.3 MiB/s 00:11 [------------------------------------] 26%
haskell-network-bsd-2.8.1.0-84-x... 170.9 MiB 15.2 MiB/s 00:11 [------------------------------------] 26%
haskell-hslogger-1.3.1.0-104-x86_64 171.0 MiB 15.1 MiB/s 00:11 [------------------------------------] 26%
haskell-splitmix-0.1.0.3-94-x86_64 171.1 MiB 15.0 MiB/s 00:11 [------------------------------------] 26%
haskell-random-1.2.0-197-x86_64 171.2 MiB 14.9 MiB/s 00:12 [------------------------------------] 26%
haskell-sandi-0.5-217-x86_64 171.3 MiB 14.8 MiB/s 00:12 [------------------------------------] 26%
haskell-utf8-string-1.0.2-31-x86_64 171.4 MiB 14.7 MiB/s 00:12 [------------------------------------] 26%
hedgewars-1.0.0-178-x86_64 320.3 MiB 17.9 MiB/s 00:18 [------------------------------------] 49%
hostapd-2.9-5-x86_64 320.9 MiB 17.9 MiB/s 00:18 [------------------------------------] 49%
libcurl-compat-7.76.0-1-x86_64 321.1 MiB 17.8 MiB/s 00:18 [------------------------------------] 49%
libcurl-gnutls-7.76.0-1-x86_64 321.4 MiB 17.8 MiB/s 00:18 [------------------------------------] 49%
python-matplotlib-3.4.1-2-x86_64 326.4 MiB 17.8 MiB/s 00:18 [------------------------------------] 50%
lib32-systemd-248-1-x86_64 327.0 MiB 17.7 MiB/s 00:18 [------------------------------------] 50%
lib32-curl-7.76.0-1-x86_64 327.2 MiB 17.7 MiB/s 00:19 [------------------------------------] 50%
lib32-faudio-21.04-1-x86_64 327.3 MiB 17.6 MiB/s 00:19 [------------------------------------] 50%
lib32-libcurl-compat-7.76.0-1-x86_64 327.6 MiB 17.5 MiB/s 00:19 [------------------------------------] 50%
lib32-libcurl-gnutls-7.76.0-1-x86_64 327.9 MiB 17.5 MiB/s 00:19 [------------------------------------] 50%
beautyline-20210330-1-any 331.0 MiB 16.5 MiB/s 00:20 [------------------------------------] 51%
bluetooth-autoconnect-1.3-1-any 331.0 MiB 16.3 MiB/s 00:20 [------------------------------------] 51%
chaotic-keyring-20210330-1-any 331.0 MiB 15.5 MiB/s 00:21 [------------------------------------] 51%
chaotic-mirrorlist-20210329-1-any 331.0 MiB 15.1 MiB/s 00:22 [------------------------------------] 51%
dxvk-mingw-git-1.8.1.r37.ga69021... 337.7 MiB 8.96 MiB/s 00:38 [------------------------------------] 52%
cht.sh-git-r847.83bffa5-1-any 337.8 MiB 8.62 MiB/s 00:39 [------------------------------------] 52%
fish-autopair-1.0.3-1-any 337.8 MiB 8.15 MiB/s 00:41 [------------------------------------] 52%
fish-systemd-git-r8.b570b22-1-any 337.8 MiB 8.03 MiB/s 00:42 [------------------------------------] 52%
garuda-fish-config-1.1.0-1-any 337.8 MiB 7.92 MiB/s 00:43 [------------------------------------] 52%
garuda-dr460nized-1.1.1-2-any 345.0 MiB 7.65 MiB/s 00:45 [------------------------------------] 53%
garuda-setup-assistant-1.0.1-1-any 345.0 MiB 7.57 MiB/s 00:46 [------------------------------------] 53%
latte-dock-git-r5190.f242bdf3-1-... 346.2 MiB 7.23 MiB/s 00:48 [------------------------------------] 53%
paru-1.5.0-1-x86_64 348.8 MiB 7.14 MiB/s 00:49 [------------------------------------] 54%
performance-tweaks-1.0.1-1-any 348.8 MiB 6.92 MiB/s 00:50 [------------------------------------] 54%
proton-ge-custom-bin-6.5_GE_1-1-... 633.3 MiB 9.44 MiB/s 01:07 [------------------------------------] 98%
protontricks-git-1.4.5.dev6+g6b5... 633.3 MiB 9.32 MiB/s 01:08 [------------------------------------] 98%
rare-git-0.8.9.3.r3.gab895d4-1-any 633.6 MiB 9.26 MiB/s 01:08 [------------------------------------] 98%
retroarch-autoconfig-udev-git-r1... 633.7 MiB 9.17 MiB/s 01:09 [------------------------------------] 98%
timeshift-20.11.1+3+g08d0e59-3-x... 634.6 MiB 8.99 MiB/s 01:11 [------------------------------------] 98%
whoogle-git-0.3.2_r278.gb1227bd-... 645.0 MiB 8.87 MiB/s 01:13 [------------------------------------] 100%
(86/86) checking keys in keyring [------------------------------------] 100%
downloading required keys...
:: Import PGP key 57F3D9CC660431DD, "Pedro Henrique Lara Campos <[email protected]>"? [Y/n] y
(86/86) checking package integrity [------------------------------------] 100%
error: whoogle-git: key "1949E60D299007430C94DC0657F3D9CC660431DD" is unknown
:: Import PGP key 1949E60D299007430C94DC0657F3D9CC660431DD? [Y/n] y
error: key "1949E60D299007430C94DC0657F3D9CC660431DD" could not be looked up remotely
:: File /var/cache/pacman/pkg/whoogle-git-0.3.2_r278.gb1227bd-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
What do you think?
Skip this.
Do this first thing.
Save is already done. What do you think about the upd
output in terms of thegaruda-common-settings
in local being newer than chaotic-aur
and the Pedro Henrique Lara Campos
PGP error for apparently whoogle-git
error? At that point it essentially seems to fail so...
For the whoogle-git error, my VPS became one of the package builders lately and its PGP key needs to be added to your system. I initially let some people test if its working fine. Your system most likely has chaotic-keyring
not updated yet. Try the following:
For the common settings simply do sudo pacman -Suu after updating.
OP, just out of curiosity, which specific ISO did you choose to download and install? I ask because I've trialed a couple of development ISOs that weren't release-ready (and weren't meant for general use).
I'm just throwing that out there as one more thing that should be checked off the troubleshooting list. I apologize if I missed that information somewhere in this lengthy thread.
Why do you ask for advice, being in a series of trouble, and then go and do whatever you like, ignoring the given instructions?
I cannot comprehend this behavior, really!!..
Why should I continue to try help you solve your problem? Give me one reason!
Now you are back in the same situation. No lessons learnt.
Not even things experienced in this topic (roll up the posts to seeā¦).
Sorry for my Magic Crystal Ball failure!
garuda-dr460nized-gaming-linux-zen-210329.iso
@petsam I did as instructed, what are you talking about? I'm fine with your not helping, you're the one who volunteered and I was trying to offer you the info requested. Personal choice and agency are wonderful things and I'm not forcing anything upon you. Also, I do not see myself being in the same place but I am indeed baffled at your hostility and seeming misunderstanding.
@dr460nf1r3 thanks, I've done that and that did seem to work. I did get a conflict:
ā°āĪ» sudo pacman -Suu
I did notice another issue which seems likely unimportant and saw before:
Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Will see if anything else changes now after this update.
So good news, after using this for the past 45 minutes or so, things seem to have stabilized. There must have been something in the in-built update / upgrade process initially that blew some things up and this time while working through it with a manual update via upd
+ resolving the signature issue that I noted things seem to be more "sane."
Grateful for the input that led me to this point. Strange it happened as it did the first couple times, but good that we kinda know what happened.
I have now installed Google Chrome + barrier (synergy fork) successfully and moving forward with the system. I do have other questions and oddities that are cropping up, but they appear to be general issues of KDE customization I believe so I'll open up individual posts about these as I move forward.
So to reiterate for anyone that might stumble upon this, the solution appears to have been:
upd
